Opple Switch controls all lamps and plugs
Host system: Raspberry Pi 4
  • Running method: Raspbian
  • Firmware version: 266F0700
  • deCONZ version: 2.12.03 / 12.7.2021
  • Device: ConBee II
  • Is there any other USB or serial devices connected to the host system? No
I have a strange problem with an Aquara Opple 3-way switch. If I use the topmost row the switch will switch all lamps and plugs in the house on (right side) or off, independent of the switch assignment (which is only for a set of 3 lamps). The two other rows work as assigned.
you need to click the C on the back :slight_smile:
The switch is already connected to Phoscon and I can assign it to lamps. Or do you mean to reset the switch?
There is a C on the back of the switch. Click it once :slight_smile:
Ok, I decoded your answers to “reconnect the switch” :-). I did it by pressing the _C_onnect button for 5 seconds (clicking it had no effect) and then searching for a new Opple 3-gang switch in the Phoscon beta app (without removing the previous entry). It was detected and the original switch in Phoscon was updated and now works correctly.
BTW, in the beta app the OPPLE switch 3-gang appears two times. I selected the first one.
