My task:
When a window sensor reports ‘open’, a lamp
should be switched on after x minutes, for example.
I have
tried to create a schedule via a rule R1. This is not possible.
then I tried to define a schedule that is deactivated and not automatically deleted.
Rule R1 should set the state of schedule to ‘enabled’ when the window is opened.
I thought it would then wait x minutes and then execute the Akticon.
In fact, that doesn’t work either: When the trigger comes,
the schedule is activated, but the action is executed IMMEDIATELY
and not only after the defined period of time x
What am I doing wrong ?
How can I solve the task.
Many thanks for help
