OK, so I created a DDF via drag & drop:
"manufacturername": "CentraLite",
"modelid": "Motion Sensor-A",
"product": "Motion Sensor-A",
"sleeper": false,
"status": "Bronze",
"path": "/devices/motion_sensor-a.json",
"restapi": "/sensors",
"0x01",
"0x0402"
"fingerprint": {
"profile": "0x0104",
"device": "0x0402",
"endpoint": "0x01",
"in": [
"0x0000",
"0x0001",
"0x0402"
"name": "attr/swversion"
"name": "config/battery",
"description": "The current device battery level in 0–100 %."
"name": "config/offset",
"description": "Relative offset to the main measured value.",
"default": 0
"name": "config/on"
"name": "config/reachable"
"name": "state/lastupdated"
"name": "state/temperature",
"at": "0x0000",
"cl": "0x0402",
"ep": 0,
"eval": "Item.val = Attr.val + R.item('config/offset').val + 99",
"fn": "zcl"
"default": 0
"0x01",
"0x0406"
"name": "config/duration"
"name": "config/on"
"name": "state/presence"
It works, but only for one of my sensors. (I guess it might be my old one. Maybe it is another hardware/software version inside?)
However when I deleted this file another DDF was autocreated. Where did that come from?
"sleeper": false,
"status": "Bronze",
"0xff",
"0x0406"
"name": "config/duration",
"description": "The duration until presence is automatically turned back to false."
"name": "config/on"
"0x01",
"0x0402"
"fingerprint": {
"device": "0x0402",
"endpoint": "0x01",
"in": [
"0x0000",
"0x0001",
"0x0402"
"description": "The current device battery level in 0–100 %.",
"at": "0x0020",
"cl": "0x0001",
"cppsrc": "power_configuration.cpp:44",
"ep": 255,
"eval": "const vmin = 20,0; const vmax = 30,0; let bat = Attr.val; if (bat > vmax) { bat = vmax; } else if (bat < vmin) { bat = vmin; } bat = ((bat - vmin) / (vmax - vmin)) * 100; if (bat > 100) { bat = 100; } else if (bat <= 0) { bat = 1; } Item.val = bat;"
"default": 0
"name": "config/on"
"description": "The current temperature in °C × 100.",
"default": 0
"bindings": [
"dst.ep": 1,
"cl": "0x0001"
The second one does not work at all (for motion sensing).
