Pairing Issue Sonoff SNZB-02DR2
My Sonoff SNZB-02DR2 temperature sensor does not want to be recognized. It is there in Deconz but not as a valid device. On the other hand, my SNZB-02D is pairing perfectly. There is some difference between those two temperature sensors, but not that much. There must be something I can do with a DDF file, but I’m not that saffy. Who can help me out? Do I or can I deliver some readings?
You mean you can see it on deconz, but not in the API ?
Indeed, and also not in Phoscon.
I have added your device to the DDF. You can use this file to add your device to your system.
Thank you so much!
