Osram Plug 01 switches triggering on and off briefly
Hi, I have 3 Osram plugs in my Zigbee network with a Conbee II. For some time now they have been triggering a short toggle of the switching status. If one plug causes this error, all the others usually react after a short time.
I have already tried a few things, Conbee stick with no extension, different location, with and without hub. Latest updates of Conbee Stick and plugs.
Here some Infos:
Docker with Conbee II
Gateway Version 2.28.1
Firmware: 26780700
Osram Plug 01
Vendor 0x110c
Image 0x0027
Version 0x01020509
In the Deconz debug I see such information, but I can’t analyse it:
sc state/on: not synced
sc tick --> statecallfunction
Does anyone have any idea where I can do further error analysis?
Has anyone ever had a similar problem and been able to solve it?
I would be grateful for any ideas or help.
Thanks!
I think these are the plugs with the firmware issue that causes malformed packets in zigbee. @manup can you confirm?
No not as far as I remember also couldn’t find issues for this.
This indicates that there are on/off control commands queued.
The question is from where do these come. Are the plugs part of any scene or automation?
yes, there was a plug in an automation, but it didn’t work.
I have just seen that v2.30.2 has been available as stable since 2025-05-08. I will download it straight away.
Hi, I’ve just had another ‘Osram plug’ flashing again, so unfortunately the software update doesn’t seem to have helped.
Usually, but not always, there are other SC tick --> StateCallFunction nearby. I think they come from normal working actions.
Here are some messages from the DebugLog again. These are from the ‘osram plug’ that was flashing. I hope someone has an idea?
DeviceAnnce of LightNode: 0x7CB03EAA00B0DF5C Permit Join: 0
0x7CB03EAA00B0DF5C foundGroup 0xFFF0
0x7CB03EAA00B0DF5C foundGroup 0x000F
0x7CB03EAA00B0DF5C foundGroup 0x0003
0x7CB03EAA00B0DF5C foundGroup 0x0010
0x7CB03EAA00B0DF5C foundGroup 0x0007
The device announce looks like the device rebooted. Meaning that either your power dropped or something else is going on inside the device.
Thanks, that sounds plausible. But I already have the latest software and the plugs are connected to the normal power outlet in the flat, and no other device reboots. Only the plugs.
Any ideas what I could do?
Bad firmware of the plug
And about the “foundGroup” logs, I don’t find it in the plugin core but it mean you have your plug in 5 groups ?
It can explain why you have all plugs that react same (if you have an automation on a group)
thank you very much, I will reinstall the firmware for all of them next week.
And yes, I also have groups with the plugs, but no more automations. I deleted these some time ago, could there still be some remains of them in Phoscon? Can I check this?
You can find all groups direclty in tha API using Phoscon/help/API Information/groups.
Some groups are “natives”, but 5 …
But I can make mistake, I haven’t found this message in code, not sure what it mean exaclty.
