Hello.
A new update of deCONZ (addon in my Home Assistant) has recently appeared. It asked to upgrade from version 6.12.1 to version 6.13.0.
I have done it and suddenly the Phoscon app has stopped working with the following message:
“The web page http://192.168.9.10:8123/api/hassio_ingress/dY4Wak76CxIaGnp-A-lPYD9hbwLmE23TQgwG-zvdgkU/pwa/index.html may be temporarily down or may have moved permanently to another address.”
Trying to solve the problem I have undone the update and it still gives the same problem.
I’ve gotten hold of a full backup of Home Assistant from yesterday, and the problem persists.
Any ideas.
Is the addon started?
Yes. There are some errors in the log:
19:10:55:675 ZCL attribute report 0x00158D00026D30D0 for cluster: 0x000C, ep: 0x02, frame control: 0x18, mfcode: 0x0000
19:11:01:700 0x00158D0003F457FE error APSDE-DATA.confirm: 0xE9 on task
19:11:02:493 0x00158D0003F457FE error APSDE-DATA.confirm: 0xE9 on task
19:11:04:680 ZCL attribute report 0x00158D00026D30D0 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:11:14:962 Device TTL 5159 s flags: 0x7
19:11:15:683 ZCL attribute report 0x00158D00026D30D0 for cluster: 0x000C, ep: 0x02, frame control: 0x18, mfcode: 0x0000
19:11:21:588 0x00158D00044B2E84 error APSDE-DATA.confirm: 0xE9 on task
But it seems that all devices work. What has stopped working is the APP
But with a VNC client I get this message:
I think this is solely a Addon issue in that matter.
We don’t maintain the addon so we cant be of much help here.
It’s okay. Thank you. It was just in case it had happened to someone else.
Had no problems in 3 years of use.
Only thing I can recommend is check if you did the ports in the addon configuration. Then, if you did, go to that url with that port and see if phoscon opens there.
