Hi there! Im trying to find a solution with Hue Wall Modules which stopped working after last update of deCONZ. All worked without issue for last 6 months. I tried to delete one and pair it back but this is no longer possible. All of these are RDM001 and clearly visible in GUI, also visible in Phoscon app but without a possibility of settings. Attaching some logs and screens.
Thank you for your help and for your great work!
Current versions:
Raspbian GNU/Linux Bullseye (11)
Homebridge 1.8.2
deCONZ version 2.27.2
ConbeeII 26780700
[31/05/2024, 07:15:36] [deCONZ] Phoscon-GW: Entryway and Hall Enrave: add accessory
[31/05/2024, 07:15:36] [deCONZ] Entryway and Hall Enrave: Signify Netherlands B.V. RDM001 v1.0.5 (1 resources)
[31/05/2024, 07:15:36] [deCONZ] Entryway and Hall Enrave: warning: /sensors/29: unknown ZHASwitch: {“config”:{“battery”:100,“on”:true,“reachable”:true},“etag”:“0947922d0a21cb7f5ac2143cacf36296”,“lastannounced”:“2024-05-30T09:30:29Z”,“lastseen”:“2024-05-31T05:11Z”,“manufacturername”:“Signify Netherlands B.V.”,“mode”:1,“modelid”:“RDM001”,“name”:“Entryway and Hall Enrave”,“state”:{“buttonevent”:1002,“lastupdated”:“2024-04-08T04:39:20.932”},“swversion”:“1.0.5”,“type”:“ZHASwitch”,“uniqueid”:“00:17:88:01:0b:02:2e:29-01-fc00”}
[31/05/2024, 07:15:36] [deCONZ] Entryway and Hall Enrave Battery: Name: set to “Entryway and Hall Enrave Battery”
[31/05/2024, 07:15:36] [deCONZ] Entryway and Hall Enrave Battery: Configured Name: set to “Entryway and Hall Enrave Battery”
[31/05/2024, 07:15:36] [deCONZ] Entryway and Hall Enrave Battery: Battery Level: set to 100%
[31/05/2024, 07:15:36] [deCONZ] Entryway and Hall Enrave Battery: Status Low Battery: set to 0
[31/05/2024, 07:15:36] [deCONZ] Entryway and Hall Enrave Battery: lowBatteryThreshold: set to 20%
