Hi, i have a conbee II and want to use it with the deconz docker container from marthoc. The logs of the container indicate that it is properly recognizing the stick. However, the stick is not shown properly on the web landingpage, instead the icon looks like a cased raspberry pi (i am using an intel NUC). Also it asks me for a password which i did not specify before. A reset of the passwort is not possible either, it simpy complains that the device wasnt power cycled before (i did a power cycle a minute ago).
The interesting stuff is: When i connect directly to the container, everything works as intended, stick properly shown and so on. So the problem is the Traefik in front of the container. I suppose the websocket config is not right, at least thats what some googling reveals. Has someone set up deconz behind a Traefik reverse proxy and can tell me something more about their configuration?
