Philips Dimmschalter - how to connect it to a lamp?
I integrated the above mentioned switch which is now visible in ‘switches’ in Phoscon (Home Assistant).
But what I want is - like with my Hue Bridge - to connect this switch with a lamp. But this is not possible in Phoscon/Home Assistant. What can I do?
Or maybe I can use either the lamp on/off function in Home Assistant/Phoscon or the stand alone Dimmschalter switch without the HA bridge?
Thanks for your help
Martin
You can use deconz rules with the rest api
A easy way to configure this is the hue essentials app :slight_smile:
Thank you. Don’t exactly know what you mean with the rest api.
I forgot to mention that I don’t use my Hue Bridge anymore. But I will try to use the hue essentials app you mentioned. Is this an integration?
It’s app on your phone or pc.
I can still use the Hue app without the Hue bridge?
Hue essentials is not the hue app.
Ok, I got it :grin: … and I’ll try it out.
