Here is the Log. 18:06 I actived the permit to Join and pressed the Button of the Power Plug.
It was flashing all the time, but did not connect.
I do not see anything in the log. The Adapter might be broken?
18:04:52:685 DEV found DDF for 0xA4C13881311EA0BA, path: /usr/share/deCONZ/devices/tuya/_TZ3000_yd2e749y_temp_hum_sensor.json
18:04:52:705 dlg action: Read binding table
18:04:52:750 DEV found DDF for 0xA4C138972BEDF8B9, path: /usr/share/deCONZ/devices/tuya/_TZ3000_yd2e749y_temp_hum_sensor.json
18:04:53:471 COM: /dev/ttyACM0 / serialno: , ConBee II
18:04:55:124 Device firmware version 0x26720700 ConBee II
18:04:55:150 unlocked max nodes: 512
18:04:55:150 Device protocol version: 0x010E
18:04:55:324 New websocket 192.168.178.28:54306 (state: 3)
18:04:55:394 Current channel 15
18:04:55:480 CTRL ANT_CTRL 0x03
18:04:55:498 CTRL ZDP_RESPONSE handler 0x0000
18:04:55:499 CTRL reconfigure ZDP_RESPONSE handler 0x0001
18:04:57:544 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26720700.bin.GCF
18:04:57:545 GW firmware version is up to date: 0x26720700
18:04:57:811 Announced to internet https://phoscon.de/discover
18:05:00:394 New websocket 192.168.178.43:50632 (state: 3)
18:05:00:681 DEV Tick.Init: booted after 8000 seconds
18:05:22:681 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:05:24:907 sql exec SELECT * FROM nodes WHERE mac='00:21:2e:ff:ff:09:7e:6e-01' COLLATE NOCASE AND state != 'deleted'
18:05:24:908 sql exec SELECT * FROM nodes WHERE mac='0x00212effff097e6e' COLLATE NOCASE AND state != 'deleted'
18:05:24:909 sql exec SELECT * FROM nodes WHERE mac='00:21:2e:ff:ff:09:7e:6e-01' COLLATE NOCASE AND state != 'deleted'
18:05:24:910 sql exec SELECT * FROM nodes WHERE mac='0x00212effff097e6e' COLLATE NOCASE AND state != 'deleted'
18:05:32:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:05:42:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:05:43:180 Idle timer triggered
18:05:51:707 [Master] read param with arg 0x19
18:05:52:680 DB save zll database items 0x00000084
18:05:52:681 DB sql exec REPLACE INTO auth (apikey, devicetype, createdate, lastusedate, useragent) VALUES ('308206F71A', 'Phoscon#B1920x1075', '2023-01-27T14:04:01', '2023-01-27T17:05:49', 'Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/109.0')
18:05:52:682 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastseen', '2023-01-27T17:04Z', 'dev', 1674749304 FROM sub_devices WHERE uniqueid = 'a4:c1:38:81:31:1e:a0:ba-01-0402'
18:05:52:683 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/on', 'true', 'dev', 1674749244 FROM sub_devices WHERE uniqueid = 'a4:c1:38:81:31:1e:a0:ba-01-0402'
18:05:52:684 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/reachable', 'false', 'dev', 1674839092 FROM sub_devices WHERE uniqueid = 'a4:c1:38:81:31:1e:a0:ba-01-0402'
18:05:52:684 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/battery', '54', 'dev', 1674779820 FROM sub_devices WHERE uniqueid = 'a4:c1:38:81:31:1e:a0:ba-01-0402'
18:05:52:685 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/offset', '0', 'dev', 1674838972 FROM sub_devices WHERE uniqueid = 'a4:c1:38:81:31:1e:a0:ba-01-0402'
18:05:52:686 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('14', 'Aussentemperatur', 'ZHATemperature', 'TS0201', '_TZ3000_xr3htd96', 'a4:c1:38:81:31:1e:a0:ba-01-0402', '1.0.6', '{"lastupdated":"2023-01-26T16:08:24.531","temperature":138}', '{"battery":54,"offset":0,"on":true,"reachable":false}', '', 'normal', '1', '2023-01-27T17:04Z', '')
18:05:52:687 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastseen', '2023-01-27T17:04Z', 'dev', 1674749305 FROM sub_devices WHERE uniqueid = 'a4:c1:38:81:31:1e:a0:ba-01-0405'
18:05:52:688 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/on', 'true', 'dev', 1674749244 FROM sub_devices WHERE uniqueid = 'a4:c1:38:81:31:1e:a0:ba-01-0405'
18:05:52:689 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/reachable', 'false', 'dev', 1674839092 FROM sub_devices WHERE uniqueid = 'a4:c1:38:81:31:1e:a0:ba-01-0405'
18:05:52:690 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/battery', '54', 'dev', 1674779820 FROM sub_devices WHERE uniqueid = 'a4:c1:38:81:31:1e:a0:ba-01-0405'
18:05:52:690 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/offset', '0', 'dev', 1674838972 FROM sub_devices WHERE uniqueid = 'a4:c1:38:81:31:1e:a0:ba-01-0405'
18:05:52:691 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('15', 'Aussentemperatur', 'ZHAHumidity', 'TS0201', '_TZ3000_xr3htd96', 'a4:c1:38:81:31:1e:a0:ba-01-0405', '1.0.6', '{"humidity":5546,"lastupdated":"2023-01-26T16:08:24.656"}', '{"battery":54,"offset":0,"on":true,"reachable":false}', '', 'normal', '1', '2023-01-27T17:04Z', '')
18:05:52:693 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastannounced', '', 'dev', 1674831132 FROM sub_devices WHERE uniqueid = 'a4:c1:38:97:2b:ed:f8:b9-01-0402'
18:05:52:694 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastseen', '2023-01-27T17:04Z', 'dev', 1674831132 FROM sub_devices WHERE uniqueid = 'a4:c1:38:97:2b:ed:f8:b9-01-0402'
18:05:52:694 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/on', 'true', 'dev', 1674671505 FROM sub_devices WHERE uniqueid = 'a4:c1:38:97:2b:ed:f8:b9-01-0402'
18:05:52:695 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/reachable', 'false', 'dev', 1674839092 FROM sub_devices WHERE uniqueid = 'a4:c1:38:97:2b:ed:f8:b9-01-0402'
18:05:52:696 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/battery', '30', 'dev', 1674832903 FROM sub_devices WHERE uniqueid = 'a4:c1:38:97:2b:ed:f8:b9-01-0402'
18:05:52:697 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/offset', '0', 'dev', 1674838972 FROM sub_devices WHERE uniqueid = 'a4:c1:38:97:2b:ed:f8:b9-01-0402'
18:05:52:697 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('8', 'Wohnzimmer', 'ZHATemperature', 'TS0201', '_TZ3000_xr3htd96', 'a4:c1:38:97:2b:ed:f8:b9-01-0402', '1.0.6', '{"lastupdated":"2023-01-27T14:52:13.305","temperature":2058}', '{"battery":30,"offset":0,"on":true,"reachable":false}', '', 'normal', '1', '2023-01-27T17:04Z', '')
18:05:52:699 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastannounced', '', 'dev', 1674831132 FROM sub_devices WHERE uniqueid = 'a4:c1:38:97:2b:ed:f8:b9-01-0405'
18:05:52:700 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastseen', '2023-01-27T17:04Z', 'dev', 1674831132 FROM sub_devices WHERE uniqueid = 'a4:c1:38:97:2b:ed:f8:b9-01-0405'
18:05:52:700 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/on', 'true', 'dev', 1674671506 FROM sub_devices WHERE uniqueid = 'a4:c1:38:97:2b:ed:f8:b9-01-0405'
18:05:52:701 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/reachable', 'false', 'dev', 1674839092 FROM sub_devices WHERE uniqueid = 'a4:c1:38:97:2b:ed:f8:b9-01-0405'
18:05:52:702 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/battery', '30', 'dev', 1674832903 FROM sub_devices WHERE uniqueid = 'a4:c1:38:97:2b:ed:f8:b9-01-0405'
18:05:52:702 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/offset', '0', 'dev', 1674838972 FROM sub_devices WHERE uniqueid = 'a4:c1:38:97:2b:ed:f8:b9-01-0405'
18:05:52:703 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('9', 'Wohnzimmer', 'ZHAHumidity', 'TS0201', '_TZ3000_xr3htd96', 'a4:c1:38:97:2b:ed:f8:b9-01-0405', '1.0.6', '{"humidity":5101,"lastupdated":"2023-01-27T14:52:13.472"}', '{"battery":30,"offset":0,"on":true,"reachable":false}', '', 'normal', '1', '2023-01-27T17:04Z', '')
18:05:52:767 DB saved in 86 ms
18:05:52:767 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:06:02:681 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:06:12:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:06:13:181 sql exec SELECT conf FROM zbconf ORDER BY rowid desc limit 1
18:06:13:181 Idle timer triggered
18:06:22:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:06:32:181 send permit join, duration: 65
18:06:32:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:06:32:696 New websocket 192.168.178.44:33854 (state: 3)
18:06:33:181 send permit join, duration: 0
18:06:33:758 Search sensors done
18:06:34:842 Websocket disconnected 192.168.178.44:33854, state: 0, close-code: 1001, reason:
18:06:36:730 New websocket 192.168.178.44:33872 (state: 3)
18:06:42:394 Websocket disconnected 192.168.178.44:33872, state: 0, close-code: 1001, reason:
18:06:42:681 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:06:43:180 Idle timer triggered
18:06:43:715 New websocket 192.168.178.44:33880 (state: 3)
18:06:47:718 Websocket disconnected 192.168.178.44:33880, state: 0, close-code: 1001, reason:
18:06:49:263 New websocket 192.168.178.44:33886 (state: 3)
18:06:52:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:07:02:681 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:07:04:155 Websocket disconnected 192.168.178.44:33886, state: 0, close-code: 1001, reason:
18:07:05:590 New websocket 192.168.178.44:33890 (state: 3)
18:07:09:373 Websocket disconnected 192.168.178.44:33890, state: 0, close-code: 1001, reason:
18:07:10:913 New websocket 192.168.178.44:33896 (state: 3)
18:07:12:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:07:13:180 Idle timer triggered
18:07:13:982 Websocket disconnected 192.168.178.44:33896, state: 0, close-code: 1001, reason:
18:07:15:199 New websocket 192.168.178.44:33900 (state: 3)
18:07:22:681 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:07:29:898 Websocket disconnected 192.168.178.44:33900, state: 0, close-code: 1001, reason:
18:07:31:248 New websocket 192.168.178.44:33902 (state: 3)
18:07:32:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:07:35:414 Websocket disconnected 192.168.178.44:33902, state: 0, close-code: 1001, reason:
18:07:36:508 New websocket 192.168.178.44:33904 (state: 3)
18:07:42:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:07:43:181 sql exec SELECT conf FROM zbconf ORDER BY rowid desc limit 1
18:07:43:181 Idle timer triggered
18:07:52:180 send permit join, duration: 65
18:07:52:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:08:02:681 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:08:12:681 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:08:13:181 Idle timer triggered
18:08:18:229 APS-DATA.indication from child 0x33E3
18:08:18:231 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'state/temperature', '143', 'dev', 1674839298 FROM sub_devices WHERE uniqueid = 'a4:c1:38:81:31:1e:a0:ba-01-0402'
18:08:18:332 ZCL attribute report 0xA4C13881311EA0BA for cluster: 0x0402, ep: 0x01, frame control: 0x08, mfcode: 0x0000
18:08:18:333 payload: 0000298f00
18:08:18:333 Websocket 192.168.178.28:54306 send message: {"attr":{"id":"14","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHATemperature","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"},"e":"changed","id":"14","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 339)
18:08:18:334 Websocket 192.168.178.43:50632 send message: {"attr":{"id":"14","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHATemperature","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"},"e":"changed","id":"14","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 339)
18:08:18:336 Websocket 192.168.178.44:33904 send message: {"attr":{"id":"14","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHATemperature","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"},"e":"changed","id":"14","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 339)
18:08:18:337 Websocket 192.168.178.28:54306 send message: {"config":{"battery":54,"offset":0,"on":true,"reachable":true},"e":"changed","id":"14","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 158)
18:08:18:338 Websocket 192.168.178.43:50632 send message: {"config":{"battery":54,"offset":0,"on":true,"reachable":true},"e":"changed","id":"14","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 158)
18:08:18:338 Websocket 192.168.178.44:33904 send message: {"config":{"battery":54,"offset":0,"on":true,"reachable":true},"e":"changed","id":"14","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 158)
18:08:18:339 Websocket 192.168.178.28:54306 send message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2023-01-27T17:08:18.230","temperature":143},"t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 164)
18:08:18:340 Websocket 192.168.178.43:50632 send message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2023-01-27T17:08:18.230","temperature":143},"t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 164)
18:08:18:341 Websocket 192.168.178.44:33904 send message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2023-01-27T17:08:18.230","temperature":143},"t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 164)
18:08:18:341 Websocket 192.168.178.28:54306 send message: {"attr":{"id":"15","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHAHumidity","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"},"e":"changed","id":"15","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 336)
18:08:18:342 Websocket 192.168.178.43:50632 send message: {"attr":{"id":"15","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHAHumidity","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"},"e":"changed","id":"15","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 336)
18:08:18:343 Websocket 192.168.178.44:33904 send message: {"attr":{"id":"15","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHAHumidity","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"},"e":"changed","id":"15","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 336)
18:08:18:367 Websocket 192.168.178.28:54306 send message: {"config":{"battery":54,"offset":0,"on":true,"reachable":true},"e":"changed","id":"15","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 158)
18:08:18:368 Websocket 192.168.178.43:50632 send message: {"config":{"battery":54,"offset":0,"on":true,"reachable":true},"e":"changed","id":"15","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 158)
18:08:18:369 Websocket 192.168.178.44:33904 send message: {"config":{"battery":54,"offset":0,"on":true,"reachable":true},"e":"changed","id":"15","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 158)
18:08:18:397 APS-DATA.indication from child 0x33E3
18:08:18:398 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'state/humidity', '5587', 'dev', 1674839298 FROM sub_devices WHERE uniqueid = 'a4:c1:38:81:31:1e:a0:ba-01-0405'
18:08:18:511 ZCL attribute report 0xA4C13881311EA0BA for cluster: 0x0405, ep: 0x01, frame control: 0x08, mfcode: 0x0000
18:08:18:512 payload: 000021d315
18:08:18:513 Websocket 192.168.178.28:54306 send message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":5587,"lastupdated":"2023-01-27T17:08:18.398"},"t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 162)
18:08:18:513 Websocket 192.168.178.43:50632 send message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":5587,"lastupdated":"2023-01-27T17:08:18.398"},"t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 162)
18:08:18:515 Websocket 192.168.178.44:33904 send message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":5587,"lastupdated":"2023-01-27T17:08:18.398"},"t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 162)
18:08:19:481 APS-DATA.indication from child 0x33E3
18:08:19:482 Websocket 192.168.178.28:54306 send message: {"attr":{"id":"14","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHATemperature","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"},"e":"changed","id":"14","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 339)
18:08:19:483 Websocket 192.168.178.43:50632 send message: {"attr":{"id":"14","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHATemperature","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"},"e":"changed","id":"14","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 339)
18:08:19:484 Websocket 192.168.178.44:33904 send message: {"attr":{"id":"14","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHATemperature","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"},"e":"changed","id":"14","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 339)
18:08:19:485 Websocket 192.168.178.28:54306 send message: {"attr":{"id":"15","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHAHumidity","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"},"e":"changed","id":"15","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 336)
18:08:19:486 Websocket 192.168.178.43:50632 send message: {"attr":{"id":"15","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHAHumidity","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"},"e":"changed","id":"15","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 336)
18:08:19:487 Websocket 192.168.178.44:33904 send message: {"attr":{"id":"15","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHAHumidity","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"},"e":"changed","id":"15","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 336)
18:08:19:516 APS-DATA.indication from child 0x33E3
18:08:19:692 APS-DATA.indication from child 0x33E3
18:08:19:693 Websocket 192.168.178.28:54306 send message: {"attr":{"id":"14","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHATemperature","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"},"e":"changed","id":"14","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 339)
18:08:19:694 Websocket 192.168.178.43:50632 send message: {"attr":{"id":"14","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHATemperature","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"},"e":"changed","id":"14","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 339)
18:08:19:695 Websocket 192.168.178.44:33904 send message: {"attr":{"id":"14","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHATemperature","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"},"e":"changed","id":"14","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0402"} (ret = 339)
18:08:19:696 Websocket 192.168.178.28:54306 send message: {"attr":{"id":"15","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHAHumidity","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"},"e":"changed","id":"15","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 336)
18:08:19:697 Websocket 192.168.178.43:50632 send message: {"attr":{"id":"15","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHAHumidity","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"},"e":"changed","id":"15","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 336)
18:08:19:697 Websocket 192.168.178.44:33904 send message: {"attr":{"id":"15","lastannounced":null,"lastseen":"2023-01-27T17:08Z","manufacturername":"_TZ3000_xr3htd96","modelid":"TS0201","name":"Aussentemperatur","swversion":"1.0.6","type":"ZHAHumidity","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"},"e":"changed","id":"15","r":"sensors","t":"event","uniqueid":"a4:c1:38:81:31:1e:a0:ba-01-0405"} (ret = 336)
18:08:19:810 APS-DATA.indication from child 0x33E3
18:08:19:927 APS-DATA.indication from child 0x33E3
18:08:20:038 APS-DATA.indication from child 0x33E3
18:08:20:154 APS-DATA.indication from child 0x33E3
18:08:22:681 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:08:32:681 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:08:42:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:08:43:180 Idle timer triggered
18:08:43:181 Force read attributes for ZHATemperature SensorNode Aussentemperatur
18:08:43:181 Force read attributes for ZHAHumidity SensorNode Aussentemperatur
18:08:51:708 [Master] read param with arg 0x19
18:08:52:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:08:53:181 send permit join, duration: 65
18:08:57:681 GW firmware version: 0x26720700
18:08:57:681 GW firmware version is up to date: 0x26720700
18:09:02:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:09:12:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:09:13:181 sql exec SELECT conf FROM zbconf ORDER BY rowid desc limit 1
18:09:13:182 Idle timer triggered
18:09:13:182 Force read attributes for ZHATemperature SensorNode Aussentemperatur
18:09:13:182 Force read attributes for ZHAHumidity SensorNode Aussentemperatur
18:09:19:253 Remove websocket 192.168.178.44:33904 after error Unknown error, close-code: 1000, reason:
18:09:22:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:09:32:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:09:42:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:09:43:181 Idle timer triggered
18:09:43:181 Force read attributes for ZHATemperature SensorNode Aussentemperatur
18:09:43:181 Force read attributes for ZHAHumidity SensorNode Aussentemperatur
18:09:52:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:09:54:181 send permit join, duration: 57
18:10:02:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:10:12:681 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:10:13:180 Idle timer triggered
18:10:13:181 Force read attributes for ZHATemperature SensorNode Aussentemperatur
18:10:13:181 Force read attributes for ZHAHumidity SensorNode Aussentemperatur
18:10:13:181 SensorNode id: 8 (Wohnzimmer) available
18:10:13:181 SensorNode id: 9 (Wohnzimmer) available
18:10:13:189 Websocket 192.168.178.28:54306 send message: {"config":{"battery":30,"offset":0,"on":true,"reachable":true},"e":"changed","id":"8","r":"sensors","t":"event","uniqueid":"a4:c1:38:97:2b:ed:f8:b9-01-0402"} (ret = 157)
18:10:13:189 Websocket 192.168.178.43:50632 send message: {"config":{"battery":30,"offset":0,"on":true,"reachable":true},"e":"changed","id":"8","r":"sensors","t":"event","uniqueid":"a4:c1:38:97:2b:ed:f8:b9-01-0402"} (ret = 157)
18:10:13:190 Websocket 192.168.178.28:54306 send message: {"config":{"battery":30,"offset":0,"on":true,"reachable":true},"e":"changed","id":"9","r":"sensors","t":"event","uniqueid":"a4:c1:38:97:2b:ed:f8:b9-01-0405"} (ret = 157)
18:10:13:191 Websocket 192.168.178.43:50632 send message: {"config":{"battery":30,"offset":0,"on":true,"reachable":true},"e":"changed","id":"9","r":"sensors","t":"event","uniqueid":"a4:c1:38:97:2b:ed:f8:b9-01-0405"} (ret = 157)
18:10:22:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:10:30:824 Websocket disconnected 192.168.178.28:54306, state: 0, close-code: 1001, reason:
18:10:32:049 New websocket 192.168.178.28:54536 (state: 3)
18:10:32:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:10:42:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:10:43:181 sql exec SELECT conf FROM zbconf ORDER BY rowid desc limit 1
18:10:43:181 Idle timer triggered
18:10:43:182 Force read attributes for ZHATemperature SensorNode Aussentemperatur
18:10:43:182 Force read attributes for ZHAHumidity SensorNode Aussentemperatur
18:10:51:181 send permit join, duration: 0
18:10:51:673 Search sensors done
18:10:52:681 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:11:02:681 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:11:12:680 Daylight now: dusk, status: 210, daylight: 0, dark: 1
18:11:13:181 Idle timer triggered
18:11:13:181 Force read attributes for ZHATemperature SensorNode Aussentemperatur
18:11:13:181 Force read attributes for ZHAHumidity SensorNode Aussentemperatur
I think I will return the Power Plugs and order some new
