I have a Zigbee pool sensor from Ali and i was able to connect it to Deconz and then integrate it to IP Symcon. I’m getting the values, but only every hour. Sometimes i need values now if I add chemicals. There is a button in the DeconZ GUI to “Trigger all datapoints”. If i click this, the sensor is reading and sending new data.
Is it possible to do it over API?
Product: Zigbee Chlorine Meter PH ORP EC TDS Salinity Temp CL
Manufacture name: _TZE200_v1jqz5cy
Model: TS0601
