But the sample is not complete (miss the binding) , start on your side, and copy paste your DDF for someone complete it.
Drag and drop a ZHAPresence a ZHATempertature and a ZHALight, set the status to “gold”, you will miss some fied visible on the sample, like state/enrolled. The more important is the basic cluster identification.
Save the file, Make “hot reload” on the menu to test it, and show your DDF to finish it (you will probably miss the state return, because of missing bindings)
I create a DDF and bindings but I cannot see the sensor in Phoscon App.
When I search the sensor he create a generic node name (0xE086) and don’t find the Presence Sensor?!?
I will follow the correct procedure like said @Mimiix we will see…
