New SONOF Temperatur Sensor SNBZ-02LD
I bought a new Sonoff Temperatur Sensor
Type SNBZ-02LD
It is a IP65 Temperatur Sensor with a one meter long Sensor Cable.
I´m using it as Pool Sensor
I added it to the deconz-rest-plugin/devices/sonoff/snzb-02-multisensor.json at master · dresden-elektronik/deconz-rest-plugin · GitHub file
  "uuid": "52815a37-6180-4ab8-83ef-021d75496a7b",
  "manufacturername": [
    "eWeLink",
    "SONOFF",
    "SONOFF",
    "eWeLink",
    "SONOFF"
  "modelid": [
    "TH01",
    "SNZB-02D",
    "SNZB-02P",
    "SNZB-02P",
    "SNZB-02LD"
This works for me, but this Sensor has no Humidity Sensor.
Is this the right way or schould there be an extra file without humidity
Hello, yes better to make a new DDF, else we will have users saying there is a not working sensor on this device.
I tried to copy the multisensor file do a new file caled snzb-02ld.json and deleted the humidity sensor section.
I also removed the modelid and manufacturername form the mulisensor file.
After restart deconz and removing it from the phoscon app the sensor was not found any more.
Did I something wrong?
Yep probably a typo in the new DDF.
The sensor is not reconised so this part is fine.
You can try your DDF in this site https://jsonlint.com/
You have put the new DDF in the same folder ?
I updated to openhab 5 today and I added the new json file to the deconz dir.
I works as expected.
How could I add this to the repository.
snzb-02LD.json
    "SONOFF"
  "modelid": [
    "SNZB-02LD"
  "vendor": "Sonoff",
  "product": "Temperature And Humidity Sensor (SNZB-02)",
  "sleeper": true,
  "status": "Gold",
      "restapi": "/sensors",
        "0x01",
        "0x0402"
      "fingerprint": {
        "profile": "0x0104",
        "device": "0x0302",
        "endpoint": "0x01",
        "in": [
          "0x0000",
          "0x0001",
          "0x0402"
          "name": "attr/swversion",
          "refresh.interval": 86400,
          "read": {
            "at": "0x0006",
            "cl": "0x0000",
            "fn": "zcl:attr"
            "at": "0x0006",
            "cl": "0x0000",
            "fn": "zcl:attr"
          "name": "config/battery",
          "awake": true,
          "refresh.interval": 7265,
          "read": {
            "at": "0x0021",
            "cl": "0x0001",
            "fn": "zcl:attr"
            "at": "0x0021",
            "cl": "0x0001",
          "default": 0
          "name": "config/offset",
          "default": 0
          "name": "config/on"
          "name": "config/reachable"
          "name": "state/lastupdated"
          "name": "state/temperature",
          "awake": true,
          "default": 0
  "bindings": [
      "dst.ep": 1,
      "cl": "0x0001",
          "at": "0x0021",
          "dt": "0x20",
          "min": 3600,
          "max": 7200,
          "change": "0x00000002"
      "dst.ep": 1,
      "cl": "0x0405",
          "at": "0x0000",
          "dt": "0x21",
          "min": 60,
          "max": 600,
          "change": "0x00000064"
      "cl": "0x0402",
          "at": "0x0000",
          "dt": "0x29",
          "min": 60,
          "max": 600,
          "change": "0x0000001E"
You can make a PR if you have a github account.
Just try to create a new file in this folder deconz-rest-plugin/devices/sonoff at master · dresden-elektronik/deconz-rest-plugin · GitHub
You will have an error message saying you haven’t right, it will create a fork on your account and start to make the PR
Rollback is possible, you can’t break something and can retry/edit the file later.
Else I can make it myself.
Just remove this line
This line will be added by the site itself.
I tried.
I hope I did it the right way.
Yep, the PR was fine, there was probably errors, I have only see the not removed old binding, but it’s possible to correct a PR, not a big problem for a PR, don’t worry for that.
But sorry for this time, another user was on the same DDF than you.
