## Device
- Product name: Tuya ZigBee Smart Knob
- Manufacturer: _TZ3000_qj…a6nq5z
- Model identifier: TS004F
- Device type :
- Switch
- Dimmer
## Screenshots
### Basic
### Identify
### Groups
### On/Off
### Color Control
Huge list (50 items)
### Power Configuration
## Comments
I've followed the instractions that appear here https://github.com/dresden-elektronik/deconz-rest-plugin/issues/6031.
I've modified the DDF, the current one is as follows:
"manufacturername": "_TZ3000_qja6nq5z",
"modelid": "TS004F",
"vendor": "Tuya",
"product": "Smart Knob",
"sleeper": true,
"status": "Gold",
"path": "/devices/backup/tuya/_TZ3000_qja6nq5z_smart_knob.json",
"type": "$TYPE_SWITCH",
"restapi": "/sensors",
"0x01",
"0x1000"
"name": "attr/swversion"
"name": "config/battery",
"refresh.interval": 7300,
"read": {
"at": "0x0021",
"cl": "0x0001",
"ep": 1
"at": "0x0021",
"cl": "0x0001",
"default": 0
"name": "config/on"
"name": "config/reachable"
"name": "state/angle",
"default": 0
"name": "state/bri",
"refresh.interval": 5,
"read": {
"fn": "none"
"cl": "0x0008",
"fn": "zcl",
"script": "_TZ3000_qja6nq5z_smart_knob_buttons.js"
"name": "state/buttonevent"
"name": "state/lastupdated"
"name": "state/on",
"awake": true,
"read": {
"fn": "none"
"cl": "0x0006",
"fn": "zcl",
"bindings": [
"bind": "groupcast",
"config.group": 0,
"cl": "0x0006"
"config.group": 0,
"cl": "0x0008"
"config.group": 0,
"cl": "0x0300"
"cl": "0x0001",
"at": "0x0021",
"dt": "0x20",
"min": 300,
"max": 600,
"change": "0x00000001"
I don't have the original DDF as I didn't make a copy (whoops).
The logs shows this kind of logs:
[INFO] - No button map for: TS004F, broadcast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), command: TOGGLE (0x02), payload: None, zclSeq: 34
[INFO] - No button map for: TS004F, broadcast to: 0x0000, endpoint: 0x01, cluster: LEVEL_CONTROL (0x0008), command: STEP (0x02), payload: 010D0100, zclSeq: 35
Buttons mapping:
Mode ? (I don't know how to identify the mode)
- Single Click -> cluster: ONOFF (0x0006), command: TOGGLE (0x02), payload: None
- Double Click -> Nothing
- Rotate Clockwise -> cluster: LEVEL_CONTROL (0x0008), command: STEP (0x02), payload: 000D0100
- Rotate Counter-Clockwise -> cluster: LEVEL_CONTROL (0x0008), command: STEP (0x02), payload: 01190100
- Push and Rotate Clockwise ->cluster: COLOR_CONTROL (0x0300), command: STEP_COLOR_TEMPERATURE (0x4C), payload: 01340002009900F401
- Push and Rotate Counter-Clockwise -> cluster: COLOR_CONTROL (0x0300), command: STEP_COLOR_TEMPERATURE (0x4C), payload: 03560002009900F401
Mode ?
- Single Click -> cluster: ONOFF (0x0006), command: LIDL (0xFD), payload: 00
- Double Click -> cluster: ONOFF (0x0006), command: LIDL (0xFD), payload: 01
- Rotate Clockwise -> cluster: ONOFF (0x0006), command: 0xFC, payload: 00
- Rotate Counter-Clockwise -> cluster: ONOFF (0x0006), command: 0xFC, payload: 01
- Push and Rotate Clockwise ->Nothing
- Push and Rotate Counter-Clockwise -> Noting
