Only direct connecteted devices ... no next hop
Hi all,
some days ago, my local zigbee cloud dies.
In deCONZ i see only connections directly to the conBEE-II.
Software is running as docker, so i tried old versions without success. everytime the same behaviour.
Devices near to conbee-II connects. no connection between the 2 active plugs , no connections to other devices, that should be reachable from the active plugs.
Transport a device near to conbee-II and connection is established. (only to conbeeII, not to the plugs)
Firmware and Software versions should be the latest.
some ideas?
Thx, Dirk
Can you share some logs?
Thanks for the reply.
Sure, what should I look for?
I’ve read a bit about environment variables for debugging, but I have no idea how they can be used in Docker or where to find the logs.
Best regards,
Dirk
So you have access to the GUI ?
Take a look in deconz/help/debug view with flags “info”+“info_l2”+“error”+“error_l2” and later with both “aps”.
But with this method you will be not able to make a copy/paste.
Try to see something special.
perhaps some help here > Source Routing · dresden-elektronik/deconz-rest-plugin Wiki · GitHub
09:11:27:947 Invalid admin password hash
09:11:29:067 ZDP get active endpoints for 0x15A7
09:11:30:471 ZDP get active endpoints for 0xE897
09:11:31:359 discovery for zombie 0x914805602BD5B370 dropped, last try was 176 seconds ago
09:11:32:987 Invalid admin password hash
09:11:38:144 Invalid admin password hash
09:11:39:998 node 0xF0D1B800001D18A3 leave wait state
09:11:40:066 rule event /config/localtime: 09:11:39.066 → 09:11:40.066 (1000ms)
09:11:41:066 rule event /config/localtime: 09:11:40.066 → 09:11:41.066 (1000ms)
09:11:41:567 ZDP get active endpoints for 0xCD5F
09:11:41:713 unhandled APS-DATA.confirm id: 197 status 0xE1
09:11:42:066 rule event /config/localtime: 09:11:41.066 → 09:11:42.066 (1000ms)
09:11:42:639 node 0x70B3D52B6008AC57 leave wait state
09:11:43:066 rule event /config/localtime: 09:11:42.066 → 09:11:43.066 (1000ms)
09:11:43:215 Invalid admin password hash
09:11:43:215 API error 101, /, link button not pressed
09:11:44:067 Daylight now: goldenHour1, status: 160, daylight: 1, dark: 0
09:11:44:068 rule event /config/localtime: 09:11:43.066 → 09:11:44.067 (1001ms)
09:11:45:067 rule event /config/localtime: 09:11:44.067 → 09:11:45.067 (1000ms)
09:11:46:066 rule event /config/localtime: 09:11:45.067 → 09:11:46.066 (999ms)
09:11:46:128 unhandled APS-DATA.confirm id: 211 status 0xE1
09:11:46:817 add task 111615 type 21 to 0x914805602BD5B370 cluster 0x0004 req.id 214
09:11:47:050 Erase task req-id: 214, type: 21 zcl seqno: 9 send time 0, profileId: 0x0104, clusterId: 0x0004
09:11:47:067 sql exec SELECT conf FROM zbconf ORDER BY rowid desc limit 1
09:11:47:068 rule event /config/localtime: 09:11:46.066 → 09:11:47.067 (1001ms)
09:11:47:083 max transmit errors for node 0x914805602BD5B370, last seen by neighbors 47182 s
09:11:47:094 max transmit errors for node 0x914805602BD5B370, last seen by neighbors 47182 s
09:11:47:105 max transmit errors for node 0x914805602BD5B370, last seen by neighbors 47182 s
09:11:47:116 max transmit errors for node 0x914805602BD5B370, last seen by neighbors 47182 s
09:11:47:127 max transmit errors for node 0x914805602BD5B370, last seen by neighbors 47182 s
09:11:47:138 max transmit errors for node 0x914805602BD5B370, last seen by neighbors 47182 s
09:11:47:149 max transmit errors for node 0x914805602BD5B370, last seen by neighbors 47182 s
09:11:47:160 max transmit errors for node 0x914805602BD5B370, last seen by neighbors 47182 s
09:11:47:175 max transmit errors for node 0x914805602BD5B370, last seen by neighbors 47182 s
09:11:47:186 max transmit errors for node 0x914805602BD5B370, last seen by neighbors 47182 s
09:11:47:918 0x914805602BD5B370 seems to be a zombie recv errors 15
09:11:47:919 SensorNode id: 15 (Power 15) no longer available
09:11:47:919 SensorNode id: 16 (Consumption 16) no longer available
09:11:48:067 rule event /config/localtime: 09:11:47.067 → 09:11:48.067 (1000ms)
09:11:48:289 Invalid admin password hash
09:11:48:290 API error 101, /, link button not pressed
09:11:49:067 ZDP get active endpoints for 0x15A7
09:11:49:067 rule event /config/localtime: 09:11:48.067 → 09:11:49.066 (999ms)
09:11:50:066 rule event /config/localtime: 09:11:49.066 → 09:11:50.066 (1000ms)
09:11:50:566 ZDP get active endpoints for 0xE897
09:11:50:723 unhandled APS-DATA.confirm id: 240 status 0xE1
09:11:51:066 rule event /config/localtime: 09:11:50.066 → 09:11:51.066 (1000ms)
09:11:52:067 rule event /config/localtime: 09:11:51.066 → 09:11:52.066 (1000ms)
09:11:52:718 poll node f0:d1:b8:00:00:1d:0a:d4-01
09:11:52:718 Poll light node Dimmable light 13 - SZ-Decke
09:11:52:766 0x0000
09:11:52:766 ]
09:11:52:766 add task 111630 type 19 to 0xF0D1B800001D0AD4 cluster 0x0006 req.id 245
09:11:52:767 Poll APS request 245 to 0xF0D1B800001D0AD4 cluster: 0x0006
09:11:52:798 node 0x70B3D52B6009898C leave wait state
09:11:53:067 rule event /config/localtime: 09:11:52.066 → 09:11:53.066 (1000ms)
09:11:53:372 Invalid admin password hash
09:11:53:373 API error 101, /, link button not pressed
09:11:53:957 Poll APS confirm 245 status: 0xE1
09:11:53:957 drop item attr/modelid
09:11:53:957 drop item attr/swversion
09:11:53:958 drop item state/bri
09:11:53:958 Erase task req-id: 245, type: 19 zcl seqno: 23 send time 1, profileId: 0x0104, clusterId: 0x0006
09:11:53:958 unhandled APS-DATA.confirm id: 245 status 0xE1
09:11:54:066 Daylight now: goldenHour1, status: 160, daylight: 1, dark: 0
09:11:54:069 rule event /config/localtime: 09:11:53.066 → 09:11:54.067 (1001ms)
09:11:54:398 node 0xF0D1B800001D0AD4 leave wait state
09:11:55:067 rule event /config/localtime: 09:11:54.067 → 09:11:55.066 (999ms)
09:11:55:092 poll node f0:d1:b8:00:00:1d:10:a7-01
09:11:55:092 Poll light node Dimmable light 3 - Flur Unten
09:11:55:144 0x0000
09:11:55:144 ]
09:11:55:144 add task 111637 type 19 to 0xF0D1B800001D10A7 cluster 0x0006 req.id 252
09:11:55:144 Poll APS request 252 to 0xF0D1B800001D10A7 cluster: 0x0006
09:11:56:067 rule event /config/localtime: 09:11:55.066 → 09:11:56.067 (1001ms)
09:11:56:210 Poll APS confirm 252 status: 0xE1
09:11:56:210 drop item attr/modelid
09:11:56:211 drop item attr/swversion
09:11:56:211 drop item state/bri
09:11:56:211 Erase task req-id: 252, type: 19 zcl seqno: 24 send time 1, profileId: 0x0104, clusterId: 0x0006
09:11:56:211 unhandled APS-DATA.confirm id: 252 status 0xE1
09:11:57:038 node 0xF0D1B800001D10A7 leave wait state
09:11:57:067 rule event /config/localtime: 09:11:56.067 → 09:11:57.066 (999ms)
09:11:57:358 poll node f0:d1:b8:00:00:1d:18:a3-01
09:11:57:359 Poll light node Dimmable light 11 - SZ-Decke
09:11:57:410 0x0000
09:11:57:411 ]
09:11:57:411 add task 111644 type 19 to 0xF0D1B800001D18A3 cluster 0x0006 req.id 3
09:11:57:411 Poll APS request 3 to 0xF0D1B800001D18A3 cluster: 0x0006
09:11:58:067 rule event /config/localtime: 09:11:57.066 → 09:11:58.066 (1000ms)
09:11:58:508 Invalid admin password hash
09:11:58:508 API error 101, /, link button not pressed
09:11:58:511 Poll APS confirm 3 status: 0xE1
09:11:58:512 drop item attr/modelid
09:11:58:512 drop item attr/swversion
09:11:58:512 drop item state/bri
09:11:58:512 Erase task req-id: 3, type: 19 zcl seqno: 25 send time 1, profileId: 0x0104, clusterId: 0x0006
09:11:58:512 unhandled APS-DATA.confirm id: 3 status 0xE1
09:11:59:066 rule event /config/localtime: 09:11:58.066 → 09:11:59.066 (1000ms)
09:12:00:067 rule event /config/localtime: 09:11:59.066 → 09:12:00.067 (1001ms)
09:12:00:398 node 0xF0D1B800001D18A3 leave wait state
09:12:01:067 rule event /config/localtime: 09:12:00.067 → 09:12:01.067 (1000ms)
09:12:01:561 ZDP get active endpoints for 0xCD5F
09:12:01:778 unhandled APS-DATA.confirm id: 14 status 0xE1
09:12:02:066 rule event /config/localtime: 09:12:01.067 → 09:12:02.066 (999ms)
09:12:03:066 rule event /config/localtime: 09:12:02.066 → 09:12:03.066 (1000ms)
09:12:03:118 node 0x70B3D52B6008AC57 leave wait state
09:12:03:606 Invalid admin password hash
09:12:03:607 API error 101, /, link button not pressed
09:12:04:067 Daylight now: goldenHour1, status: 160, daylight: 1, dark: 0
09:12:04:069 rule event /config/localtime: 09:12:03.066 → 09:12:04.067 (1001ms)
09:12:05:066 rule event /config/localtime: 09:12:04.067 → 09:12:05.066 (999ms)
09:12:06:067 rule event /config/localtime: 09:12:05.066 → 09:12:06.067 (1001ms)
09:12:06:878 discovery for zombie 0xF0D1B800001D149A dropped, last try was 90 seconds ago
09:12:07:067 rule event /config/localtime: 09:12:06.067 → 09:12:07.067 (1000ms)
09:12:08:583 unhandled APS-DATA.confirm id: 30 status 0xE1
Here is the current log.
Capture the “first minutes” asap.
Some seconds after deconz reboot … at 9:53 added “routing” to debug view:
09:51:19:066 Wait 0s till query finished
09:51:19:067 rule event /config/localtime: 09:51:18.067 → 09:51:19.066 (999ms)
09:51:19:496 unhandled APS-DATA.confirm id: 53 status 0xE1
09:51:19:951 node 0x70B3D52B6009898C leave wait state
09:51:20:067 Force binding of attribute reporting for node Configuration tool 7
09:51:20:068 rule event /config/localtime: 09:51:19.066 → 09:51:20.067 (1001ms)
09:51:20:556 unhandled APS-DATA.confirm id: 55 status 0xE1
09:51:21:067 rule event /config/localtime: 09:51:20.067 → 09:51:21.067 (1000ms)
09:51:21:624 unhandled APS-DATA.confirm id: 60 status 0xE1
09:51:22:066 Wait 0s till query finished
09:51:22:067 rule event /config/localtime: 09:51:21.067 → 09:51:22.066 (999ms)
09:51:22:695 unhandled APS-DATA.confirm id: 62 status 0xE1
09:51:23:066 rule event /config/localtime: 09:51:22.066 → 09:51:23.066 (1000ms)
09:51:23:763 unhandled APS-DATA.confirm id: 64 status 0xE1
09:51:23:870 node 0x0C4314FFFE52AE25 leave wait state
09:51:24:067 rule event /config/localtime: 09:51:23.066 → 09:51:24.066 (1000ms)
09:51:24:826 unhandled APS-DATA.confirm id: 69 status 0xE1
… snip …
09:51:47:067 rule event /config/localtime: 09:51:46.067 → 09:51:47.066 (999ms)
09:51:47:390 node 0x0C4314FFFE52AE25 leave wait state
09:51:48:066 Daylight now: goldenHour1, status: 160, daylight: 1, dark: 0
09:51:48:069 rule event /config/localtime: 09:51:47.066 → 09:51:48.067 (1001ms)
09:51:49:067 rule event /config/localtime: 09:51:48.067 → 09:51:49.066 (999ms)
09:51:50:067 rule event /config/localtime: 09:51:49.066 → 09:51:50.066 (1000ms)
09:51:51:067 rule event /config/localtime: 09:51:50.066 → 09:51:51.067 (1001ms)
09:51:52:066 rule event /config/localtime: 09:51:51.067 → 09:51:52.066 (999ms)
09:51:53:066 rule event /config/localtime: 09:51:52.066 → 09:51:53.066 (1000ms)
09:51:54:066 rule event /config/localtime: 09:51:53.066 → 09:51:54.066 (1000ms)
09:51:55:066 rule event /config/localtime: 09:51:54.066 → 09:51:55.066 (1000ms)
09:51:56:066 rule event /config/localtime: 09:51:55.066 → 09:51:56.066 (1000ms)
09:51:57:066 rule event /config/localtime: 09:51:56.066 → 09:51:57.066 (1000ms)
09:51:57:089 [Master] read param with arg 0x19
09:51:58:066 DB save zll database items 0x00000087
09:51:58:067 DB sql exec REPLACE INTO auth (apikey, devicetype, createdate, lastusedate, useragent) VALUES (‘BB416DDF72’, ‘fhem’, ‘2026-06-02T20:08:18’, ‘2026-08-23T07:51:03’, ‘fhem’)
09:51:58:067 DB sql exec REPLACE INTO auth (apikey, devicetype, createdate, lastusedate, useragent) VALUES (‘EBDCED5DDA’, ‘Phoscon#B1696x807’, ‘2026-08-23T07:49:09’, ‘2026-08-23T07:51:55’, ‘Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:154.0) Gecko/20100101 Firefox/154.0’)
09:51:58:068 DB sql exec REPLACE INTO nodes (id, state, mac, name, groups, endpoint, modelid, manufacturername, swbuildid, ritems) VALUES (‘8’, ‘normal’, ‘70:b3:d5:2b:60:09:89:8c-01’, ‘SmartPlug Z8 - DampfRadio’, ‘1’, ‘1’, ‘TS011F’, ‘_TZ3000_okaz9tjs’, ‘1.3.0’, ‘{“attr/id”:“8”,“attr/lastannounced”:“2026-02-28T15:53:05Z”,“attr/lastseen”:“2026-08-21T08:24Z”,“attr/manufacturername”:“_TZ3000_okaz9tjs”,“attr/modelid”:“TS011F”,“attr/name”:“SmartPlug Z8 - DampfRadio”,“attr/swversion”:“1.3.0”,“attr/type”:“Smart plug”,“attr/uniqueid”:“70:b3:d5:2b:60:09:89:8c-01”,“state/alert”:“none”,“state/on”:true,“state/reachable”:false}’)
09:51:58:069 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES (‘0xFFF0’, ‘All’, ‘normal’, ‘’, ‘’, ‘’, ‘false’, ‘LightGroup’, ‘Other’, ‘’)
09:51:58:069 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES (‘0x0001’, ‘Phoscon_All_Off’, ‘normal’, ‘’, ‘’, ‘’, ‘true’, ‘LightGroup’, ‘Other’, ‘’)
09:51:58:070 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES (‘0x0002’, ‘Alle’, ‘normal’, ‘’, ‘’, ‘’, ‘false’, ‘LightGroup’, ‘Other’, ‘’)
09:51:58:070 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES (‘0x0003’, ‘LAB - KellerLicht’, ‘normal’, ‘’, ‘’, ‘’, ‘false’, ‘LightGroup’, ‘Other’, ‘’)
09:51:58:070 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES (‘0x0004’, ‘SZ-Decke’, ‘normal’, ‘’, ‘’, ‘’, ‘false’, ‘LightGroup’, ‘Other’, ‘’)
09:51:58:071 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘5’, ‘Offset Ref P-SR’, ‘CLIPDaylightOffset’, ‘DLOFFSET10012’, ‘Phoscon’, ‘2A:C0:B4:B9-8361-7F4B-B5DA-ED:6B:01:CE:30:D5’, ‘1.0’, ‘{“lastupdated”:“2026-08-23T07:50:58.049”,“localtime”:“2026-08-23T06:04:48”}’, ‘{“mode”:“sunrise”,“offset”:0,“on”:true,“reachable”:true}’, ‘’, ‘normal’, ‘1’, ‘’, ‘’)
09:51:58:071 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘6’, ‘Offset Ref P2100’, ‘CLIPDaylightOffset’, ‘DLOFFSET122’, ‘Phoscon’, ‘EA:16:E0:31-81FA-71E0-B655-9F:7E:F1:9E:E1:DA’, ‘1.0’, ‘{“lastupdated”:“2026-08-23T07:51:28.066”,“localtime”:“2026-08-23T16:23:02”}’, ‘{“mode”:“sunset”,“offset”:-236,“on”:true,“reachable”:true}’, ‘’, ‘normal’, ‘1’, ‘’, ‘’)
09:51:58:072 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘7’, ‘Offset Ref P101’, ‘CLIPDaylightOffset’, ‘DLOFFSET1021’, ‘Phoscon’, ‘37:68:FF:02-2792-1860-AE02-96:96:84:83:81:7D’, ‘1.0’, ‘{“lastupdated”:“2026-08-23T07:51:08.067”,“localtime”:“2026-08-24T01:42:02”}’, ‘{“mode”:“sunset”,“offset”:323,“on”:true,“reachable”:true}’, ‘’, ‘normal’, ‘1’, ‘’, ‘’)
09:51:58:072 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘4’, ‘Offset Ref P-SS’, ‘CLIPDaylightOffset’, ‘DLOFFSET211’, ‘Phoscon’, ‘DC:9B:2D:CB-F110-EEFB-88ED-69:00:AF:2D:F4:27’, ‘1.0’, ‘{“lastupdated”:“2026-08-23T07:51:38.067”,“localtime”:“2026-08-23T20:19:02”}’, ‘{“mode”:“sunset”,“offset”:0,“on”:true,“reachable”:true}’, ‘’, ‘normal’, ‘1’, ‘’, ‘’)
09:51:58:073 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘1’, ‘Daylight’, ‘Daylight’, ‘PHDL00’, ‘Philips’, ‘00:21:2e:ff:ff:08:28:64-01’, ‘1.0’, ‘{“dark”:false,“daylight”:true,“lastupdated”:“2026-08-23T07:50:58.049”,“status”:160,“sunrise”:“2026-08-23T04:04:48”,“sunset”:“2026-08-23T18:19:02”}’, ‘{“configured”:true,“lat”:“52.398800”,“long”:“13.072700”,“on”:true,“sunriseoffset”:30,“sunsetoffset”:-30}’, ‘’, ‘normal’, ‘1’, ‘’, ‘’)
09:51:58:074 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘25’, ‘ZG-204Z-Schubfach’, ‘ZHAPresence’, ‘ZG-204Z’, ‘HOBEIAN’, ‘a4:c1:38:51:c9:5b:b8:d7-01-0500’, ‘2.1.7’, ‘{“lastupdated”:“2026-08-17T16:26:33.345”,“lowbattery”:false,“presence”:false}’, ‘{“battery”:90,“duration”:30,“enrolled”:1,“on”:true,“pending”:0,“reachable”:false,“sensitivity”:2}’, ‘{“d”:1026,“ep”:1,“in”:[0,1,1280,61184],“p”:260}’, ‘normal’, ‘1’, ‘2026-08-21T02:36Z’, ‘2026-08-05T17:57:01Z’)
09:51:58:075 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘2’, ‘TH01 (1)’, ‘ZHATemperature’, ‘TH01’, ‘Zbeacon’, ‘a4:c1:38:d1:95:3c:9c:da-01-0402’, ‘2.1.3’, ‘{“lastupdated”:“2026-08-21T08:11:48.288”,“temperature”:2002}’, ‘{“battery”:20,“offset”:0,“on”:true,“reachable”:false}’, ‘’, ‘normal’, ‘1’, ‘2026-08-21T21:03Z’, ‘2026-08-17T19:07:12Z’)
09:51:58:076 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘3’, ‘TH01 (1)’, ‘ZHAHumidity’, ‘TH01’, ‘Zbeacon’, ‘a4:c1:38:d1:95:3c:9c:da-01-0405’, ‘2.1.3’, ‘{“humidity”:7167,“lastupdated”:“2026-08-21T21:03:18.824”}’, ‘{“battery”:20,“offset”:0,“on”:true,“reachable”:false}’, ‘’, ‘normal’, ‘1’, ‘2026-08-21T21:03Z’, ‘2026-08-17T19:07:12Z’)
09:51:58:076 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘11’, ‘TH01 (2)’, ‘ZHATemperature’, ‘TH01’, ‘Zbeacon’, ‘a4:c1:38:39:09:dd:21:26-01-0402’, ‘2.1.3’, ‘{“lastupdated”:“2026-08-21T08:22:18.421”,“temperature”:2044}’, ‘{“battery”:9,“offset”:0,“on”:true,“reachable”:false}’, ‘’, ‘normal’, ‘1’, ‘2026-08-22T10:31Z’, ‘2026-08-22T10:31:52Z’)
09:51:58:077 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘12’, ‘Humidity 12’, ‘ZHAHumidity’, ‘TH01’, ‘Zbeacon’, ‘a4:c1:38:39:09:dd:21:26-01-0405’, ‘2.1.3’, ‘{“humidity”:5790,“lastupdated”:“2026-08-21T08:22:18.567”}’, ‘{“battery”:9,“offset”:0,“on”:true,“reachable”:false}’, ‘’, ‘normal’, ‘1’, ‘2026-08-22T10:31Z’, ‘2026-08-22T10:31:52Z’)
09:51:58:078 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘10’, ‘ZG-204Z-KellerLicht’, ‘ZHAPresence’, ‘ZG-204Z’, ‘HOBEIAN’, ‘a4:c1:38:18:cb:c2:40:46-01-0500’, ‘2.1.3’, ‘{“lastupdated”:“2026-08-21T06:44:39.951”,“lowbattery”:false,“presence”:false}’, ‘{“battery”:100,“duration”:30,“enrolled”:0,“on”:true,“pending”:0,“reachable”:false,“sensitivity”:2}’, ‘{“d”:1026,“ep”:1,“in”:[0,1,1280,61184],“p”:260}’, ‘normal’, ‘1’, ‘2026-08-22T16:21Z’, ‘2026-08-22T16:21:19Z’)
09:51:58:078 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘8’, ‘Consumption 8’, ‘ZHAConsumption’, ‘TS011F’, ‘_TZ3000_5f43h46b’, ‘0c:43:14:ff:fe:52:ae:25-01-0702’, ‘1.2.4’, ‘{“consumption”:30,“lastupdated”:“2026-08-21T13:29:44.158”}’, ‘{“on”:true,“reachable”:false}’, ‘’, ‘normal’, ‘1’, ‘2026-08-22T15:33Z’, ‘2026-01-15T18:43:58Z’)
09:51:58:079 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘9’, ‘Power 9’, ‘ZHAPower’, ‘TS011F’, ‘_TZ3000_5f43h46b’, ‘0c:43:14:ff:fe:52:ae:25-01-0b04’, ‘1.2.4’, ‘{“current”:0,“lastupdated”:“2026-08-21T15:59:11.838”,“power”:0,“voltage”:232}’, ‘{“on”:true,“reachable”:false}’, ‘’, ‘normal’, ‘1’, ‘2026-08-22T15:33Z’, ‘2026-01-15T18:43:58Z’)
09:51:58:080 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘17’, ‘Power 17’, ‘ZHAPower’, ‘TS011F’, ‘_TZ3000_okaz9tjs’, ‘70:b3:d5:2b:60:08:ac:57-01-0b04’, ‘1.3.0’, ‘{“current”:0,“lastupdated”:“2026-08-21T21:03:17.705”,“power”:0,“voltage”:231}’, ‘{“on”:true,“reachable”:false}’, ‘{“d”:81,“ep”:1,“in”:[0,2820],“p”:260}’, ‘normal’, ‘1’, ‘2026-08-21T21:02Z’, ‘2026-02-28T15:53:30Z’)
09:51:58:081 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘18’, ‘Consumption 18’, ‘ZHAConsumption’, ‘TS011F’, ‘_TZ3000_okaz9tjs’, ‘70:b3:d5:2b:60:08:ac:57-01-0702’, ‘1.3.0’, ‘{“consumption”:60,“lastupdated”:“2026-08-21T08:17:49.618”}’, ‘{“on”:true,“reachable”:false}’, ‘{“d”:81,“ep”:1,“in”:[0,1794],“p”:260}’, ‘normal’, ‘1’, ‘2026-08-21T21:02Z’, ‘2026-02-28T15:53:30Z’)
09:51:58:081 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘13’, ‘Power 13’, ‘ZHAPower’, ‘TS011F’, ‘_TZ3000_okaz9tjs’, ‘70:b3:d5:2b:60:09:89:8c-01-0b04’, ‘1.3.0’, ‘{“current”:0,“lastupdated”:“2026-08-21T08:18:53.395”,“power”:0,“voltage”:228}’, ‘{“on”:true,“reachable”:false}’, ‘{“d”:81,“ep”:1,“in”:[0,2820],“p”:260}’, ‘normal’, ‘1’, ‘2026-08-21T08:24Z’, ‘2026-02-28T15:53:05Z’)
09:51:58:082 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘14’, ‘Consumption 14’, ‘ZHAConsumption’, ‘TS011F’, ‘_TZ3000_okaz9tjs’, ‘70:b3:d5:2b:60:09:89:8c-01-0702’, ‘1.3.0’, ‘{“consumption”:4430,“lastupdated”:“2026-08-21T08:21:46.403”}’, ‘{“on”:true,“reachable”:false}’, ‘{“d”:81,“ep”:1,“in”:[0,1794],“p”:260}’, ‘normal’, ‘1’, ‘2026-08-21T08:24Z’, ‘2026-02-28T15:53:05Z’)
09:51:58:092 DB saved in 25 ms
09:51:58:093 Daylight now: goldenHour1, status: 160, daylight: 1, dark: 0
09:51:58:109 rule event /config/localtime: 09:51:57.066 → 09:51:58.093 (1027ms)
09:51:59:066 rule event /config/localtime: 09:51:58.093 → 09:51:59.066 (973ms)
09:52:00:066 rule event /config/localtime: 09:51:59.066 → 09:52:00.066 (1000ms)
… snip …
09:52:21:066 rule event /config/localtime: 09:52:20.066 → 09:52:21.066 (1000ms)
09:52:21:986 unhandled APS-DATA.confirm id: 174 status 0xE1
09:52:22:067 rule event /config/localtime: 09:52:21.066 → 09:52:22.066 (1000ms)
09:52:23:067 sql exec SELECT conf FROM zbconf ORDER BY rowid desc limit 1
09:52:23:067 poll node f0:d1:b8:00:00:1d:10:a7-01
09:52:23:068 Poll light node Dimmable light 3 - Flur Unten
09:52:23:068 create binding for attribute reporting of cluster 0x0006
09:52:23:068 queue binding task for 0xF0D1B800001D10A7, cluster 0x0006
09:52:23:068 create binding for attribute reporting of cluster 0x0008
09:52:23:068 queue binding task for 0xF0D1B800001D10A7, cluster 0x0008
09:52:23:069 Force binding of attribute reporting for node Dimmable light 3 - Flur Unten
09:52:23:074 rule event /config/localtime: 09:52:22.066 → 09:52:23.067 (1001ms)
09:52:23:075 node 0xF0D1B800001D06B1 leave wait state
09:52:23:167 0x0000
09:52:23:167 ]
09:52:23:167 add task 141 type 19 to 0xF0D1B800001D10A7 cluster 0x0006 req.id 179
09:52:23:167 Poll APS request 179 to 0xF0D1B800001D10A7 cluster: 0x0006
09:52:24:067 rule event /config/localtime: 09:52:23.067 → 09:52:24.066 (999ms)
09:52:24:233 Poll APS confirm 179 status: 0xE1
09:52:24:234 drop item attr/modelid
09:52:24:234 drop item attr/swversion
09:52:24:234 drop item state/bri
09:52:24:234 Erase task req-id: 179, type: 19 zcl seqno: 15 send time 1, profileId: 0x0104, clusterId: 0x0006
09:52:24:234 unhandled APS-DATA.confirm id: 179 status 0xE1
09:52:24:830 node 0xF0D1B800001D10A7 leave wait state
09:52:25:067 rule event /config/localtime: 09:52:24.066 → 09:52:25.067 (1001ms)
09:52:26:067 rule event /config/localtime: 09:52:25.067 → 09:52:26.066 (999ms)
09:52:27:066 rule event /config/localtime: 09:52:26.066 → 09:52:27.066 (1000ms)
09:52:28:066 Daylight now: goldenHour1, status: 160, daylight: 1, dark: 0
09:52:28:068 rule event /config/localtime: 09:52:27.066 → 09:52:28.066 (1000ms)
09:52:29:067 rule event /config/localtime: 09:52:28.066 → 09:52:29.067 (1001ms)
09:52:30:067 rule event /config/localtime: 09:52:29.067 → 09:52:30.067 (1000ms)
09:52:31:066 rule event /config/localtime: 09:52:30.067 → 09:52:31.066 (999ms)
09:52:32:067 rule event /config/localtime: 09:52:31.066 → 09:52:32.067 (1001ms)
09:52:33:066 rule event /config/localtime: 09:52:32.067 → 09:52:33.066 (999ms)
09:52:34:067 rule event /config/localtime: 09:52:33.066 → 09:52:34.067 (1001ms)
09:52:35:067 rule event /config/localtime: 09:52:34.067 → 09:52:35.067 (1000ms)
09:52:36:067 rule event /config/localtime: 09:52:35.067 → 09:52:36.066 (999ms)
09:52:37:066 rule event /config/localtime: 09:52:36.066 → 09:52:37.066 (1000ms)
09:52:37:268 poll node f0:d1:b8:00:00:1d:10:a7-01
09:52:37:268 Poll light node Dimmable light 3 - Flur Unten
09:52:37:316 0x0000
09:52:37:316 ]
09:52:37:316 add task 163 type 19 to 0xF0D1B800001D10A7 cluster 0x0006 req.id 205
09:52:37:317 Poll APS request 205 to 0xF0D1B800001D10A7 cluster: 0x0006
09:52:38:066 Daylight now: goldenHour1, status: 160, daylight: 1, dark: 0
09:52:38:068 rule event /config/localtime: 09:52:37.066 → 09:52:38.067 (1001ms)
09:52:38:424 Poll APS confirm 205 status: 0xE1
09:52:38:424 drop item attr/modelid
09:52:38:424 drop item attr/swversion
09:52:38:425 drop item state/bri
09:52:38:425 Erase task req-id: 205, type: 19 zcl seqno: 16 send time 1, profileId: 0x0104, clusterId: 0x0006
09:52:38:425 unhandled APS-DATA.confirm id: 205 status 0xE1
09:52:39:066 rule event /config/localtime: 09:52:38.067 → 09:52:39.066 (999ms)
09:52:40:067 rule event /config/localtime: 09:52:39.066 → 09:52:40.066 (1000ms)
09:52:41:067 rule event /config/localtime: 09:52:40.066 → 09:52:41.066 (1000ms)
09:52:42:066 rule event /config/localtime: 09:52:41.066 → 09:52:42.066 (1000ms)
09:52:43:066 rule event /config/localtime: 09:52:42.066 → 09:52:43.066 (1000ms)
09:52:44:066 rule event /config/localtime: 09:52:43.066 → 09:52:44.066 (1000ms)
09:52:45:066 binding/unbinding timeout srcAddr: 0xF0D1B800001D10A7, retry
09:52:45:068 rule event /config/localtime: 09:52:44.066 → 09:52:45.066 (1000ms)
09:52:46:067 rule event /config/localtime: 09:52:45.066 → 09:52:46.066 (1000ms)
09:52:47:067 binding/unbinding timeout srcAddr: 0xF0D1B800001D10A7, retry
09:52:47:069 rule event /config/localtime: 09:52:46.066 → 09:52:47.067 (1001ms)
09:52:48:067 Daylight now: goldenHour1, status: 160, daylight: 1, dark: 0
09:52:48:069 rule event /config/localtime: 09:52:47.067 → 09:52:48.067 (1000ms)
09:52:48:130 unhandled APS-DATA.confirm id: 228 status 0xE1
09:52:49:067 rule event /config/localtime: 09:52:48.067 → 09:52:49.067 (1000ms)
09:52:50:067 rule event /config/localtime: 09:52:49.067 → 09:52:50.066 (999ms)
09:52:50:346 max transmit errors for node 0x0C4314FFFE52AE25, last seen by neighbors 11 s
09:52:50:357 max transmit errors for node 0x0C4314FFFE52AE25, last seen by neighbors 11 s
09:52:50:380 max transmit errors for node 0x0C4314FFFE52AE25, last seen by neighbors 11 s
09:52:50:391 max transmit errors for node 0x0C4314FFFE52AE25, last seen by neighbors 11 s
09:52:50:402 max transmit errors for node 0x0C4314FFFE52AE25, last seen by neighbors 11 s
09:52:50:413 max transmit errors for node 0x0C4314FFFE52AE25, last seen by neighbors 11 s
09:52:50:424 max transmit errors for node 0x0C4314FFFE52AE25, last seen by neighbors 11 s
09:52:50:439 max transmit errors for node 0x0C4314FFFE52AE25, last seen by neighbors 11 s
09:52:51:067 rule event /config/localtime: 09:52:50.066 → 09:52:51.066 (1000ms)
09:52:52:067 rule event /config/localtime: 09:52:51.066 → 09:52:52.066 (1000ms)
09:52:53:067 rule event /config/localtime: 09:52:52.066 → 09:52:53.067 (1001ms)
09:52:54:066 rule event /config/localtime: 09:52:53.067 → 09:52:54.066 (999ms)
09:52:55:066 rule event /config/localtime: 09:52:54.066 → 09:52:55.066 (1000ms)
09:52:55:710 0x0C4314FFFE52AE25 seems to be a zombie recv errors 13
09:52:55:711 SensorNode id: 8 (Consumption 8) available
09:52:55:711 SensorNode id: 9 (Power 9) available
09:52:56:067 rule event /config/localtime: 09:52:55.066 → 09:52:56.066 (1000ms)
09:52:57:066 rule event /config/localtime: 09:52:56.066 → 09:52:57.066 (1000ms)
09:52:57:345 poll node f0:d1:b8:00:00:1d:10:a7-01
09:52:57:346 Poll light node Dimmable light 3 - Flur Unten
09:52:57:397 0x0000
09:52:57:397 ]
09:52:57:398 add task 194 type 19 to 0xF0D1B800001D10A7 cluster 0x0006 req.id 1
09:52:57:398 Poll APS request 1 to 0xF0D1B800001D10A7 cluster: 0x0006
09:52:58:066 Daylight now: goldenHour1, status: 160, daylight: 1, dark: 0
09:52:58:069 rule event /config/localtime: 09:52:57.066 → 09:52:58.067 (1001ms)
09:52:58:552 Poll APS confirm 1 status: 0xE1
09:52:58:552 drop item attr/modelid
09:52:58:552 drop item attr/swversion
09:52:58:553 drop item state/bri
09:52:58:553 Erase task req-id: 1, type: 19 zcl seqno: 30 send time 1, profileId: 0x0104, clusterId: 0x0006
09:52:58:553 unhandled APS-DATA.confirm id: 1 status 0xE1
09:52:59:067 rule event /config/localtime: 09:52:58.067 → 09:52:59.066 (999ms)
09:53:00:067 rule event /config/localtime: 09:52:59.066 → 09:53:00.066 (1000ms)
09:53:00:097 unhandled APS-DATA.confirm id: 3 status 0xE1
09:53:01:066 add task 201 type 21 to 0xF0D1B800001D10A7 cluster 0x0004 req.id 12
09:53:01:069 rule event /config/localtime: 09:53:00.066 → 09:53:01.066 (1000ms)
09:53:02:067 rule event /config/localtime: 09:53:01.066 → 09:53:02.066 (1000ms)
09:53:02:152 Erase task req-id: 12, type: 21 zcl seqno: 31 send time 1, profileId: 0x0104, clusterId: 0x0004
09:53:02:153 unhandled APS-DATA.confirm id: 12 status 0xE1
09:53:02:510 node 0xF0D1B800001D10A7 leave wait state
09:53:03:067 rule event /config/localtime: 09:53:02.066 → 09:53:03.067 (1001ms)
09:53:04:067 rule event /config/localtime: 09:53:03.067 → 09:53:04.067 (1000ms)
09:53:05:067 rule event /config/localtime: 09:53:04.067 → 09:53:05.067 (1000ms)
09:53:05:551 discovery for zombie 0x0C4314FFFE52AE25 dropped, last try was 75 seconds ago
09:53:06:067 rule event /config/localtime: 09:53:05.067 → 09:53:06.066 (999ms)
09:53:07:067 giveup binding srcAddr: 0xF0D1B800001D10A7
09:53:07:069 rule event /config/localtime: 09:53:06.066 → 09:53:07.066 (1000ms)
09:53:08:067 Daylight now: goldenHour1, status: 160, daylight: 1, dark: 0
09:53:08:069 rule event /config/localtime: 09:53:07.066 → 09:53:08.067 (1001ms)
09:53:09:067 rule event /config/localtime: 09:53:08.067 → 09:53:09.067 (1000ms)
09:53:10:066 giveup binding srcAddr: 0xF0D1B800001D10A7
09:53:10:068 rule event /config/localtime: 09:53:09.067 → 09:53:10.066 (999ms)
09:53:11:066 rule event /config/localtime: 09:53:10.066 → 09:53:11.066 (1000ms)
09:53:12:067 rule event /config/localtime: 09:53:11.066 → 09:53:12.066 (1000ms)
09:53:13:066 rule event /config/localtime: 09:53:12.066 → 09:53:13.066 (1000ms)
09:53:14:067 rule event /config/localtime: 09:53:13.066 → 09:53:14.066 (1000ms)
09:53:14:742 poll node f0:d1:b8:00:00:1d:10:a7-01
09:53:14:742 Poll light node Dimmable light 3 - Flur Unten
09:53:14:793 0x0000
09:53:14:794 ]
09:53:14:794 add task 222 type 19 to 0xF0D1B800001D10A7 cluster 0x0006 req.id 37
09:53:14:794 Poll APS request 37 to 0xF0D1B800001D10A7 cluster: 0x0006
09:53:15:066 rule event /config/localtime: 09:53:14.066 → 09:53:15.066 (1000ms)
09:53:15:931 Poll APS confirm 37 status: 0xE1
09:53:15:931 drop item attr/modelid
09:53:15:931 drop item attr/swversion
09:53:15:932 drop item state/bri
09:53:15:932 Erase task req-id: 37, type: 19 zcl seqno: 32 send time 1, profileId: 0x0104, clusterId: 0x0006
09:53:15:932 unhandled APS-DATA.confirm id: 37 status 0xE1
09:53:16:067 rule event /config/localtime: 09:53:15.066 → 09:53:16.066 (1000ms)
09:53:16:111 discovery for zombie 0x0C4314FFFE52AE25 dropped, last try was 85 seconds ago
09:53:17:066 DB save zll database items 0x00000083
09:53:17:067 DB sql exec REPLACE INTO nodes (id, state, mac, name, groups, endpoint, modelid, manufacturername, swbuildid, ritems) VALUES (‘3’, ‘normal’, ‘f0:d1:b8:00:00:1d:10:a7-01’, ‘Dimmable light 3 - Flur Unten’, ‘65520,1,2’, ‘1’, ‘LEDVANCE DIM’, ‘LEDVANCE’, ‘0x03177310’, ‘{“attr/id”:“3”,“attr/lastannounced”:“2026-08-23T07:52:17Z”,“attr/lastseen”:“2026-08-23T07:52Z”,“attr/manufacturername”:“LEDVANCE”,“attr/modelid”:“LEDVANCE DIM”,“attr/name”:“Dimmable light 3 - Flur Unten”,“attr/swversion”:“0x03177310”,“attr/type”:“Dimmable light”,“attr/uniqueid”:“f0:d1:b8:00:00:1d:10:a7-01”,“state/alert”:“none”,“state/bri”:254,“state/on”:true,“state/reachable”:true}’)
09:53:17:068 DB sql exec REPLACE INTO nodes (id, state, mac, name, groups, endpoint, modelid, manufacturername, swbuildid, ritems) VALUES (‘6’, ‘normal’, ‘0c:43:14:ff:fe:52:ae:25-01’, ‘On/Off plug-in unit 6’, ‘2,1’, ‘1’, ‘TS011F’, ‘_TZ3000_5f43h46b’, ‘1.2.4’, ‘{“attr/id”:“6”,“attr/lastannounced”:“2026-01-15T18:43:58Z”,“attr/lastseen”:“2026-08-22T15:33Z”,“attr/manufacturername”:“_TZ3000_5f43h46b”,“attr/modelid”:“TS011F”,“attr/name”:“On/Off plug-in unit 6”,“attr/swversion”:“1.2.4”,“attr/type”:“On/Off plug-in unit”,“attr/uniqueid”:“0c:43:14:ff:fe:52:ae:25-01”,“state/alert”:“none”,“state/on”:true,“state/reachable”:false}’)
09:53:17:069 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES (‘0xFFF0’, ‘All’, ‘normal’, ‘’, ‘’, ‘’, ‘false’, ‘LightGroup’, ‘Other’, ‘’)
09:53:17:069 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES (‘0x0001’, ‘Phoscon_All_Off’, ‘normal’, ‘’, ‘’, ‘’, ‘true’, ‘LightGroup’, ‘Other’, ‘’)
09:53:17:070 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES (‘0x0002’, ‘Alle’, ‘normal’, ‘’, ‘’, ‘’, ‘false’, ‘LightGroup’, ‘Other’, ‘’)
09:53:17:070 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES (‘0x0003’, ‘LAB - KellerLicht’, ‘normal’, ‘’, ‘’, ‘’, ‘false’, ‘LightGroup’, ‘Other’, ‘’)
09:53:17:070 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES (‘0x0004’, ‘SZ-Decke’, ‘normal’, ‘’, ‘’, ‘’, ‘false’, ‘LightGroup’, ‘Other’, ‘’)
09:53:17:071 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘8’, ‘Consumption 8’, ‘ZHAConsumption’, ‘TS011F’, ‘_TZ3000_5f43h46b’, ‘0c:43:14:ff:fe:52:ae:25-01-0702’, ‘1.2.4’, ‘{“consumption”:30,“lastupdated”:“2026-08-21T13:29:44.158”}’, ‘{“on”:true,“reachable”:true}’, ‘’, ‘normal’, ‘1’, ‘2026-08-22T15:33Z’, ‘2026-01-15T18:43:58Z’)
09:53:17:072 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘9’, ‘Power 9’, ‘ZHAPower’, ‘TS011F’, ‘_TZ3000_5f43h46b’, ‘0c:43:14:ff:fe:52:ae:25-01-0b04’, ‘1.2.4’, ‘{“current”:0,“lastupdated”:“2026-08-21T15:59:11.838”,“power”:0,“voltage”:232}’, ‘{“on”:true,“reachable”:true}’, ‘’, ‘normal’, ‘1’, ‘2026-08-22T15:33Z’, ‘2026-01-15T18:43:58Z’)
09:53:17:125 DB saved in 58 ms
09:53:17:136 rule event /config/localtime: 09:53:16.066 → 09:53:17.125 (1059ms)
09:53:18:066 Daylight now: goldenHour1, status: 160, daylight: 1, dark: 0
09:53:18:351 node 0xF0D1B800001D10A7 leave wait state
09:53:19:067 rule event /config/localtime: 09:53:17.125 → 09:53:19.066 (1941ms)
09:53:20:067 rule event /config/localtime: 09:53:19.066 → 09:53:20.067 (1001ms)
09:53:21:067 rule event /config/localtime: 09:53:20.067 → 09:53:21.067 (1000ms)
09:53:22:067 rule event /config/localtime: 09:53:21.067 → 09:53:22.067 (1000ms)
09:53:22:271 node 0x70B3D52B6008AC57 leave wait state
09:53:23:067 rule event /config/localtime: 09:53:22.067 → 09:53:23.066 (999ms)
09:53:24:067 rule event /config/localtime: 09:53:23.066 → 09:53:24.066 (1000ms)
09:53:25:067 rule event /config/localtime: 09:53:24.066 → 09:53:25.067 (1001ms)
09:53:26:066 sql exec SELECT conf FROM zbconf ORDER BY rowid desc limit 1
09:53:26:068 rule event /config/localtime: 09:53:25.067 → 09:53:26.066 (999ms)
09:53:26:670 discovery for zombie 0x0C4314FFFE52AE25 dropped, last try was 96 seconds ago
09:53:27:067 rule event /config/localtime: 09:53:26.066 → 09:53:27.067 (1001ms)
09:53:28:066 Daylight now: goldenHour1, status: 160, daylight: 1, dark: 0
09:53:28:069 rule event /config/localtime: 09:53:27.067 → 09:53:28.067 (1000ms)
09:53:29:067 rule event /config/localtime: 09:53:28.067 → 09:53:29.066 (999ms)
09:53:30:066 rule event /config/localtime: 09:53:29.066 → 09:53:30.066 (1000ms)
09:53:31:066 rule event /config/localtime: 09:53:30.066 → 09:53:31.066 (1000ms)
09:53:32:066 rule event /config/localtime: 09:53:31.066 → 09:53:32.066 (1000ms)
09:53:32:219 poll node f0:d1:b8:00:00:1d:10:a7-01
09:53:32:219 Poll light node Dimmable light 3 - Flur Unten
09:53:32:268 0x0000
09:53:32:268 ]
09:53:32:268 add task 249 type 19 to 0xF0D1B800001D10A7 cluster 0x0006 req.id 66
09:53:32:268 Poll APS request 66 to 0xF0D1B800001D10A7 cluster: 0x0006
09:53:33:066 rule event /config/localtime: 09:53:32.066 → 09:53:33.066 (1000ms)
09:53:33:442 Poll APS confirm 66 status: 0xE1
09:53:33:442 drop item attr/modelid
09:53:33:442 drop item attr/swversion
09:53:33:442 drop item state/bri
09:53:33:443 Erase task req-id: 66, type: 19 zcl seqno: 33 send time 1, profileId: 0x0104, clusterId: 0x0006
09:53:33:443 unhandled APS-DATA.confirm id: 66 status 0xE1
09:53:34:066 rule event /config/localtime: 09:53:33.066 → 09:53:34.066 (1000ms)
09:53:34:990 node 0xF0D1B800001D10A7 leave wait state
09:53:35:067 rule event /config/localtime: 09:53:34.066 → 09:53:35.067 (1001ms)
09:53:36:066 rule event /config/localtime: 09:53:35.067 → 09:53:36.066 (999ms)
09:53:37:067 rule event /config/localtime: 09:53:36.066 → 09:53:37.067 (1001ms)
09:53:38:067 Daylight now: goldenHour1, status: 160, daylight: 1, dark: 0
09:53:38:069 rule event /config/localtime: 09:53:37.067 → 09:53:38.067 (1000ms)
09:53:39:066 rule event /config/localtime: 09:53:38.067 → 09:53:39.066 (999ms)
09:53:40:067 rule event /config/localtime: 09:53:39.066 → 09:53:40.066 (1000ms)
09:53:41:066 rule event /config/localtime: 09:53:40.066 → 09:53:41.066 (1000ms)
09:53:42:066 rule event /config/localtime: 09:53:41.066 → 09:53:42.066 (1000ms)
09:53:43:066 rule event /config/localtime: 09:53:42.066 → 09:53:43.066 (1000ms)
09:53:44:066 rule event /config/localtime: 09:53:43.066 → 09:53:44.066 (1000ms)
For thoses one you have an application that is trying to get access to the API, but bad procedure. You need to be connected to phoscon and “authenticate” the application.
This one is zigbee error, if you can found the device according the mac adress, just remove it for your tests.
It’s yours plugs ? try a power cycle.
BTW why you have so much
It’s something normal ?
i have 6 power plugs some light bulbs and some motion sensors. Need the plugs for switching lights, old radio, raspiradio … and as zigbee-repeater/router.
Currently only one is reachable. (my current problem) all others produce these errors.
The tests killed my FHEM-connection. But this isn’t my current problem.
Now started rebuilding the ZigBee Cloud.
After resetting gateway and importing different backups the problem keeps existing.
After resetting the gateway and rebind some devices, it works again.
Looks as the ZigBee Cloud was collapsed. But nothing has changed for weeks.
Thanks for your support,
Dirk
By curiosity what was the plugs that have disconnected ?
I see some 0xE1 which means interference. Do you use USB 2.0 and an extension cable?
Yes. USB2 and extension-cable.
Worked for months … and now again.
Are wifi interferences possible too? I am unable to change zigbee away from channel 25 … after resetting it use cannel 11 now
All lights, plugs, and sensors that were one hop or more away
were brought to the ConBee, and they were reconnected
but two connected plugs did not establish a link between themselves.
I remember a similar issue, the user had the neighboard tables full, it have solved with a reboot, with unplug/replug the conbee, because if you just restart the host, it don’t restart the USB port.
But he had specific message on logs you haven’t.
Yes, but why suddently ?
Can be an hardware issue, from a specific device.
