Lumi.vibration.aq1 sensor with phantom triggers since deCONZ 2.29.5
No. Because of the regular process:
  1. fix creation
  2. fix merge to beta
  3. wait several beta releases
  4. stable release made of beta releases
  5. on top: wait for HA addon to receive new stable
Now we are at stage 2, not being able to at least check if the fix actually fixes the issue. And the HA addon never got the „feature“ to switch to beta releases (temporarily). So summary:
  1. It takes several months as HA user to receive a new stable deCONZ version.
  2. There is no option to run/test beta releases with the HA deCONZ addon.
  3. A (stable!) deCONZ upgrade introduced the issues. Which now take several months to get fixed. Maybe. User conclusion: don‘t update to new stable releases of deCONZ because you can get screwed. Let other users run into issues (that‘s not the community mindset I like) and wait few weeks, check user reports and monitor next beta releases for fixes related to hardware in place.
Now 25 % of my smart home use-cases are not working. Thanks. I hope you see how frustrating this situation is for users. There‘s no speed, even we are already past stage 1.
Proposal: finally implement a beta release channel option for the HA deCONZ addon. That would be at least a workaround and cool down things, giving low-effort options in case they are needed.
Personal note: next time don’t even try to investigate or report or fix things, but immediately restore addon backup and that way try downgrading deCONZ to maintain the ZigBee smart home fully operational. Long-term: migrate away from deCONZ in case nothing improves after watching and suffering for more than 4 years.
