I had restart everything in many times
Deconz or phoscon ?
Can you describe what you are doing ? there is a timer in the procedure to reset the password.
I try to login into the phoscon web page from my HA (as i wrote my HA is on the Synology VM, conBee II in USB, all the zigbee items works and communicate well). It can’t accept the password. If i click to ‘Forgot password’ i go to stop the HA and the VM and than the restart the Synology. When i’m back -in less than 10 minutes- same happpening, pass rejected, and the ip of my mac will be banned in HA (when i click to Login button it try to do login many times, i recognized that when i use the Safari, the deconz page had been refreshed many times).
And wich one defaut password are you using ? delight / delight ?
HA on Synology VM, conBeeII via USB, all the zigbee items works well.
If i click the password reset on the HA/Phoscon page, i go to stop the VM on the synology then i restart the Syno too. When i back to the HA/Phoscon page only have to write the password. I tried with mine and the original (delight) too.
Did you also power down the syno? Removed power?
no, just did restart,
have to remove the power cord too?
Had the same but seems to be working now. On updating the Docker image, I tried to login with hostname and got “Invalid admin password hash” in the logs. Switch to IP address, logged in just fine, and then after that, login with the hostname is now working.
