Hi all,
it´s my first post here, so at first sorry, if I miss something.
I used deconz with raspbee 2 on openhabian without problems - until yesterday.
We had a power breakdown, and after reboot openhabian won´t find the deconz-gateway. By checking the service, I got this:
openhabian@openhabian:/tmp $ sudo /bin/systemctl start deconz.service
openhabian@openhabian:/tmp $ sudo /bin/systemctl status deconz.service
● deconz.service - deCONZ: ZigBee gateway – REST API
Active: activating (auto-restart) (Result: signal) since Thu 2024-02-08 12:15:43 CET; 8s ago
Process: 2780 ExecStart=/usr/bin/deCONZ -platform minimal --http-port=8081 --ws-port=8081 (code=killed, signal=ILL)
Main PID: 2780 (code=killed, signal=ILL)
CPU: 964ms
I suppose, that “code=killed, signal=ILL” isn´t so good?
What had I done to solve this?
- stop and start service (more than one time)
- remove and new install of deconz
- new install of raspbee 2, as described here on phoscon.de
- searching on internet without success
Do you have a hint for me, what´s going wrong here?
Best wishes and thank you
Veikko
