Have found usefull information on the doc
The Device supports commands On/Off Cluster as Server to allow the control of the Fil Pilote Heater wired to the Device, in a deprecated mode, when the Gateway does not integrate the Fil Pilote Cluster.
When controlled with the On/Off Cluster, the SIN-4-FP acts as:
Comfort when receiving a On Command,
No-Frost when receiving a Off Command.
So the light entry is useless. But you can use it to force a no-frost/Comfort and see if the device return the value after you send the request, can need to set a bind.
"ddfvalidate": false,
"manufacturername": "NodOn",
"modelid": "SIN-4-FP-21",
"vendor": "NodOn",
"product": "Cable outlet",
"sleeper": false,
"status": "Gold",
"type": "$TYPE_THERMOSTAT",
"restapi": "/sensors",
"0x01",
"0x0201"
"meta": {
"values": {
"config/mode": {"confort": 1, "confort-1": 4, "confort-2": 5, "eco": 2, "hors gel": 3, "off": 0}
"name": "attr/swversion"
"name": "config/mode",
"refresh.interval": 3600,
"read": {
"at": "0x0000",
"cl": "0xfc00",
"ep": "0x01",
"fn": "zcl:attr"
"at": "0x0000",
"cl": "0xfc00",
"ep": "0x01",
"eval": "if (Attr.val == 0) { Item.val = 'off'; } else if (Attr.val == 1) { Item.val = 'confort'; } else if (Attr.val == 2) { Item.val = 'eco'; } else if (Attr.val == 3) { Item.val = 'hors gel';} else if (Attr.val == 4) { Item.val = 'confort-1'; } else if (Attr.val == 5) { Item.val = 'confort-2'; }",
"fn": "zcl:attr"
"write": {
"cl": "0xfc00",
"ep": "0x01",
"cmd": "0x00",
"eval": "if (Item.val == 'off') { 0 } else if (Item.val == 'confort') { 1 } else if (Item.val == 'eco') { 2 } else if (Item.val == 'hors gel') { 3 } else if (Item.val == 'confort-1') { 4 } else if (Item.val == 'confort-2') { 5 }",
"fn": "zcl:cmd"
"name": "config/on"
"name": "config/reachable"
"name": "state/lastupdated"
"0x01",
"0x0702"
"name": "config/on"
"name": "state/consumption"
"type": "$TYPE_LEVEL_CONTROL_SWITCH",
"restapi": "/lights",
"0x01"
"name": "state/on",
"refresh.interval": 5
"name": "state/reachable"
"bindings": [
"cl": "0x0006",
"at": "0x0000",
"dt": "0x10",
"min": 1,
"max": 300
"cl": "0x0702",
"at": "0x0000",
"dt": "0x25",
"min": 1,
"max": 300,
"change": "0x00000001"
"cl": "0xfc00",
"at": "0x0000",
"dt": "0x20",
"min": 1,
"max": 3600,
