Hi all,
I’m using a few Nous A1Z (nous_a1z_smart_plug.json). They are very similar to other tuya based plugs, maybe even the same. But different devices use different DDFs (other plugs I’m using are using NAS-WR01B_TS011F.json).
At first I wondered, why they didn’t report current/voltage/power very often and the found, that in the bindings definition in nous_a1z_smart_plug.json the change value in the report section are set to very high values. After changing all to 1 the reporting worked as expected.
Where should I report this “bug report” best? In the deconz-rest-plugin repository?
Thanks
