I have a new RaspBee2 connected to a new Phoscon image on a raspberry pi, but the RaspBee is not detected. Here’s the steps I took
- Installed Phoscon_Gateway_2021-08-23.xz (also tried Phoscon_Gateway_2021-12-21.xz) on a Raspberry Pi 3 Model v1.2
- Performed software updates
- Disabled login shell over serial in raspi-config
- Enabled serial port hardware
There is a Low voltage warning, but the voltage is 5.14V (@ 310mA Power consumption) on a 3A power supply - same thing on a different 4.4A power supply (5.11V @ 310mA).
In deCONZ application only “RaspBee” is available to select in the “Connect to Device” dialog box. Clicking the Connect button has no effect.
The Gateway page in the Phoscon web app indicated “unknown” Vendor, empty Product and “Not connected” Firmware
After swapping the raspbee2 with a ConBee2 everthing works fine
Could the RaspBee be broken ?
How can I further investigate ?
Here are the logs
log file
13:20:39:542 HTTP Server listen on address 0.0.0.0, port: 80 error: The bound address is already in use
13:20:39:543 HTTP Server listen on address 0.0.0.0, port: 80 error: The bound address is already in use
13:20:39:543 HTTP Server listen on address 0.0.0.0, port: 8080, root: /usr/share/deCONZ/webapp/
13:20:40:001 COM: /dev/ttyAMA0 : (0x0000/0x0000)
13:20:40:001 COM: /dev/ttyS0 : (0x0000/0x0000)
13:20:40:001 dev /dev/ttyS0 (/dev/ttyS0)
13:20:40:002 ZCLDB init file /home/pi/.local/share/dresden-elektronik/deCONZ/zcldb.txt
13:20:40:634 DDF: doc:hdr: Vibration sensor DJT11LM
13:20:40:634 DDF: doc:path: xiaomi/aq_vibration_sensor.md
13:20:40:634 DDF: manufacturername: $MF_LUMI
13:20:40:634 DDF: md:known_issues:
13:20:40:634 DDF: modelid: lumi.vibration.aq1
13:20:40:634 DDF: product: Vibration Sensor (DJT11LM)
13:20:40:634 DDF: schema: devcap1.schema.json
13:20:40:634 DDF: sleeper:
13:20:40:634 DDF: status: Bronze
13:20:40:634 DDF: subdevices:
13:20:40:634 DDF: loaded resource item descriptor: attr/lastseen
13:20:40:634 DDF: loaded resource item descriptor: attr/manufacturername
... resources loading deleted for brievity ...
13:20:40:738 DDF: loaded resource item descriptor: state/lastupdated
13:20:40:795 parent process -bash
13:20:40:795 gw run mode: normal
13:20:40:796 GW sd-card image version: Phoscon-GW, V4_00, 2021-08-23
13:20:40:796 sd-card cid: 6f0303434241445310ffffffff0135f9
13:20:40:799 DB sqlite version 3.27.2
13:20:40:803 DB PRAGMA page_count: 46
13:20:40:803 DB PRAGMA page_size: 4096
13:20:40:803 DB PRAGMA freelist_count: 0
13:20:40:803 DB file size 188416 bytes, free pages 0
13:20:40:803 DB PRAGMA user_version: 9
13:20:40:803 DB cleanup
13:20:40:805 DB create temporary views
13:20:40:806 DB view [0] created
13:20:40:807 DB view [1] created
13:20:40:808 DB view [2] created
13:20:40:809 DB view [3] created
13:20:40:810 sql exec SELECT apikey,devicetype,createdate,lastusedate,useragent FROM auth
13:20:40:811 sql exec SELECT key FROM config2
13:20:40:812 sql exec SELECT key,value FROM config2
13:20:40:812 Load config UTC: 2022-01-01T11:58:04 from db.
13:20:40:812 Load config announceinterval: 45 from db.
13:20:40:812 Load config announceurl: https://phoscon.de/discover from db.
13:20:40:812 Load config apiversion: 2.13.04 from db.
13:20:40:812 Load config bridgeid: 0000000000000000 from db.
13:20:40:812 Load config datastoreversion: 93 from db.
13:20:40:812 Load config dhcp: true from db.
13:20:40:812 Load config disablePermitJoinAutoOff: false from db.
13:20:40:812 Load config discovery: false from db.
13:20:40:812 Load config factorynew: false from db.
13:20:40:812 Load config fwneedupdate: false from db.
13:20:40:812 Load config fwupdatestate: idle from db.
13:20:40:813 Load config fwversion: 0x00000000 from db.
13:20:40:813 Load config gateway: 127.0.0.1 from db.
13:20:40:813 Load config group0: 65520 from db.
13:20:40:813 Load config groupdelay: 50 from db.
13:20:40:813 Load config gwpassword: $1$8282jdkm$mk8ipTFEkrhungZTTClLh0 from db.
13:20:40:813 Load config gwusername: delight from db.
13:20:40:813 Load config homebridge: not-managed from db.
13:20:40:813 Load config homebridge-pin: from db.
13:20:40:813 Load config homebridgepin: from db.
13:20:40:813 Load config homebridgeupdate: false from db.
13:20:40:813 Load config homebridgeupdateversion: from db.
13:20:40:813 Load config homebridgeversion: from db.
13:20:40:813 Load config ipaddress: 192.168.0.201 from db.
13:20:40:813 Load config lightlastseeninterval: 60 from db.
13:20:40:813 Load config linkbutton: false from db.
13:20:40:813 Load config localtime: 2022-01-01T12:58:04 from db.
13:20:40:813 Load config mac: 38:60:77:7c:53:18 from db.
13:20:40:813 Load config modelid: deCONZ from db.
13:20:40:813 Load config name: Phoscon-GW from db.
13:20:40:813 Load config netmask: 255.0.0.0 from db.
13:20:40:813 Load config networkopenduration: 180 from db.
13:20:40:813 Load config ntp: synced from db.
13:20:40:813 Load config otauactive: false from db.
13:20:40:814 Load config otaustate: off from db.
13:20:40:814 Load config panid: 0 from db.
13:20:40:814 Load config permitjoin: 0 from db.
13:20:40:814 Load config permitjoinfull: 0 from db.
13:20:40:814 Load config port: 80 from db.
13:20:40:814 Load config portalservices: false from db.
13:20:40:814 Load config proxyaddress: none from db.
13:20:40:814 Load config proxyport: 0 from db.
13:20:40:814 Load config rfconnect: 1 from db.
13:20:40:814 Load config rfconnected: false from db.
13:20:40:814 Load config rgbwdisplay: 1 from db.
13:20:40:814 Load config runmode: systemd/gui from db.
13:20:40:814 Load config starterkitid: from db.
13:20:40:814 Load config swcommit: 8204f08632d42e22905a77e111acc552b7770f25 from db.
13:20:40:814 Load config swupdatestate: noupdates from db.
13:20:40:814 Load config swversion: 2.13.04 from db.
13:20:40:814 Load config system: linux-gw from db.
13:20:40:814 Load config timeformat: 12h from db.
13:20:40:814 Load config timezone: Etc/GMT from db.
13:20:40:814 Load config updatechannel: stable from db.
13:20:40:814 Load config uuid: 182cea9e-b2d5-49ce-ad67-39ed29e2a16c from db.
13:20:40:815 Load config websocketnotifyall: true from db.
13:20:40:815 Load config websocketport: 443 from db.
13:20:40:815 Load config wifi: not-configured from db.
13:20:40:815 Load config wifibackupname: from db.
13:20:40:815 Load config wifibackuppw: from db.
13:20:40:815 Load config wifibackuppwenc: from db.
13:20:40:815 Load config wifichannel: 1 from db.
13:20:40:815 Load config wificlientname: SVDV from db.
13:20:40:815 Load config wificlientpw: from db.
13:20:40:815 Load config wifiip: 192.168.0.202 from db.
13:20:40:815 Load config wifilastupdated: 1641036307 from db.
13:20:40:815 Load config wifimgmt: 0 from db.
13:20:40:815 Load config wifiname: from db.
13:20:40:815 Load config wifipageactive: false from db.
13:20:40:815 Load config wifipw: from db.
13:20:40:815 Load config wifipwenc: from db.
13:20:40:815 Load config wifitype: accesspoint from db.
13:20:40:815 Load config workingname: SVDV from db.
13:20:40:815 Load config workingpw: from db.
13:20:40:815 Load config workingpwenc: from db.
13:20:40:815 Load config workingtype: client from db.
13:20:40:816 Load config zclvaluemaxage: 0 from db.
13:20:40:816 Load config zigbeechannel: 0 from db.
13:20:40:816 sql exec SELECT key,value FROM userparameter
13:20:40:816 sql exec SELECT * FROM groups
13:20:40:817 Sqlite group: gid = 0xFFF0
13:20:40:817 Sqlite group: name = All
13:20:40:817 Sqlite group: state = normal
13:20:40:817 Sqlite group: hidden = false
13:20:40:817 Sqlite group: type = LightGroup
13:20:40:817 Sqlite group: class = Other
13:20:40:818 DB found group All 0xFFF0
13:20:40:818 sql exec SELECT * FROM resourcelinks
13:20:40:818 sql exec SELECT * FROM scenes
13:20:40:819 sql exec SELECT * FROM rules
13:20:40:819 sql exec SELECT * FROM schedules
13:20:40:820 sql exec SELECT * FROM sensors
13:20:40:820 Sqlite sensors: sid = 1
13:20:40:821 Sqlite sensors: name = Daylight
13:20:40:821 Sqlite sensors: type = Daylight
13:20:40:821 Sqlite sensors: modelid = PHDL00
13:20:40:821 Sqlite sensors: manufacturername = Philips
13:20:40:821 Sqlite sensors: uniqueid = 00:00:00:00:00:00:00:00-01
13:20:40:821 Sqlite sensors: swversion = 1.0
13:20:40:821 Sqlite sensors: state = {"dark":false,"daylight":true,"lastupdated":"2022-01-01T12:14:51.546","status":170,"sunrise":"2022-01-01T07:50:34","sunset":"2022-01-01T15:52:32"}
13:20:40:821 Sqlite sensors: config = {"configured":true,"lat":"50.828","long":"3.2649","on":true,"sunriseoffset":30,"sunsetoffset":-30}
13:20:40:821 Sqlite sensors: deletedState = normal
13:20:40:822 Sqlite sensors: mode = 1
13:20:40:822 DB found sensor Daylight 1
13:20:40:824 sql exec SELECT * FROM gateways
12:20:40:829 Daylight now: solarNoon, status: 170, daylight: 1, dark: 0
12:20:40:831 Failed to start websocket server on 0.0.0.0, port: 443. error: The bound address is already in use
12:20:40:831 Failed to start websocket server on 0.0.0.0, port: 8080. error: The bound address is already in use
12:20:40:831 Started websocket server on 0.0.0.0, port: 8088
12:20:40:833 <?xml version="1.0" encoding="UTF-8" ?>
12:20:40:833 <root xmlns="urn:schemas-upnp-org:device-1-0">
12:20:40:833 <specVersion>
12:20:40:833 <major>1</major>
12:20:40:833 <minor>0</minor>
12:20:40:833 </specVersion>
12:20:40:833 <URLBase>http://192.168.0.201:8080/</URLBase>
12:20:40:833 <device>
12:20:40:833 <deviceType>urn:schemas-upnp-org:device:Basic:1</deviceType>
12:20:40:833 <friendlyName>Phoscon-GW (192.168.0.201)</friendlyName>
12:20:40:833 <manufacturer>Royal Philips Electronics</manufacturer>
12:20:40:834 <manufacturerURL>http://www.dresden-elektronik.de</manufacturerURL>
12:20:40:834 <modelDescription>Philips hue compatible Personal Wireless Lighting</modelDescription>
12:20:40:834 <modelName>Philips hue bridge 2015</modelName>
12:20:40:834 <modelNumber>BSB002</modelNumber>
12:20:40:834 <modelURL>http://www.dresden-elektronik.de</modelURL>
12:20:40:834 <serialNumber>000000000000</serialNumber>
12:20:40:834 <UDN>uuid:182cea9e-b2d5-49ce-ad67-39ed29e2a16c</UDN>
12:20:40:834 <presentationURL>index.html</presentationURL>
12:20:40:834 <iconList>
12:20:40:834 <icon>
12:20:40:834 <mimetype>image/png</mimetype>
12:20:40:834 <height>48</height>
12:20:40:834 <width>48</width>
12:20:40:834 <depth>24</depth>
12:20:40:835 <url>hue_logo_0.png</url>
12:20:40:835 </icon>
12:20:40:835 </iconList>
12:20:40:835 </device>
12:20:40:835 </root>
12:20:40:835 <?xml version="1.0" encoding="UTF-8" ?>
12:20:40:835 <root xmlns="urn:schemas-upnp-org:device-1-0">
12:20:40:835 <specVersion>
12:20:40:835 <major>1</major>
12:20:40:836 <minor>0</minor>
12:20:40:836 </specVersion>
12:20:40:836 <URLBase>http://192.168.0.201:8080/</URLBase>
12:20:40:836 <device>
12:20:40:836 <deviceType>urn:schemas-upnp-org:device:Basic:1</deviceType>
12:20:40:836 <friendlyName>Phoscon-GW (192.168.0.201)</friendlyName>
12:20:40:836 <manufacturer>Royal Philips Electronics</manufacturer>
12:20:40:836 <manufacturerURL>http://www.dresden-elektronik.de</manufacturerURL>
12:20:40:836 <modelDescription>Philips hue compatible Personal Wireless Lighting</modelDescription>
12:20:40:836 <modelName>Philips hue bridge 2015</modelName>
12:20:40:836 <modelNumber>BSB002</modelNumber>
12:20:40:836 <modelURL>http://www.dresden-elektronik.de</modelURL>
12:20:40:836 <serialNumber>000000000000</serialNumber>
12:20:40:836 <UDN>uuid:182cea9e-b2d5-49ce-ad67-39ed29e2a16c</UDN>
12:20:40:837 <presentationURL>index.html</presentationURL>
12:20:40:837 <iconList>
12:20:40:837 <icon>
12:20:40:837 <mimetype>image/png</mimetype>
12:20:40:837 <height>48</height>
12:20:40:837 <width>48</width>
12:20:40:837 <depth>24</depth>
12:20:40:837 <url>hue_logo_0.png</url>
12:20:40:837 </icon>
12:20:40:837 </iconList>
12:20:40:837 </device>
12:20:40:837 </root>
12:20:40:840 [INFO] - Found file containing button maps. Parsing data...
12:20:40:893 [INFO] - Button maps loaded.
12:20:40:895 found node plugin: libde_rest_plugin.so - REST API Plugin
12:20:40:898 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
12:20:40:901 Otau image path does not exist: /home/pi/otau
12:20:40:938 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
12:20:41:097 dlg action: Read binding table
12:20:41:887 UPNP socket not bound, state: 0
12:20:42:051 COM: /dev/ttyAMA0 : (0x0000/0x0000)
12:20:42:052 COM: /dev/ttyS0 : (0x0000/0x0000)
12:20:42:052 dev /dev/ttyS0 (/dev/ttyS0)
12:20:42:054 auto connect com /dev/ttyS0
12:20:43:525 Serial com connected
12:20:43:606 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:20:43:606 device state timeout ignored in state 2
12:20:43:766 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:20:43:766 device state timeout ignored in state 2
12:20:43:925 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:20:43:926 device state timeout ignored in state 2
12:20:44:085 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:20:44:085 device state timeout ignored in state 2
12:20:44:246 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:20:44:246 device state timeout ignored in state 2
12:20:44:406 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:20:44:406 device state timeout ignored in state 2
12:20:44:566 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:20:44:566 device state timeout ignored in state 2
12:20:44:726 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:20:44:726 device state timeout ignored in state 2
12:20:44:886 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:20:44:886 device state timeout ignored in state 2
12:20:45:046 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:20:45:046 device state timeout ignored in state 2
12:20:45:206 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:20:45:206 device state timeout ignored in state 2
12:20:45:366 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:20:45:366 device state timeout (handled)
12:20:45:366 Serial com disconnected, reason: 1
12:20:45:368 device disconnected reason: 1, device index: 0
12:20:45:446 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
12:20:45:446 device state timeout ignored in state 1
12:20:46:082 wait reconnect 15 seconds
12:20:46:190 COM: /dev/ttyAMA0 : (0x0000/0x0000)
12:20:46:191 COM: /dev/ttyS0 : (0x0000/0x0000)
12:20:46:191 dev /dev/ttyS0 (/dev/ttyS0)
12:20:46:191 GW firmware update select /dev/ttyS0 device
12:20:46:191 GW update firmware not found:
12:20:46:451 Announced to internet https://phoscon.de/discover
12:20:46:451 discovery server date: Sat, 01 Jan 2022 12:20:46 GMT
12:20:46:451 local time seems to be ok
12:20:47:026 Skip idle timer callback, too early: elapsed 943 msec
12:20:47:026 wait reconnect 14 seconds
12:20:48:026 wait reconnect 13 seconds
12:20:49:025 DEV Tick.Init: booted after 8000 seconds
12:20:49:025 wait reconnect 12 seconds
12:20:50:026 wait reconnect 11 seconds
12:20:51:025 Daylight now: solarNoon, status: 170, daylight: 1, dark: 0
12:20:51:026 wait reconnect 10 seconds
12:20:52:025 wait reconnect 9 seconds
12:20:53:026 wait reconnect 8 seconds
12:20:54:027 wait reconnect 7 seconds
12:20:55:026 wait reconnect 6 seconds
12:20:56:026 wait reconnect 5 seconds
12:20:56:134 COM: /dev/ttyAMA0 : (0x0000/0x0000)
12:20:56:137 COM: /dev/ttyS0 : (0x0000/0x0000)
12:20:56:137 dev /dev/ttyS0 (/dev/ttyS0)
12:20:56:137 GW firmware update select /dev/ttyS0 device
12:20:56:137 GW update firmware not found:
12:20:57:026 wait reconnect 4 seconds
12:20:58:025 wait reconnect 3 seconds
12:20:59:026 wait reconnect 2 seconds
12:21:00:025 wait reconnect 1 seconds
12:21:00:132 COM: /dev/ttyAMA0 : (0x0000/0x0000)
12:21:00:133 COM: /dev/ttyS0 : (0x0000/0x0000)
12:21:00:133 dev /dev/ttyS0 (/dev/ttyS0)
12:21:00:134 auto connect com /dev/ttyS0
12:21:01:026 Daylight now: solarNoon, status: 170, daylight: 1, dark: 0
12:21:01:559 Serial com connected
12:21:01:638 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:01:638 device state timeout ignored in state 2
12:21:01:798 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:01:798 device state timeout ignored in state 2
12:21:01:958 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:01:958 device state timeout ignored in state 2
12:21:02:026 networkState: CC_ReconnectNetwork
12:21:02:026 start reconnect to network
12:21:02:118 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:02:118 device state timeout ignored in state 2
12:21:02:277 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:02:277 device state timeout ignored in state 2
12:21:02:438 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:02:438 device state timeout ignored in state 2
12:21:02:598 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:02:598 device state timeout ignored in state 2
12:21:02:758 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:02:758 device state timeout ignored in state 2
12:21:02:917 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:02:918 device state timeout ignored in state 2
12:21:03:077 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:03:078 device state timeout ignored in state 2
12:21:03:238 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:03:238 device state timeout ignored in state 2
12:21:03:397 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:03:397 device state timeout (handled)
12:21:03:397 Serial com disconnected, reason: 1
12:21:03:399 device disconnected reason: 1, device index: 0
12:21:03:478 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
12:21:03:478 device state timeout ignored in state 1
12:21:04:026 wait reconnect 15 seconds
12:21:05:026 wait reconnect 14 seconds
12:21:06:026 wait reconnect 13 seconds
12:21:06:141 COM: /dev/ttyAMA0 : (0x0000/0x0000)
12:21:06:141 COM: /dev/ttyS0 : (0x0000/0x0000)
12:21:06:141 dev /dev/ttyS0 (/dev/ttyS0)
12:21:06:142 GW firmware update select /dev/ttyS0 device
12:21:06:142 GW update firmware not found:
12:21:07:025 failed to reconnect to network try=1
12:21:07:026 wait reconnect 12 seconds
12:21:08:026 wait reconnect 11 seconds
12:21:09:026 wait reconnect 10 seconds
12:21:10:026 wait reconnect 9 seconds
12:21:11:025 Daylight now: solarNoon, status: 170, daylight: 1, dark: 0
12:21:11:026 wait reconnect 8 seconds
12:21:12:025 failed to reconnect to network try=2
12:21:12:026 wait reconnect 7 seconds
12:21:13:025 wait reconnect 6 seconds
12:21:14:027 wait reconnect 5 seconds
12:21:15:026 wait reconnect 4 seconds
12:21:16:026 wait reconnect 3 seconds
12:21:16:147 COM: /dev/ttyAMA0 : (0x0000/0x0000)
12:21:16:147 COM: /dev/ttyS0 : (0x0000/0x0000)
12:21:16:147 dev /dev/ttyS0 (/dev/ttyS0)
12:21:16:147 GW firmware update select /dev/ttyS0 device
12:21:16:148 GW update firmware not found:
12:21:17:025 failed to reconnect to network try=3
12:21:17:026 wait reconnect 2 seconds
12:21:18:025 wait reconnect 1 seconds
12:21:18:136 COM: /dev/ttyAMA0 : (0x0000/0x0000)
12:21:18:136 COM: /dev/ttyS0 : (0x0000/0x0000)
12:21:18:137 dev /dev/ttyS0 (/dev/ttyS0)
12:21:18:138 auto connect com /dev/ttyS0
12:21:19:563 Serial com connected
12:21:19:641 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:19:641 device state timeout ignored in state 2
12:21:19:805 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:19:805 device state timeout ignored in state 2
12:21:19:965 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:19:965 device state timeout ignored in state 2
12:21:20:126 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:20:126 device state timeout ignored in state 2
12:21:20:286 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:20:286 device state timeout ignored in state 2
12:21:20:446 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:20:446 device state timeout ignored in state 2
12:21:20:605 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:20:606 device state timeout ignored in state 2
12:21:20:766 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:20:766 device state timeout ignored in state 2
12:21:20:925 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:20:925 device state timeout ignored in state 2
12:21:21:026 Daylight now: solarNoon, status: 170, daylight: 1, dark: 0
12:21:21:085 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:21:085 device state timeout ignored in state 2
12:21:21:246 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:21:246 device state timeout ignored in state 2
12:21:21:405 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
12:21:21:406 device state timeout (handled)
12:21:21:406 Serial com disconnected, reason: 1
12:21:21:407 device disconnected reason: 1, device index: 0
12:21:21:486 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
12:21:21:486 device state timeout ignored in state 1
12:21:22:025 failed to reconnect to network try=4
12:21:22:025 wait reconnect 15 seconds
12:21:23:027 wait reconnect 14 seconds
12:21:24:027 wait reconnect 13 seconds
12:21:25:026 wait reconnect 12 seconds
