I have a few (the number seems to be growing by the day) of lights that were once paired, unpairing, then being unable to re-pair.
I have tried just enabling pairing then reseting the light (this would normaly work), and I have tried deleting the unpaired light to try to start from the beginning.
Phoscon just shows nothing. And deConz shows a box but no name and no dropdown menu accessible (no plus button). I can only assume that this is my light.
I can add a new light that hasn’t been setup before just fine.
Ha ? Strange it happen on router …
Have you tried a “right clic” on the node title ? you will found some command to ask information, one of them is probably missing (or be blocked)
Yes, but why deconz can’t complete the pairing with the requests on right clic menu …
Can you retry for exemple “Read node descriptor” but with logging enabled ?
