The Gateway screen is broken in deCONZ 2.17.0. The menu icons are in the wrong language and they are also not working/no link on the icons.
This in Brave browser. When I open the app directly on the deCONZ app on the RPi it looks fine.
Mimiix
June 14, 2022, 1:52pm
2
Work around is clearing the browser cache.
Hmm it does not seem to fix it to delete the site cache. And I do think it is getting deleted since I have to login again.
Mimiix
June 14, 2022, 3:59pm
4
The browser cache not site cache.
manup
June 14, 2022, 10:24pm
5
If you’re on Windows you may try Ctrl+F5 (force reload).
There is some functionality in the app to refresh the cache automatically but I think a few places are missing
BarryT
June 15, 2022, 6:15pm
6
Use cache cleaner extension in chrome, that should fix most problems after updates…
Thanks! Ctrl+F5 worked. I didn’t know about that one before.
pcman
June 22, 2022, 5:22am
8
deCONZ 2.17.0 here. I have the same problem. Gateway does not work and buttons are not English.
Reset browser cache does not solve the issue.
Chrome development console show errors:
manup
June 23, 2022, 1:14am
9
@ChrisHae can you check this please looks like a missing guard.
Yes there is a typo in the code. Will be fixed in next release.
Same after updating (from 2.16.1) to 2.17.1. Fixed by deleting browser cache.
opened 08:58PM - 08 Jul 22 UTC
closed 09:12PM - 08 Jul 22 UTC
Bug report
- Use this issue template to report a bug in the deCONZ REST-API.
- A… nything that is not clearly a bug can implicate manual closure. For support we recommend the forum: https://forum.phoscon.de
- If you want to report a bug for the Phoscon App, please head over to: https://forum.phoscon.de
- If you're unsure if the bug fits into this issue tracker, please ask for advise in our Discord chat: https://discord.gg/QFhTxqN
- Please make sure sure you're running the latest version of deCONZ: https://github.com/dresden-elektronik/deconz-rest-plugin/releases
## Describe the bug
Updated from 2.16.1 to 2.17.1 using Home Assistant addon (6.14.2 to 6.15.0).
Since the update the gateway settings page is almost empty:
Deleted browser cache, issue persits.
## Steps to reproduce the behavior
1. Update to 2.17.1
2. Turn to Phoscon gateway page
## Expected behavior
Details shown as before, including backup options (VERY important!)
## Screenshots
![grafik](https://user-images.githubusercontent.com/13799156/178068867-7b1bce0e-47dc-4c83-ac3b-2afb91839b32.png)
## Environment
The deCONZ and firmware versions are found in the Phoscon App: Menu -> Settings -> Gateway,
as well as in the deCONZ GUI: Menu > Help > About deCONZ.
- Host system: Raspberry Pi
- Running method: Home Assistent deCONZ Add-on
- Firmware version: (26720700)
- deCONZ version: (2.17.1)
- Device: ConBee II
- Do you use an USB extension cable: yes -- only relevant for ConBee I/II
- Is there any other USB or serial devices connected to the host system? If so: Which? - It's clearly not about hardware here.
## deCONZ Logs
Logs
## Additional context
Interestingly, https://github.com/dresden-elektronik/deconz-rest-plugin/releases lists `Fix crash on Phoscon App gateway settings page.`.
thanks, Ctrl+F5 worked on Windows to fix the “display issue”
