Moes Tuya Scene Switch Battery Drain
Hey :slight_smile:
I bought this Moes Tuya 3-Way Scene Switch
and have a RaspBee II Coordinator (deconz). In General the Switch works very good but the Battery (CR2430) is down to 2.7 V after a couple of days (maybe 5-6). Then LEDs of the Switch start flashing continuously.
Otherwise I have no problems with my Zigbee network. What could be the reason for this? What other information do you need to be able to help me? What can I do to find out what the problem could be?
Thanks a lot
Jens
I found this Info: Update _TZ3000_ygvf9xzp_4gang_remote.json by sinus61 · Pull Request #6744 · dresden-elektronik/deconz-rest-plugin · GitHub
… but I honestly don’t understand what that means for me or what I have to do to solve the problem
Can try with this DDF
  "uuid": "d333ea82-790f-42e4-ac3b-c255f67a95be",
  "manufacturername": [
    "_TZ3000_gbm10jnj",
    "_TZ3000_sj7jbgks",
    "_TZ3000_w8jwkczz",
    "_TZ3000_famkxci2",
    "_TZ3000_w3c7ouru",
    "_TZ3000_yw5tvzsk",
    "_TZ3000_pkeqinnt"
  "modelid": [
    "TS0043",
    "TS0043",
    "TS0043",
    "TS0043",
    "TS0043",
    "TS0043",
    "TS0043"
  "vendor": "Tuya",
  "product": "3-gang remote (TS0043)",
  "sleeper": false,
  "status": "Gold",
      "type": "$TYPE_SWITCH",
      "restapi": "/sensors",
        "0x01",
        "0x0006"
          "name": "attr/swversion",
          "refresh.interval": 86400,
            "fn": "zcl:attr",
            "cl": "0x0000",
            "at": "0x0001",
            "script": "tuya_swversion.js"
          "read": {
            "fn": "zcl:attr",
            "cl": "0x0000",
            "at": "0x0001"
          "name": "config/battery",
          "awake": true,
          "read": {
            "at": "0x0021",
            "cl": "0x0001",
            "fn": "zcl:attr"
            "at": "0x0021",
            "cl": "0x0001",
          "default": 0
          "name": "config/on"
          "name": "config/reachable"
          "name": "state/buttonevent"
          "name": "state/lastupdated"
          "name": "config/tuya_unlock"
  "bindings": [
      "dst.ep": 1,
      "cl": "0x0006"
      "src.ep": 2,
      "dst.ep": 1,
      "cl": "0x0006"
      "src.ep": 3,
      "dst.ep": 1,
      "cl": "0x0006"
Have added the tuya unlock sequence and removed the bind/report.
Or better edit the devices\tuya_TZ3000_TS0043_3gang_remote.json file.
Hi @Smanar
Thank a lot. i will try it.
to make sure i´m doing it right:
i can not edit it in deconz because i get a “failed to write…” message after editing the DDF inside deconz.
So i did it via the terminal using “sudo nano”.
What do i have todo after editing the file? If i try to open the new file in the deconz DDF editor it also says “Failed to open…”:
so i just restarted deconz.
do i have to delete and add the device to “apply” the changes?
What is your OS ? Real OS or docker ?
Have tried the DDF on external website, it’s fine for me, sudo nano need to work.
Don’t use the editor, too much issues, only use it to check, never to save/edit.
Just edit the file and restart deconz, deconz load DDF only at start, and it need to pick the modified one.
a “real” Raspbian.
I think the modified DDF works but i will monitor the device the next days/weeks and give feedback.
Just to make it clear … if i edit a DDF file via nano …
  1. i have to restart deconz?
  2. do i have to delete an pair the device again?
thanks a lot and merry xmas
Jens
If you have acces to the deconz application, it mean you have a desktop ? Why you don’t use a graphical text editor, by defaut you have Geany.
1- Yes better to restart deconz, it load all DDF at start, like this we are sure it will use it.
2 - Yes better to pair it again, because the tuya unclock sequence (deconz do it at pairing or every 24h), and to reset the bind/report (it’s one cause of the battery drain, it’s removed on the new DDF)
If the device is not reconised > probably typo in the DDF
Hi @nevermind did this solve your issue? It seems I have the exact same model and it drained the battery in just 4 days. Haven’t tried this fix yet, just curious whether it worked for you.
Hi @kvnnap
Yes, Smanars DDF solved the issue.
Have just made a PR to have it officialy, sorry have missed your answer.
