Not able to change state of any light (also group of lights)
I hope someone can help me, because I am getting frustrated.
I am running ConBee II Version 2.20.01 / 19.9.2022 with Firmware 26780700 and deconz. Also running Homebridge with Hue and deconz plugins.
This worked since 2 years without problem. But since few weeks, I am not able to change any state of for example lights. Home app is showing that state is changed (ON) but the lights are still not turned on.
In Homebridge I can see logs like
[16/05/2023, 14:31:02] [Hue] Motion Sensor: set homekit status fault from 1 to 0
[16/05/2023, 14:31:02] [Hue] Window 2: set homekit status fault from 1 to 0
[16/05/2023, 14:31:02] [Hue] All Mighty Schalter: set homekit status fault from 1 to 0
[16/05/2023, 14:31:02] [Hue] RelativeRotary 25: set homekit status fault from 1 to 0
[16/05/2023, 14:31:02] [deCONZ] Motion Sensor: Status Fault: set to 0 (from 1)
[16/05/2023, 14:31:02] [deCONZ] Window 2: Status Fault: set to 0 (from 1)
[16/05/2023, 14:31:02] [deCONZ] All Mighty Schalter: Status Fault: set to 0 (from 1)
Maybe also important to note is that I am using USB cable extension. I also tried to change channel from 15 to 20 or even 25 but no luck. The Phoscon app always switches back to Channel 15… in Deconz GUI the links was visible but now after I experimented with Channels - no links visible anymore…
Edit:
Now if I try to turn on plug I will get this in homebridge log:
[16/05/2023, 14:46:31] [Hue] Coffee Machine Plug: homekit on changed from false to true
[16/05/2023, 14:46:31] [Hue] ZigBee-Gateway: request 3577: PUT /lights/2/state {"on":true}
[16/05/2023, 14:46:31] [Hue] ZigBee-Gateway: request 3577: /lights/2/state: api error 202: resource, /lights/2/state, is not modifiable. Device is not reachable.
Edit 2:
this is the log
19:29:44:806 sql exec SELECT conf FROM zbconf ORDER BY rowid desc limit 1
19:29:44:808 Idle timer triggered
19:29:45:225 aps request id: 74 prf: 0x0000 cl: 0x0031 timeout (confirmed: 0) to 0x00212EFFFF078D2D (0x0000)
19:29:45:227 aps request id: 74 prf: 0x0000 cl: 0x0031 timeout NOT confirmed to 0x00212EFFFF078D2D (0x0000)
19:29:45:307 aps request id: 74 failed, erase from queue
19:29:45:308 emit artificial APSDE-DATA.confirm id: 74
19:29:45:386 aps request id: 74 failed, erase from queue
19:29:45:546 APS-DATA.request id: 95, addrmode: 0x03, addr: 0x00212effff078d2d, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 0 len: 2 tx.options 0x00
19:29:45:547 	asdu (length: 2): e100
19:29:49:806 Daylight now: goldenHour2, status: 180, daylight: 1, dark: 0
19:29:49:807 channel 15 does not match channel mask 0x02000000 (TODO)
19:29:59:806 Daylight now: goldenHour2, status: 180, daylight: 1, dark: 0
19:29:59:807 channel 15 does not match channel mask 0x02000000 (TODO)
19:30:04:807 GW firmware version: 0x26780700
19:30:04:808 GW firmware version is up to date: 0x26780700
19:30:09:806 Daylight now: goldenHour2, status: 180, daylight: 1, dark: 0
19:30:09:807 channel 15 does not match channel mask 0x02000000 (TODO)
