I have a problem. I’m unsure where to search for the origin.
I have a lights group “kitchen” with the following components:
- many IKEA Trafri dimmlights
- a wall switch: Xiaomi Aqara Opple Wireless Scene Switch 6 Button (WXCJKG13LM)
- a switch modul with standard led light: Lonsonho 2 Gang Switch Module No Neutral (QS-Zigbee-S04-2C-L)
- a switch modul with standard led light: Aqara Single Switch Module T1 With Neutral (SSM-U01)
- Aqara Motion and Illuminance Sensor (RTCGQ11LM)
I added 4 different scenes to control the different lights. If I change a scene in the phoscon app in one browser tab I can see in another brotcher tab that the correct lights are changed to the correct values always.
But the actual switch moduls don’t turn on or off as shown in the app.
If I use the single bulb control in the kitchen then both switch moduls work without a problem.
So there is a difference in turning ON/Off a switch modul by scene or by a single bulb control in the phoscon app.
The same problem applies to the wall switch.
When I add each scene to a button and then press these I see the correct behaviour in the phoscon app, but the lights from the switch modul never turn ON/OFF.
The same problem applies to the motion sensor.
When a motion is detected all dimmable lights turn ON and after the timer OFF again. But the switch moduls don’t react?
My Configuration:
Synology NAS DS716+ with DSM 6.2.4-25556
Deconz running the Docker container “marthoc-deconz:latest” in version 2.12.06
USB Stick ConBee II with USB extension cable
Here I tried to paste a log file where I changed the scenes in the kitchen many times in the end. ( I can’t read the log yet)
What can be the reason for this?
It must by some how in the programming? Maybe a problem when dimmlights are mixed with non dimmable lights?
What can I do to solve this?
