Hi everybody,
i read some posts, but i didn’t found a solution for my problem. I’ve got an Conbee II that run under ubuntu. When i try to backup phoscon i get error that the backup fails. My network settings seems to be correct and i can add new devices.
The software is updated:
I have no idea to fix it and hope somebody can help me.
Greetings Peter
Smanar
March 19, 2023, 6:29pm
2
Hello, can you share some logs ?
From deconz with “info” and “info_l2” or at least from your browser, but IDK if they are usefull.
Mimiix
March 20, 2023, 11:05am
3
My network settings look different, perhaps that might be the issue?
Smanar
March 20, 2023, 4:53pm
4
“Network update id” is the number of time you have updated your network config, IDK if the value can me modified.
BTW, the bad value for Security mode is worrying …
Hi everybody, after i change my Security mode to “High”, the backup is now possible. Everthing works fine. Thank you very much.
Greetings Peter
Smanar
March 21, 2023, 4:39pm
6
Ha nice catch.
First time I see this issue (first time I see someone with not the defaut setting here too ^^) but realy good to know.
