New Ikea GU10 bulbs
Hi all,
I have a set of 3 GU10 dimmable white spectrum bulbs (bought them in 2021) and one start flickering and I think I need to replace all 3 just to get the same light level…
It seems that Ikea has some new models of the GU10 bulbs
Color + white TRÅDFRI white spectrum, LED bulb GU10, wireless, dimmable - IKEA Ireland Code: LED2110R3
White spectrum TRÅDFRI warm white, smart LED bulb GU10, wireless, dimmable - IKEA Ireland Code: LED2104R3
Cannot find anywhere if those are supported or not as yet in Deconz / Conbee III (I have home assistant so a little behind deconz version). Has anyone tried those bulbs and confirm that are working?
Many thanks!
LED2110R3 (color) found it in https://github.com/search?q=repo%3Adresden-elektronik%2Fdeconz-rest-plugin%20LED2110R3&type=code so it must be supported :slight_smile:
but LED2104R3 (white spectum) is not mentioned in the code
Anyone owning those can confirm please?
Thank you!
anyone???
Thanks!
ok. I bought the LED2110R3 (color) version and they do work.
One thing that I have noticed is that they are not keeping the status value at power off. I have kooked at parameters in VNC connection and could not find anything. Can things like that be fixed in code or DDF?
In the newer version (LED2110R3) of the multicolor RGB GU10 bulb, there is an issue where the bulb appears in the deCONZ console but does not turn on. The only way to make it work again is by cutting the power. The bulb will not light up again until the power is cycled.
The problem occurs when the bulb has been off for several hours it no longer turns back on via deCONZ, even though it remains visible in the system. However, when the bulb is on, it functions normally, responding to commands as expected. This issue has been observed across multiple bulbs of this model in different fixtures, indicating a recurring problem rather than an isolated defect.
Edit: ConBee II firmware: 26780700
Deconz version: 2.29.1
Hi - I’m having this problem with the LED2110R3.
I’ve 9 lights in the ceiling: 6 LED1923R5 (old version) and 3 LED2110R3 (new).
The 6 lights work fine, but the 3 LED2110R3 are up to date with the latest firmware but stop responding after a few minutes of being powered up.
Update: Deconz and the adapter have been updated, but the this IKEA LED lights still don’t work!
Does not work! Same problems as mentioned above.
ConBee III 26530900
Phoscon 2.29.2
GU10 firmware:
Release Version: 1.28.1
15th Jan 2025
New features and changes in Accessories:
TRÅDFRI color white spectrum bulbs E27/GU10 (1.0.44)
Product ID: LED2109G6, LED2110R3
◆ Update to support new product revisions.
This is disappointing as the older ones work fine - and I’ve not had issue with any other Ikea bulb.
I really don’t want to have to go buy some older ones of Ebay.
Do you think this is Ikea, or some changes to the way the bulb works that needs some code changes in the tool.
Status as of today. No update from Ikea and latest Deconz. Sama problem continue.
Hi I’m not sure what the modelid of the lights is to check if there is already a device support request for it.
If you can open an issue for the light and provide the infors as described in wiki/Request-Device-Support I can add a DDF for it.
If I m right the LED2110R3 are “TRADFRI bulb GU10 CWS 345lm” and are using this DDF deconz-rest-plugin/devices/ikea/tradfri_bulb_cws_A.json at master · dresden-elektronik/deconz-rest-plugin · GitHub
But no idea why they stop responding after a time …
Perhaps with some logs ?
Would be good to know for confirmation that the Model ID is TRADFRI bulb GU10 CWS 345lm.
