Moes BHT-002 Thermostat with updated model ID TZE204_xalsoe3m
I purchased this thermostat as it was listed as compatible with deCONZ. Whilst this is true, the hardware has been updated and as such, the “manufacturename” is not listed in the DDF. The device currently loads as a smart plug.
The trouble is, as I’m in Home Assistant with the official add-on, I cannot upload a modified version of the current DDF to include the new manufacture name as add-ons are now sandboxed.
Seems like a simple fix to me as hardware functionality is identical.
For info - the current listed hardware is:
“manufacturername”: [
“_TZE200_ztvwu4nk”,
“_TZE200_ye5jkfsb”,
“_TZE204_aoclfnxz”,
“_TZE200_u9bfwha0”
The new one is:
“_TZE204_xalsoe3m”
Thanks.
The problem is we need tests, tuya is making clone of clone and some model can be different.
If you can’t edit the DDF, you can create a new one using the deconz tool Deconz Toolbox
And load it using Phoscon (need to restart it after)
Remember you need to edit 2 lines
  "manufacturername": [
    "_TZE200_ztvwu4nk",
    "_TZE200_ye5jkfsb",
    "_TZE204_aoclfnxz",
    "_TZE200_u9bfwha0",
    "_TZE204_xalsoe3m"
  "modelid": [
    "TS0601",
    "TS0601",
    "TS0601",
    "TS0601",
    "TS0601"
But from that I m reading, you have a new device, eg your device use the dpid 50 for heatpoint and the DDF is using the dpid 16.
All is possible with tuya, you can have same device visualy, buy the same day, at same seller but 2 differents devices.
I did try this - it uploaded fine to Phoscon, but the device didn’t take the DDF after hot-reloading or restarting.
What did work was using SSH from Home Assistant whilst deCONZ was still running and then using nano to edit the current DDF. That worked. It’s now showing all of the correct parameters and I can turn it on and off.
What isn’t right is the heat set point, as you mention. Will try changing it to the value you suggested. It’s also not showing the current temperature and seems to randomly cycle through presets.
So I guess I’m 60% there…
Any further suggestions?
Yes, if you can do that, you can edit the file, and use the “hot relaod” feature in the DDF editor.
But next time you will restart deconz you will loose your changes.
Do you have the GUI ? if yes you take a look, right clic on the node, then edit DDF, on the editor title bar you will see the path/title.
The DDF can have a typo.
The model “_TZE204_xalsoe3m” use
  • the dpid 16 for local temperature
  • the dpid 2 for mode (only auto-manu)
  • the dpid 39 for child lock
  • the dpid 50 for heatpoint
Don’t see something for preset … if you device have it, try to change it manualy on the device and look on deconz log the request send by the device.
Yes - I noticed the changes didn’t hold. What I did to work around it was do the edits using SSH/nano, then open the DDF editor in the deCONZ UI and save it in the default location (then hot-reload). It now sticks after restarting.
Thanks for the dpid values - I’ll try it with those tomorrow and let you know. Happy to help with testing if you let me know what you’d need.
We need tests ^^, your procedure is fine for that.
Even it’s not persistent, after that you will be able to load it using the PR, so you will have it persistent.
Update… With the values you gave, the thermostat is now showing the correct inside temperature and the set point is controllable :+1: Looking good. We’re 95% there.
Small issue I’m seeing is in Home Assistant, the adjustment is in 0.5 degree increments. However, the temperature only changes when making full 1 degree changes, so it’s slightly fiddly. Not sure if that’s a deCONZ issue or a Home Assistant one.
I haven’t had the chance to test it thoroughly or see if any of the preset modes are working (not that I need them). Will update if I notice anything else. But as of now, my wife is happy that she can change the heating from her bed!
Thanks for all of your help so far.
            "fn": "tuya",
            "dpid": 16,
            "eval": "Item.val = Attr.val * 100;"
          "write": {
            "fn": "tuya",
            "dpid": 16,
            "dt": "0x2b",
            "eval": "Item.val / 100;"
          "read": {
            "fn": "tuya"
          "refresh.interval": 84000
It seem it’s from the device.
The device need a value in degre, it don’t handle decimal. So even you send 2250 as value, ths one is divided by 100, and only 22 is send to the device.
NP, do you want to make the PR to add the device officialy or want I make it ? (even we miss the “preset”)
Hey, happy for you to make it. Haven’t seen any further issues so far, so it can wait for now until you have time.
Thanks again!
I m not sure to understand ^^
Do you want to make the PR or do you want I make it ? (to have the device officialy supported)
