### Link
https://www.aliexpress.com/item/1005005099780623.html
### Database en…try
{"id":80,"type":"EndDevice","ieeeAddr":"0xa4c13863cb90b4be","nwkAddr":28436,"manufId":4417,"manufName":"_TZ3040_bb6xaihh","powerSource":"Battery","modelId":"TS0202","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":1026,"inClusterList":[1,3,4,1280,0],"outClusterList":[4,6,4096,25,10],"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":""}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00212effff07afaa","zoneState":1}}},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":72,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{},"lastSeen":1681655875502,"defaultSendRequestWhen":"immediate"}
### Comments
don't join:
2023-04-16 15:37:50Zigbee: allowing new devices to join.
Info 2023-04-16 15:37:50MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"288zx-15"}'
Info 2023-04-16 15:37:52Device '0xa4c13863cb90b4be' joined
Info 2023-04-16 15:37:53MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c13863cb90b4be","ieee_address":"0xa4c13863cb90b4be"},"type":"device_joined"}'
Info 2023-04-16 15:37:53MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"friendly_name":"0xa4c13863cb90b4be"},"type":"device_connected"}'
Info 2023-04-16 15:37:53MQTT publish: topic 'zigbee2mqtt/0xa4c13863cb90b4be', payload '{"last_seen":"2023-04-16T15:37:53+01:00","linkquality":255}'
Info 2023-04-16 15:37:53Starting interview of '0xa4c13863cb90b4be'
Info 2023-04-16 15:37:53MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c13863cb90b4be","ieee_address":"0xa4c13863cb90b4be","status":"started"},"type":"device_interview"}'
Info 2023-04-16 15:37:53MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_started","meta":{"friendly_name":"0xa4c13863cb90b4be"},"type":"pairing"}'
Debug 2023-04-16 15:37:53Received Zigbee message from 'Sen Mov Quarto RC ZG', type 'read', cluster 'genTime', data '["localTime"]' from endpoint 1 with groupID null
Info 2023-04-16 15:37:53MQTT publish: topic 'zigbee2mqtt/Sen Mov Quarto RC ZG', payload '{"battery":100,"battery_low":false,"keep_time":60,"last_seen":"2023-04-16T15:37:53+01:00","linkquality":255,"occupancy":true,"sensitivity":"medium","tamper":false,"voltage":2900}'
Debug 2023-04-16 15:37:55Received Zigbee message from '0xa4c13863cb90b4be', type 'readResponse', cluster 'genBasic', data '{"stackVersion":0}' from endpoint 1 with groupID null
Debug 2023-04-16 15:37:55Skipping message, definition is undefined and still interviewing
Info 2023-04-16 15:37:55MQTT publish: topic 'zigbee2mqtt/0xa4c13863cb90b4be', payload '{"last_seen":"2023-04-16T15:37:54+01:00","linkquality":255}'
Debug 2023-04-16 15:37:55Received Zigbee message from '0xa4c13863cb90b4be', type 'readResponse', cluster 'genBasic', data '{"dateCode":""}' from endpoint 1 with groupID null
Debug 2023-04-16 15:37:55Received Zigbee message from '0xa4c13863cb90b4be', type 'readResponse', cluster 'genBasic', data '{}' from endpoint 1 with groupID null
Info 2023-04-16 15:37:55MQTT publish: topic 'zigbee2mqtt/0xa4c13863cb90b4be', payload '{"last_seen":"2023-04-16T15:37:55+01:00","linkquality":255}'
Debug 2023-04-16 15:37:55Received Zigbee message from '0xa4c13863cb90b4be', type 'readResponse', cluster 'ssIasZone', data '{"iasCieAddr":"0x00212effff07afaa","zoneState":1}' from endpoint 1 with groupID null
Info 2023-04-16 15:37:55Successfully interviewed '0xa4c13863cb90b4be', device has successfully been paired
Warning 2023-04-16 15:37:55Device '0xa4c13863cb90b4be' with Zigbee model 'TS0202' and manufacturer name '_TZ3040_bb6xaihh' is NOT supported, please follow https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
Info 2023-04-16 15:37:56MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":null,"friendly_name":"0xa4c13863cb90b4be","ieee_address":"0xa4c13863cb90b4be","status":"successful","supported":false},"type":"device_interview"}'
Info 2023-04-16 15:37:56MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_successful","meta":{"friendly_name":"0xa4c13863cb90b4be","supported":false},"type":"pairing"}'
Debug 2023-04-16 15:37:57Received Zigbee message from 'Tomada 7 ZG', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID null
Info 2023-04-16 15:37:57MQTT publish: topic 'zigbee2mqtt/Tomada 7 ZG', payload '{"last_seen":"2023-04-16T15:37:57+01:00","linkquality":255,"state":"OFF"}'
Debug 2023-04-16 15:38:00Received Zigbee message from '0xa4c13863cb90b4be', type 'commandStatusChangeNotification', cluster 'ssIasZone', data '{"extendedstatus":0,"zonestatus":1}' from endpoint 1 with groupID null
Warning 2023-04-16 15:38:00Received message from unsupported device with Zigbee model 'TS0202' and manufacturer name '_TZ3040_bb6xaihh'
Warning 2023-04-16 15:38:00Please see: https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
Info 2023-04-16 15:38:00MQTT publish: topic 'zigbee2mqtt/0xa4c13863cb90b4be', payload '{"last_seen":"2023-04-16T15:37:59+01:00","linkquality":255}'
Debug 2023-04-16 15:38:00Received Zigbee message from '0xa4c13863cb90b4be', type 'read', cluster 'genTime', data '["localTime"]' from endpoint 1 with groupID null
Debug 2023-04-16 15:38:00Received Zigbee message from 'Sen Mov Corredor ZG', type 'commandStatusChangeNotification', cluster 'ssIasZone', data '{"extendedstatus":0,"zonestatus":0}' from endpoint 1 with groupID null
Info 2023-04-16 15:38:00MQTT publish: topic 'zigbee2mqtt/Sen Mov Corredor ZG', payload '{"battery":95,"battery_low":false,"last_seen":"2023-04-16T15:38:00+01:00","linkquality":255,"occupancy":false,"tamper":false,"voltage":2100}'
Debug 2023-04-16 15:38:02Saving state to file /config/zigbee2mqtt/state.json
Debug 2023-04-16 15:38:07Received MQTT message on 'zigbee2mqtt/bridge/request/permit_join' with data '{"device":null,"time":254,"transaction":"288zx-16","value":false}'
Info 2023-04-16 15:38:07Zigbee: disabling joining new devices.
### External converter
_No response_
### Supported color modes
_No response_
### Color temperature range
_No response_
