12:53:39:511 dev /dev/ttyS0 (/dev/ttyS0)
12:53:39:956 Daylight now: solarNoon, status: 170, daylight: 1, dark: 0
12:53:40:456 wait reconnect 5 seconds
12:53:40:510 COM: /dev/ttyS0 : (0x0000/0x0000)
12:53:40:511 dev /dev/ttyS0 (/dev/ttyS0)
12:53:41:457 wait reconnect 4 seconds
12:53:42:456 wait reconnect 3 seconds
12:53:43:456 wait reconnect 2 seconds
12:53:43:956 failed to reconnect to network try=6
12:53:44:456 wait reconnect 1 seconds
12:53:44:571 COM: /dev/ttyS0 : (0x0000/0x0000)
12:53:44:572 dev /dev/ttyS0 (/dev/ttyS0)
12:53:44:572 failed open com status: (-3), path: /dev/ttyS0
12:53:45:456 wait reconnect 5 seconds
12:53:45:511 COM: /dev/ttyS0 : (0x0000/0x0000)
12:53:45:511 dev /dev/ttyS0 (/dev/ttyS0)
12:53:46:456 wait reconnect 4 seconds
12:53:47:010 COM: /dev/ttyS0 : (0x0000/0x0000)
12:53:47:011 dev /dev/ttyS0 (/dev/ttyS0)
12:53:47:011 GW firmware update select /dev/ttyS0 device
12:53:47:013 GW update firmware not found:
12:53:47:456 wait reconnect 3 seconds
12:53:48:457 wait reconnect 2 seconds
12:53:48:957 failed to reconnect to network try=7
12:53:49:457 wait reconnect 1 seconds
12:53:49:512 COM: /dev/ttyS0 : (0x0000/0x0000)
12:53:49:513 dev /dev/ttyS0 (/dev/ttyS0)
12:53:49:513 failed open com status: (-3), path: /dev/ttyS0
12:53:49:957 DB save zll database items 0x00000087
12:53:49:958 DB sql exec REPLACE INTO auth (apikey, devicetype, createdate, lastusedate, useragent) VALUES ('07919579F9', 'homebridge-hue#JotRPI', '2021-08-05T14:04:48', '2023-10-26T10:53:47', '')
12:53:49:964 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastseen', '2023-10-26T10:52Z', 'dev', 1697885418 FROM sub_devices WHERE uniqueid = '58:8e:81:ff:fe:62:39:91-01'
12:53:49:967 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'state/reachable', 'true', 'dev', 1698317573 FROM sub_devices WHERE uniqueid = '58:8e:81:ff:fe:62:39:91-01'
12:53:49:971 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastannounced', '', 'dev', 1697627869 FROM sub_devices WHERE uniqueid = '58:8e:81:ff:fe:62:39:91-01'
12:53:49:973 DB sql exec REPLACE INTO nodes (id, state, mac, name, groups, endpoint, modelid, manufacturername, swbuildid, ritems) VALUES ('4', 'normal', '58:8e:81:ff:fe:62:39:91-01', 'JoSaHome ZigBee Cover 2', '65520,11', '1', 'FYRTUR block-out roller blind', 'IKEA of Sweden', '2.3.088', '{"attr/id":"4","attr/lastannounced":null,"attr/lastseen":"2023-10-26T10:52Z","attr/manufacturername":"IKEA of Sweden","attr/modelid":"FYRTUR block-out roller blind","attr/name":"JoSaHome ZigBee Cover 2","attr/swversion":"2.3.088","attr/type":"Window covering device","attr/uniqueid":"58:8e:81:ff:fe:62:39:91-01","state/lift":0,"state/open":true,"state/reachable":true}')
12:53:49:977 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastseen', '2023-10-26T10:52Z', 'dev', 1697885421 FROM sub_devices WHERE uniqueid = '58:8e:81:ff:fe:b4:63:96-01'
12:53:49:980 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'state/reachable', 'true', 'dev', 1698317573 FROM sub_devices WHERE uniqueid = '58:8e:81:ff:fe:b4:63:96-01'
12:53:49:983 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastannounced', '', 'dev', 1697742756 FROM sub_devices WHERE uniqueid = '58:8e:81:ff:fe:b4:63:96-01'
12:53:49:985 DB sql exec REPLACE INTO nodes (id, state, mac, name, groups, endpoint, modelid, manufacturername, swbuildid, ritems) VALUES ('5', 'normal', '58:8e:81:ff:fe:b4:63:96-01', 'JoSaHome ZigBee Cover 1', '65520,11', '1', 'FYRTUR block-out roller blind', 'IKEA of Sweden', '2.3.088', '{"attr/id":"5","attr/lastannounced":null,"attr/lastseen":"2023-10-26T10:52Z","attr/manufacturername":"IKEA of Sweden","attr/modelid":"FYRTUR block-out roller blind","attr/name":"JoSaHome ZigBee Cover 1","attr/swversion":"2.3.088","attr/type":"Window covering device","attr/uniqueid":"58:8e:81:ff:fe:b4:63:96-01","state/lift":100,"state/open":false,"state/reachable":true}')
12:53:49:988 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES ('0xFFF0', 'All', 'normal', '', '', '', 'false', 'LightGroup', 'Other', '')
12:53:49:990 DB sql exec DELETE FROM scenes WHERE gid='0x0001'
12:53:49:991 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES ('0x0001', 'JoSaHome Room 1', 'deleted', '', '', '', 'false', 'LightGroup', 'Other', '')
12:53:49:992 DB sql exec DELETE FROM scenes WHERE gid='0x0002'
12:53:49:993 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES ('0x0002', 'TRADFRI open/close remote', 'deleted', '', '', '', 'false', 'LightGroup', 'Other', '68:0a:e2:ff:fe:f9:a0:15')
12:53:49:994 DB sql exec DELETE FROM scenes WHERE gid='0x0003'
12:53:49:995 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES ('0x0003', 'Test', 'deleted', '', '', '', 'false', 'LightGroup', 'Other', '')
12:53:49:996 DB sql exec DELETE FROM scenes WHERE gid='0x0004'
12:53:49:997 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES ('0x0004', 'TRADFRI open/close remote', 'deleted', '', '', '', 'false', 'LightGroup', 'Other', '68:0a:e2:ff:fe:f9:a0:15')
12:53:49:998 DB sql exec DELETE FROM scenes WHERE gid='0x0005'
12:53:49:999 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES ('0x0005', 'Dummy Group', 'deleted', '', '', '', 'false', 'LightGroup', 'Other', '')
12:53:50:000 DB sql exec DELETE FROM scenes WHERE gid='0x0006'
12:53:50:001 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES ('0x0006', 'TRADFRI open/close remote', 'deleted', '', '', '', 'false', 'LightGroup', 'Other', '68:0a:e2:ff:fe:fa:22:14')
12:53:50:002 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES ('0x0007', 'TRADFRI SHORTCUT Button', 'normal', '', '7', '', 'false', 'LightGroup', 'Other', 'b4:e3:f9:ff:fe:67:a0:70')
12:53:50:003 DB sql exec DELETE FROM scenes WHERE gid='0x0008'
12:53:50:004 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES ('0x0008', 'TRADFRI open/close remote', 'deleted', '', '', '', 'false', 'LightGroup', 'Other', '68:0a:e2:ff:fe:fa:22:14')
12:53:50:005 DB sql exec DELETE FROM scenes WHERE gid='0x0009'
12:53:50:006 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES ('0x0009', 'lklk', 'deleted', '', '', '', 'false', 'LightGroup', 'Other', '')
12:53:50:007 DB sql exec DELETE FROM scenes WHERE gid='0x000A'
12:53:50:008 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES ('0x000A', 'Test', 'deleted', '', '', '', 'false', 'LightGroup', 'Other', '')
12:53:50:009 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES ('0x000B', 'TRADFRI open/close remote', 'normal', '', '14', '', 'false', 'LightGroup', 'Other', '68:0a:e2:ff:fe:fa:22:14')
12:53:50:011 DB sql exec DELETE FROM scenes WHERE gid='0x000C'
12:53:50:012 DB sql exec REPLACE INTO groups (gid, name, state, mids, devicemembership, lightsequence, hidden, type, class, uniqueid) VALUES ('0x000C', 'JoSaHome Roller Shutter Group', 'deleted', '', '', '', 'false', 'LightGroup', 'Other', '')
12:53:50:015 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastannounced', '', 'dev', 1697627869 FROM sub_devices WHERE uniqueid = '58:8e:81:ff:fe:62:39:91-01-0001'
12:53:50:016 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastseen', '2023-10-26T10:52Z', 'dev', 1697885418 FROM sub_devices WHERE uniqueid = '58:8e:81:ff:fe:62:39:91-01-0001'
12:53:50:018 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/on', 'true', 'dev', 1680343529 FROM sub_devices WHERE uniqueid = '58:8e:81:ff:fe:62:39:91-01-0001'
12:53:50:020 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/reachable', 'true', 'dev', 1695297542 FROM sub_devices WHERE uniqueid = '58:8e:81:ff:fe:62:39:91-01-0001'
12:53:50:022 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('12', 'FYRTUR block-out roller blind', 'ZHABattery', 'FYRTUR block-out roller blind', 'IKEA of Sweden', '58:8e:81:ff:fe:62:39:91-01-0001', '2.3.088', '{"battery":87,"lastupdated":"2023-10-21T10:50:23.090"}', '{"on":true,"reachable":true}', '{"d":514,"ep":1,"in":[0,1,258],"out":[25],"p":260}', 'normal', '1', '2023-10-26T10:52Z', '')
12:53:50:027 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastannounced', '', 'dev', 1697345420 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0402'
12:53:50:029 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastseen', '2023-10-26T10:52Z', 'dev', 1697885305 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0402'
12:53:50:031 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/on', 'true', 'dev', 1679998740 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0402'
12:53:50:032 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/reachable', 'false', 'dev', 1697885406 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0402'
12:53:50:034 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/battery', '100', 'dev', 1652392284 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0402'
12:53:50:036 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/offset', '0', 'dev', 1666374054 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0402'
12:53:50:038 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('9', 'JoSaHome ZigBee Sensor TempHum 1', 'ZHATemperature', 'lumi.weather', 'LUMI', '00:15:8d:00:06:f8:3e:d6-01-0402', '0.0.0_0005', '{"lastupdated":"2023-10-21T10:48:25.438","temperature":2240,"temperature_bis":null}', '{"battery":100,"offset":0,"on":true,"reachable":false}', '{"d":24321,"ep":1,"in":[0,1026],"p":260}', 'normal', '1', '2023-10-26T10:52Z', '')
12:53:50:042 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastannounced', '', 'dev', 1697345420 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0405'
12:53:50:044 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastseen', '2023-10-26T10:52Z', 'dev', 1697885305 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0405'
12:53:50:046 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/on', 'true', 'dev', 1679998741 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0405'
12:53:50:047 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/reachable', 'false', 'dev', 1697885406 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0405'
12:53:50:049 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/battery', '100', 'dev', 1652392284 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0405'
12:53:50:051 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/offset', '0', 'dev', 1652392284 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0405'
12:53:50:052 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('10', 'JoSaHome ZigBee Sensor TempHum 1', 'ZHAHumidity', 'lumi.weather', 'LUMI', '00:15:8d:00:06:f8:3e:d6-01-0405', '0.0.0_0005', '{"humidity":7418,"humidity_bis":null,"lastupdated":"2023-10-21T10:48:25.439"}', '{"battery":100,"offset":0,"on":true,"reachable":false}', '{"d":24321,"ep":1,"in":[0,1029],"p":260}', 'normal', '1', '2023-10-26T10:52Z', '')
12:53:50:056 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastannounced', '', 'dev', 1697345420 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0403'
12:53:50:059 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastseen', '2023-10-26T10:52Z', 'dev', 1697885305 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0403'
12:53:50:060 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/on', 'true', 'dev', 1679998743 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0403'
12:53:50:062 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/reachable', 'false', 'dev', 1697885406 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0403'
12:53:50:064 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/battery', '100', 'dev', 1652392284 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0403'
12:53:50:065 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/offset', '0', 'dev', 1652392284 FROM sub_devices WHERE uniqueid = '00:15:8d:00:06:f8:3e:d6-01-0403'
12:53:50:067 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('11', 'JoSaHome ZigBee Sensor TempHum 1', 'ZHAPressure', 'lumi.weather', 'LUMI', '00:15:8d:00:06:f8:3e:d6-01-0403', '0.0.0_0005', '{"lastupdated":"2023-10-21T10:48:25.450","pressure":993,"pressure_bis":null}', '{"battery":100,"offset":0,"on":true,"reachable":false}', '{"d":24321,"ep":1,"in":[0,1027],"p":260}', 'normal', '1', '2023-10-26T10:52Z', '')
12:53:50:071 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastannounced', '', 'dev', 1697742756 FROM sub_devices WHERE uniqueid = '58:8e:81:ff:fe:b4:63:96-01-0001'
12:53:50:073 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'attr/lastseen', '2023-10-26T10:52Z', 'dev', 1697885421 FROM sub_devices WHERE uniqueid = '58:8e:81:ff:fe:b4:63:96-01-0001'
12:53:50:075 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/on', 'true', 'dev', 1680343529 FROM sub_devices WHERE uniqueid = '58:8e:81:ff:fe:b4:63:96-01-0001'
12:53:50:076 INSERT INTO resource_items (sub_device_id,item,value,source,timestamp) SELECT id, 'config/reachable', 'true', 'dev', 1697028107 FROM sub_devices WHERE uniqueid = '58:8e:81:ff:fe:b4:63:96-01-0001'
12:53:50:079 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('5', 'FYRTUR block-out roller blind', 'ZHABattery', 'FYRTUR block-out roller blind', 'IKEA of Sweden', '58:8e:81:ff:fe:b4:63:96-01-0001', '2.3.088', '{"battery":55,"lastupdated":"2023-10-21T10:50:24.593"}', '{"on":true,"reachable":true}', '{"d":514,"ep":1,"in":[0,1,258],"out":[25],"p":260}', 'normal', '1', '2023-10-26T10:52Z', '')
12:53:50:103 DB saved in 146 ms
12:53:50:104 Daylight now: solarNoon, status: 170, daylight: 1, dark: 0
12:53:50:457 wait reconnect 5 seconds
12:53:50:512 COM: /dev/ttyS0 : (0x0000/0x0000)
12:53:50:513 dev /dev/ttyS0 (/dev/ttyS0)
12:53:51:457 wait reconnect 4 seconds
12:53:52:457 wait reconnect 3 seconds
12:53:53:456 wait reconnect 2 seconds
12:53:53:957 failed to reconnect to network try=8
12:53:54:456 wait reconnect 1 seconds
12:53:54:510 COM: /dev/ttyS0 : (0x0000/0x0000)
12:53:54:510 dev /dev/ttyS0 (/dev/ttyS0)
12:53:54:511 failed open com status: (-3), path: /dev/ttyS0
12:53:55:456 wait reconnect 5 seconds
12:53:55:549 COM: /dev/ttyS0 : (0x0000/0x0000)
12:53:55:550 dev /dev/ttyS0 (/dev/ttyS0)
12:53:56:457 wait reconnect 4 seconds
12:53:57:010 COM: /dev/ttyS0 : (0x0000/0x0000)
12:53:57:011 dev /dev/ttyS0 (/dev/ttyS0)
12:53:57:011 GW firmware update select /dev/ttyS0 device
12:53:57:014 GW update firmware not found:
12:53:57:456 wait reconnect 3 seconds
12:53:58:456 wait reconnect 2 seconds
12:53:58:957 failed to reconnect to network try=9
12:53:59:457 wait reconnect 1 seconds
12:53:59:511 COM: /dev/ttyS0 : (0x0000/0x0000)
12:53:59:511 dev /dev/ttyS0 (/dev/ttyS0)
12:53:59:512 failed open com status: (-3), path: /dev/ttyS0
12:53:59:957 Daylight now: solarNoon, status: 170, daylight: 1, dark: 0
12:54:00:456 wait reconnect 5 seconds
12:54:00:512 COM: /dev/ttyS0 : (0x0000/0x0000)
12:54:00:513 dev /dev/ttyS0 (/dev/ttyS0)
12:54:01:456 wait reconnect 4 seconds
12:54:01:593 New websocket 192.168.1.15:62326 (state: 3)
12:54:02:460 wait reconnect 3 seconds
12:54:03:456 wait reconnect 2 seconds
12:54:03:957 failed to reconnect to network try=10
12:54:04:457 wait reconnect 1 seconds
12:54:04:511 COM: /dev/ttyS0 : (0x0000/0x0000)
12:54:04:512 dev /dev/ttyS0 (/dev/ttyS0)
12:54:04:513 failed open com status: (-3), path: /dev/ttyS0
12:54:05:457 wait reconnect 5 seconds
12:54:05:513 COM: /dev/ttyS0 : (0x0000/0x0000)
12:54:05:513 dev /dev/ttyS0 (/dev/ttyS0)
12:54:06:456 wait reconnect 4 seconds
12:54:07:062 COM: /dev/ttyS0 : (0x0000/0x0000)
12:54:07:062 dev /dev/ttyS0 (/dev/ttyS0)
12:54:07:063 GW firmware update select /dev/ttyS0 device
12:54:07:066 GW update firmware not found:
12:54:07:456 wait reconnect 3 seconds
12:54:08:456 wait reconnect 2 seconds
12:54:08:957 reconnect network failed, try later
12:54:09:457 networkState: CC_ReconnectNetwork
12:54:09:457 start reconnect to network
12:54:09:457 wait reconnect 1 seconds
12:54:09:511 COM: /dev/ttyS0 : (0x0000/0x0000)
12:54:09:512 dev /dev/ttyS0 (/dev/ttyS0)
12:54:09:512 failed open com status: (-3), path: /dev/ttyS0
12:54:09:957 Daylight now: solarNoon, status: 170, daylight: 1, dark: 0
12:54:10:457 wait reconnect 5 seconds
12:54:10:511 COM: /dev/ttyS0 : (0x0000/0x0000)
12:54:10:512 dev /dev/ttyS0 (/dev/ttyS0)
12:54:11:456 wait reconnect 4 seconds
12:54:12:456 wait reconnect 3 seconds
12:54:13:456 wait reconnect 2 seconds
12:54:14:456 wait reconnect 1 seconds
12:54:14:510 COM: /dev/ttyS0 : (0x0000/0x0000)
12:54:14:511 dev /dev/ttyS0 (/dev/ttyS0)
12:54:14:512 failed open com status: (-3), path: /dev/ttyS0
12:54:14:707 failed to reconnect to network try=1
12:54:15:456 wait reconnect 5 seconds
12:54:15:510 COM: /dev/ttyS0 : (0x0000/0x0000)
12:54:15:511 dev /dev/ttyS0 (/dev/ttyS0)
12:54:16:456 wait reconnect 4 seconds
12:54:17:010 COM: /dev/ttyS0 : (0x0000/0x0000)
12:54:17:011 dev /dev/ttyS0 (/dev/ttyS0)
12:54:17:012 GW firmware update select /dev/ttyS0 device
12:54:17:015 GW update firmware not found:
12:54:17:465 wait reconnect 3 seconds
12:54:18:465 wait reconnect 2 seconds
12:54:19:465 wait reconnect 1 seconds
12:54:19:519 COM: /dev/ttyS0 : (0x0000/0x0000)
12:54:19:519 dev /dev/ttyS0 (/dev/ttyS0)
12:54:19:520 failed open com status: (-3), path: /dev/ttyS0
12:54:19:973 Daylight now: solarNoon, status: 170, daylight: 1, dark: 0
12:54:19:974 failed to reconnect to network try=2
12:54:20:483 wait reconnect 5 seconds
12:54:20:537 COM: /dev/ttyS0 : (0x0000/0x0000)
12:54:20:538 dev /dev/ttyS0 (/dev/ttyS0)
12:54:21:467 wait reconnect 4 seconds
12:54:22:466 wait reconnect 3 seconds
12:54:23:456 wait reconnect 2 seconds
12:54:24:457 wait reconnect 1 seconds
12:54:24:511 COM: /dev/ttyS0 : (0x0000/0x0000)
12:54:24:511 dev /dev/ttyS0 (/dev/ttyS0)
12:54:24:512 failed open com status: (-3), path: /dev/ttyS0
12:54:24:956 failed to reconnect to network try=3
12:54:25:456 wait reconnect 5 seconds
12:54:25:511 COM: /dev/ttyS0 : (0x0000/0x0000)
12:54:25:511 dev /dev/ttyS0 (/dev/ttyS0)
12:54:26:456 wait reconnect 4 seconds
12:54:27:010 COM: /dev/ttyS0 : (0x0000/0x0000)
12:54:27:011 dev /dev/ttyS0 (/dev/ttyS0)
12:54:27:011 GW firmware update select /dev/ttyS0 device
12:54:27:013 GW update firmware not found:
