I have no idea how things went wrong, but it appears that my deconz setup is in some sort of confused state. I’ve tried it with 2.29 and down-grading back to 2.23… no change. This is on a Windows 10 machine.
When I start deconz the diagram of device appears and does populate arcs between many of them. Some are battery-operated, so won’t always show connections at the start.
However, when I try to use the phoscon web app (either via web browser or android app) I can’t seem to control any of the plugs or lights? I can see that data has updated for motion sensors (lux level, temp, etc).
I’d very much like to avoid starting all over from scratch. As there’s at least two dozen devices and two other automation systems use deconz to reach them. Though I realize that software and configurations can get corrupted over time and it’s often quicker to just start over again. If it was just deconz alone I’d just reset the gateway and start the slog of pairing and renaming all over again.
Before I do that it seems like it’d be worth debugging things a bit to see if there’s something fixable.
Is there documentation on the Debug window messages?
