MOES water valve _TZE284_zm8zpwas support
I bought the MOES Water Valve _TZE284_zm8zpwas, Conbee 2 has no support for it, so I tried to do a DDF, but without luck, the device appears on Phoscon, but the turn on/off don’t do anything (when I press manual it changes his state) , also if I send the Tuya cluster via Deconz gui, the valve works. Anyone has this valve? Can someone make it compatible?
New device MOES water valve _TZE284_zm8zpwas · Koenkk/zigbee2mqtt · Discussion #27771 · GitHub Zigbee2mqtt is already a compatible.
Thanks
next here DDF for MOES gas/water battery valve ( _TZE284_zm8zpwas) · Issue #8317 · dresden-elektronik/deconz-rest-plugin · GitHub
