Within the Deconz-Addon Page the “Rasperry” is selectable in the dropdown, but the “Connection Button” is grayed out.
While this module is rather old, i think the main problem could be a very old Firmware Version on the Raspbee2.
So use this Manual:
Chapter: " Updating Conbee/RaspBee Firmware"
Command in Step: 3. Invoke the firmware update script
Offcourse the Deconz AddOn is stopped during this session.
During the update Process i got this Messages:
Device path .: /dev/ttyAMA@
Firmware file: deCONZ_RaspBeeII_@x26720700.bin.GCF
Timeout: 60
Loglevel ....: 3
Are the above values correct?
Enter Y to proceed, any other entry to exit: y
Flashing...
12:12:27:746 using firmware file: /usr/share/deCONZ/firmvare/deCONZ_RaspBeeII_0x26720700.bin.GCF
12:12:28:018 ls dev: /dev/ttyAMA® (0x0000/0x0000) sn:
12:12:28:018 dev /dev/ttyAMA@
Reboot device /dev/ttyAMAO (RaspBee)
12:12:28:055 query bootloader v1 ID after @ ms
query bootloader v3 ID after 1552 m:
TX cO81027dffcO
query deCONZ firmware version
write deCONZ version command failed ret: 13 (expected: 13)
12:12:30:511 retry, elapsed 2 seconds
12:12:30:608 parse commands: /usr/bin/GCFFlasher_internal.bin -d /dev/ttyAMA® -f /usr/share/deCONZ/firmvare/deCONZ_RaspBeeII_0x26720700.bin.GCF -t 60 -x 3
Is this module completely bricked or only rather old?
Can you give a hint for me?
Thank you
I made this RaspBee2 Installation until this step:
udo hwclock --verbose
hwclock from util-linux 2.36.1
System Time: 1690634403.159774
Trying to open: /dev/rtc0
Using the rtc interface to the clock.
Last drift adjustment done at 1690634390 seconds after 1969
Last calibration done at 1690634390 seconds after 1969
Hardware clock is on UTC time
Assuming hardware clock is kept in UTC time.
Waiting for clock tick...
ioctl(4, RTC_UIE_ON, 0): Invalid argument
Waiting in loop for time from /dev/rtc0 to change
hwclock: ioctl(RTC_RD_TIME) to /dev/rtc0 to read the time failed: Invalid argument
...synchronization failed
This is the RaspBeeII pcb addon for the Pin-Head. This is not connected via USB. The pcb is upside/down, so i can not see any LED. I tried to the with “darkness”, but there it seems that there is no LED on.
Do you have any idea?
Thank you for your patience!!!
