openhabian@openhabian:~ $ lsusb
Bus 001 Device 004: ID 152d:0579 JMicron Technology Corp. / JMicron USA Technology Corp. Portable SSD
Bus 001 Device 008: ID 1cf1:0030 Dresden Elektronik ZigBee gateway [ConBee II]
openhabian@openhabian:~ $ ls /dev/serial/by-id/
ls: cannot access ‘/dev/serial/by-id/’: No such file or directory
openhabian@openhabian:~ $ sudo ls /dev/serial/by-id/
[sudo] password for openhabian:
openhabian@openhabian:~ $ cd /dev/
block/ bus/ disk/ fd/ mapper/ net/ serial/ snd/
bsg/ char/ dma_heap/ input/ mqueue/ pts/ shm/ v4l/
openhabian@openhabian:~ $ cd /dev/serial/
openhabian@openhabian:/dev/serial $ ls
by-path
openhabian@openhabian:/dev/serial $ ls /dev/serial/by-path
platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0
I change now teh usb port. But the update doesn´t run.
With ubuntu I am not able to install deconz. There I got the error that am not able tu install deconz. I was update the source. But I can´t install deconz. Is there any way to update the firmware, whitout a installation.
I am not able to get it run. I didn’t understand anymore. I think I have a problem with the whole installation. Couse I saw screenshots where persons see more information for the same sensor. Is there any commercial support.
