Hi! I Hope this is the correct place for this kind of thread…
Im using a temp sensor from Aqara . It works great to pair it with the conbee2… and it works great for about a day. Then it just stops updating. Now at the time of writing this. The last update time was 7 hours ago.
I have tried deleting the sensor and reconnecting it again. Then it works for a day or so before it stops working.
Has anybody been able to solve this? Or kmow of any better temp sensor that works better?
So it’s strange, If I m right without report in 24h they are marked as “unreachable”.
So if you have them in black in phoscon, it mean something happenend.
Can you check direclty the API using Phoscon/help/API Information/sensors, you will see a lastseen and a lastupdated.
You haven’t access to the GUI to see connection ? if you put the sensor closest the gateway (with new inclusion), same result ? (to test connections issues)
One addition to this.
Yesterday evening I deleted one of the temp sensors and readded it… which made it start working again. (It usually works for a while) but this morning I realized that the Ikea tradfri lights now stopped working instead…
