OSRAM/LedVance Ceiling light is grey but is working
deconz: 2.17.01 / 1.7.2022
GW: ConBee II FW: 26780700
Light: Ceiling TW OSRAM FW: V1.05.10
I can add the light and then work with it. After one day, the light is grey inside Phoscon:
If I open the group, the light temp and brightness sliders are not shown:
But when I hit the 3 lamp icon:
grafik
Then the light goes on. If I press again, it goes off.
So, the light seems connected but something is telling Phoscon its not?
Where to start?
A restart of the docker container does NOT help.
Docker startup log
[deconzcommunity/deconz] Starting deCONZ...
[deconzcommunity/deconz] Current deCONZ version: 2.17.01
[deconzcommunity/deconz] Web UI port: 80
[deconzcommunity/deconz] Using options --auto-connect=1 --appdata=/opt/deCONZ --dbg-info=1 --dbg-aps=0 --dbg-zcl=0 --dbg-ddf=0 --dbg-dev=0 --dbg-zdp=0 --dbg-ota=0 --dbg-error=0 --dbg-http=0 --http-port=80 --ws-port=443
[deconzcommunity/deconz] VNC Disabled
20:12:53:663 HTTP Server listen on address 0.0.0.0, port: 80, root: /usr/share/deCONZ/webapp/
20:12:53:668 /opt/deCONZ/config.ini exists and is writeable
20:12:53:668 /opt/deCONZ/zll.db exists and is writeable
20:12:53:771 COM: /dev/ttyACM0 / serialno: , ConBee II
20:12:53:772 ZCLDB init file /opt/deCONZ/zcldb.txt
20:12:53:897 DDF enabled for Gold status
20:12:53:999 gw run mode: docker
20:12:53:999 GW sd-card image version file does not exist: /opt/deCONZ/gw-version
20:12:53:000 DB sqlite version 3.34.1
20:12:54:001 DB PRAGMA page_count: 46
20:12:54:001 DB PRAGMA page_size: 4096
20:12:54:001 DB PRAGMA freelist_count: 0
20:12:54:001 DB file size 188416 bytes, free pages 0
20:12:54:001 DB PRAGMA user_version: 9
20:12:54:001 DB cleanup
20:12:54:002 DB create temporary views
20:12:54:009 DB skip loading sensor Humidity 3 3, handled by DDF Aqara temp./hum./press. sensor WSDCGQ11LM
20:12:54:009 DB skip loading sensor Temperature 4 4, handled by DDF Aqara temp./hum./press. sensor WSDCGQ11LM
20:12:54:009 DB skip loading sensor Pressure 5 5, handled by DDF Aqara temp./hum./press. sensor WSDCGQ11LM
20:12:54:011 Started websocket server on 0.0.0.0, port: 443
20:12:54:013 [INFO] - Found file containing button maps. Parsing data...
20:12:54:024 [INFO] - Button maps loaded.
20:12:54:025 found node plugin: libde_rest_plugin.so - REST API Plugin
20:12:54:026 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
20:12:54:036 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
20:12:54:049 LightNode 1: Configuration tool 1 added
20:12:54:068 SensorNode 2 set node 0x00158d0004a03879
20:12:54:071 LightNode 2: Color temperature light 2 added
20:12:54:098 DEV found DDF for 0x00158D0007D3FAD9, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_wsdcgq11lm_temp_hum_press_sensor.json
20:12:54:102 DEV found DDF for 0x00158D0007D3FAD9, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_wsdcgq11lm_temp_hum_press_sensor.json
20:12:54:114 dlg action: Read binding table
20:12:54:123 DEV no DDF for 0x7CB03EAA00AD82C8, modelId: Ceiling TW OSRAM
20:12:54:123 DEV create on-the-fly DDF for 0x7CB03EAA00AD82C8
20:12:55:124 COM: /dev/ttyACM0 / serialno: , ConBee II
20:12:56:087 Skip idle timer callback, too early: elapsed 940 msec
20:12:56:610 Device firmware version 0x26780700 ConBee II
20:12:56:618 unlocked max nodes: 512
20:12:56:710 Device protocol version: 0x010E
20:12:56:777 Current channel 15
20:12:56:797 CTRL ANT_CTRL 0x03
20:12:56:798 CTRL ZDP_RESPONSE handler 0x0001
20:12:56:839 Device protocol version: 0x010E
20:12:56:923 CTRL ANT_CTRL 0x03
20:12:56:924 CTRL ZDP_RESPONSE handler 0x0001
20:12:58:312 New websocket 192.168.178.33:53579 (state: 3)
20:12:58:764 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26720700.bin.GCF
20:12:58:764 GW firmware version is up to date: 0x26780700
20:12:58:917 Announced to internet https://phoscon.de/discover
20:12:59:913 Websocket disconnected 192.168.178.33:53579, state: 0, close-code: 1001, reason:
20:13:01:081 New websocket 192.168.178.33:53583 (state: 3)
20:13:01:613 DEV Tick.Init: booted after 8000 second
Oh - I have to correct me:
Nothing is reachable then. I just had one light and one Button. Since yesterday I also have the Aqara sensor.
None of these are reachable when it happens. But guess what? If I press my Xiaomi button, the light turns on (both marked not reachable).
Log of button which is listed as offline
20:17:53:613 Device TTL 6673 s flags: 0x7
20:18:05:822 [INFO] - Button 1000 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal press, payload: 00001000, zclSeq: 62
20:18:05:822 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:05:824 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:06:027 [INFO] - Button 1002 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal release, payload: 00001001, zclSeq: 63
20:18:06:027 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:06:029 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:06:029 trigger rule 1 - Rule TOOGLE_ON
20:18:06:297 Set sensor check interval to 1000 milliseconds
20:18:07:953 [INFO] - Button 1000 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal press, payload: 00001000, zclSeq: 64
20:18:07:953 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:07:955 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:08:160 [INFO] - Button 1002 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal release, payload: 00001001, zclSeq: 65
20:18:08:160 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:08:162 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:08:162 trigger rule 1 - Rule TOOGLE_ON
20:18:08:373 Set sensor check interval to 1000 milliseconds
20:18:09:790 [INFO] - Button 1000 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal press, payload: 00001000, zclSeq: 66
20:18:09:790 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:09:792 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:09:997 [INFO] - Button 1002 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal release, payload: 00001001, zclSeq: 67
20:18:09:997 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:09:999 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:09:999 trigger rule 1 - Rule TOOGLE_ON
20:18:10:282 Set sensor check interval to 1000 milliseconds
20:18:10:927 [INFO] - Button 1000 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal press, payload: 00001000, zclSeq: 68
20:18:10:927 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:10:928 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:11:126 [INFO] - Button 1002 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal release, payload: 00001001, zclSeq: 69
20:18:11:126 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:11:128 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:11:128 trigger rule 1 - Rule TOOGLE_ON
20:18:11:402 Set sensor check interval to 1000 milliseconds
20:18:13:159 [INFO] - Button 1000 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal press, payload: 00001000, zclSeq: 70
20:18:13:159 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:13:161 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:13:366 [INFO] - Button 1002 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal release, payload: 00001001, zclSeq: 71
20:18:13:366 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:13:368 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:13:368 trigger rule 1 - Rule TOOGLE_ON
20:18:13:579 Set sensor check interval to 1000 milliseconds
20:18:16:205 [INFO] - Button 1000 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal press, payload: 00001000, zclSeq: 72
20:18:16:205 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:16:207 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:16:412 [INFO] - Button 1002 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal release, payload: 00001001, zclSeq: 73
20:18:16:412 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:16:413 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:16:414 trigger rule 1 - Rule TOOGLE_ON
20:18:16:682 Set sensor check interval to 1000 milliseconds
20:18:18:316 [INFO] - Button 1000 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal press, payload: 00001000, zclSeq: 74
20:18:18:316 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:18:318 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:18:528 [INFO] - Button 1002 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal release, payload: 00001001, zclSeq: 75
20:18:18:528 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:18:530 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:18:530 trigger rule 1 - Rule TOOGLE_ON
20:18:18:791 Set sensor check interval to 1000 milliseconds
20:18:21:052 [INFO] - Button 1000 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal press, payload: 00001000, zclSeq: 76
20:18:21:052 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:21:054 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:21:259 [INFO] - Button 1002 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal release, payload: 00001001, zclSeq: 77
20:18:21:259 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:21:261 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:21:262 trigger rule 1 - Rule TOOGLE_ON
20:18:21:472 Set sensor check interval to 1000 milliseconds
20:18:22:327 [INFO] - Button 1000 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal press, payload: 00001000, zclSeq: 78
20:18:22:328 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:22:330 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:22:534 [INFO] - Button 1002 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal release, payload: 00001001, zclSeq: 79
20:18:22:535 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:22:537 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:22:537 trigger rule 1 - Rule TOOGLE_ON
20:18:22:802 Set sensor check interval to 1000 milliseconds
20:18:24:399 [INFO] - Button 1000 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal press, payload: 00001000, zclSeq: 80
20:18:24:399 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:24:402 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:24:606 [INFO] - Button 1002 - lumi.sensor_switch, unicast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Normal release, payload: 00001001, zclSeq: 81
20:18:24:606 ZCL attribute report 0x00158D0004A03879 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
20:18:24:609 rule event /sensors/2/state/lastupdated: 0 -> 0
20:18:24:609 trigger rule 1 - Rule TOOGLE_ON
20:18:24:882 Set sensor check interval to 1000 milliseconds
20:18:53:612 Device TTL 6613 s flags: 0x7
20:19:10:960 Websocket disconnected 192.168.178.33:53835, state: 0, close-code: 1001, reason:
20:19:12:184 New websocket 192.168.178.33:53944 (state: 3)
Can you share logs with the flags as described in #deconz?
sure. I turned the Light a few times on and off (via the 3-light-bulb-icons) at the end: [deconzcommunity/deconz] Starting deCONZ...[deconzcommunity/deconz] Current de - Pastebin.com
Are you using an extension cable? You seem to have interference issues:
  1. 20:28:14:985 0x0000000000000000 error APSDE-DATA.confirm: 0xE1 on task
No, I do not. I guess that is the next step?
Yes. Try that first.
Ok, I’ll test it and report back.
Okay, got a 3m extension cord. It seems to be running now without any issues.
Do you see any issues in that log? => [deconzcommunity/deconz] Starting deCONZ...[deconzcommunity/deconz] Current de - Pastebin.com
Thanks in advance :slight_smile:
Looks good!
