Nowadays I’m running deCONZ on a RPi with Raspbian (Raspbian Buster Desktop),
Version 2.13.04 / 2021-12-18 (stable).
ConBee 1, firmware 26400500.
Using USB extension cable: Yes.
Some years ago I run deCONZ on the same RPi as my HA as an add-on. One day I noticed that I did no longer have any links between my devices in deCONZ when watching it through VNC. After I had issues with channel changes (I have always run channel 25 but suddenly I was on channel 11 and could not change it back) I decided to leave the HA deCONZ add-on and migrated to a separate RPi (as today). I restored a backup and added some new devices and it worked pretty well, except from the fact that I was still not able to see any links between the devices. Another strange thing I encountered was that I could not create any new backups. It failed every time. After reading other threads I managed to change my network settings so today I’m able to create new backups. I’m also running channel 25 as I wish.
But, I still don’t see any links between the devices in deCONZ!
Since the links disappeared already when I used deCONZ as a HA addon, and didn’t get them back when migrated to a stand-alone platform, I don’t know where to look as I didn’t change anything manually back then and still avoid manual changes as I’m no advanced user on deCONZ nor Raspbian/Linux.
I think the network is doing fine and the devices are meshing as they should, I presume. However, the GUI links were very helpful when establishing the setup and I want to have that possibility back of course.
What should I do?
Sorry for the wall of text, I’m only trying to share any information that could be of interest to solve this.
I attach the network setting. Please let me know what other information you might need to help me out. Thanks in advance.
