Loss of signal?
Hi all,
i’m an very happy user of the Conbee II with Domoticz, but i struggle with some troubles…
I have often lost of signals, and what i mean is >
When turning on some lights or an scene (in domoticz), sometimes some lights wont turn on or goes not to its (color/dim)value.
I have some zigbee repeaters / plugs (act as repeater) etc, but still some troubles.
Is it really this signal problem, or something else?
I hope someone can help me out :slight_smile:
Thanks a lot!
Barry
Hello, you are using domoticz scene or zigbee scene ?
Can be a spam request if you make some requests too fastly and don’t use zigbee group feature.
Goodmorning,
Thanks for answering.
Thats an good one.
I use scene on domoticz…
Sometimes it works on first switch, but mostly i need to turn the scene on for several times to push all lamps to its value.
Can i disable this spam detection somewhere?
Before this i used alot of 433mhz stuff and has always worked, but since i use zigbee its often that some lights stays on or does not turning on/dim after 1 click.
I cant found whats the issue in here so far.
Hope someone can found a solution.
Your domoticz scene send how much zigbee request to how much device ?
Have you try to make zigbee group using phoscon ? Groups will be visible in domoticz too, and you can send a command to a group instead of sending 5 request to 5 devices.
Oh… dear, to be honest my scene in domoticz send out to 17 devices.
this is because every device has its own color, that i set as scene in domoticz…
it is 17 devices atm, but there are many more to come.
i think when everything is finished, it will be 40/50 devices.
Is it possible to disable that spam request then?
There is none zigbee or other wifi nearby as only in our house.
btw, i have made several groups like kitchen, outside, garden, etc in phoscon itself, but i do not use these in domoticz (only to turn them off)
the reason is like i said before, i use domoticz with its color-values.
hope to see a fix for this!
thanks
Not possible to disable the spam, but try to avoid it, you can’t use a script that launch all your scenes, 1 by one every 0.5s ?
Because 50 requests in only one time, will be hard, and some request need more than 1 zigbee request ( on/off is a request and the color one more).
You realy need to change all color in same time ?
If you use the GUI, you can take a look in the log (help / debug view) with flag “error” and “error_l2”, but I m sure you will see error “busy” for exemple.
Okay, i’m going to try and let you know later…!
Thanks so far!
hello there :slight_smile:
I was looking for 10 minutes at the debug view error and error_l2, but there is none error, 0, nothing.
also did a scene in domoticz for several times, but both error logs stays empty.
ofcourse there is a lot of polling stuff going on (in info and info_l2), but thats it. :frowning:
so i guess its not the spam?
rsp.list.append(errorToMap(ERR_INTERNAL_ERROR, QString(“/lights/%1/state/effect”).arg(id), QString(“Internal error, %1”).arg(ERR_BRIDGE_BUSY)));
Have you enabled domoticz log ? “debug info only”, I have just see some errors messages are given as return on http request, so they will be visible on domoticz logs
This is my output of Domoticz after set a Scene… :
2021-12-06 19:40:30.648 Zigbee: ### Update device (Zigbee - Hue Moodlight) : {'nValue': 1, 'sValue': '25', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":239,"ww":239,"cw":16}'} 2021-12-06 19:40:30.650 Activating Scene/Group Device: Zigbee - Eettafel (On) 2021-12-06 19:40:30.678 Zigbee: onMessage called 2021-12-06 19:40:30.679 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '15', 'r': 'lights', 'state': {'alert': 'none', 'bri': 137, 'colormode': 'xy', 'ct': 555, 'effect': 'none', 'hue': 4128, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.5603, 0.4182]}, 't': 'event', 'uniqueid': '84:71:27:ff:fe:99:ed:84-01'} 2021-12-06 19:40:30.679 Zigbee: ### Update device (Zigbee - Keukenspot Midden) : {'nValue': 1, 'sValue': '53', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":249,"ww":249,"cw":6}'} 2021-12-06 19:40:30.697 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '18', 'r': 'lights', 'state': {'alert': 'none', 'bri': 137, 'colormode': 'xy', 'ct': 555, 'effect': 'none', 'hue': 3870, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.5603, 0.4182]}, 't': 'event', 'uniqueid': '84:71:27:ff:fe:13:a7:fd-01'} 2021-12-06 19:40:30.697 Zigbee: ### Update device (Zigbee - Keukenspot Airfryer) : {'nValue': 1, 'sValue': '53', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":249,"ww":249,"cw":6}'} 2021-12-06 19:40:30.701 Activating Scene/Group Device: Zigbee - Keukenspot 1 (On) 2021-12-06 19:40:30.731 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '19', 'r': 'lights', 'state': {'alert': 'none', 'bri': 137, 'colormode': 'xy', 'ct': 555, 'effect': 'none', 'hue': 4128, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.5603, 0.4182]}, 't': 'event', 'uniqueid': '84:71:27:ff:fe:8c:cf:ec-01'} 2021-12-06 19:40:30.732 Zigbee: ### Update device (Zigbee - Keukenspot Wasbak) : {'nValue': 1, 'sValue': '53', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":249,"ww":249,"cw":6}'} 2021-12-06 19:40:30.750 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '14', 'r': 'lights', 'state': {'alert': 'none', 'bri': 137, 'colormode': 'xy', 'ct': 555, 'effect': 'none', 'hue': 4386, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.5603, 0.4182]}, 't': 'event', 'uniqueid': '84:71:27:ff:fe:1a:2c:94-01'} 2021-12-06 19:40:30.750 Zigbee: ### Update device (Zigbee - Keukenspot Koffiehoek) : {'nValue': 1, 'sValue': '53', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":249,"ww":249,"cw":6}'} 2021-12-06 19:40:30.752 Activating Scene/Group Device: Zigbee - Keukenspot 2 (On) 2021-12-06 19:40:30.769 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '16', 'r': 'lights', 'state': {'alert': 'none', 'bri': 137, 'colormode': 'xy', 'ct': 555, 'effect': 'none', 'hue': 4128, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.5603, 0.4182]}, 't': 'event', 'uniqueid': '84:71:27:ff:fe:1a:2c:8f-01'} 2021-12-06 19:40:30.770 Zigbee: ### Update device (Zigbee - Keukenspot 2) : {'nValue': 1, 'sValue': '53', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":249,"ww":249,"cw":6}'} 2021-12-06 19:40:30.786 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '17', 'r': 'lights', 'state': {'alert': 'none', 'bri': 137, 'colormode': 'xy', 'ct': 555, 'effect': 'none', 'hue': 3870, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.5603, 0.4182]}, 't': 'event', 'uniqueid': '84:71:27:ff:fe:99:e8:dc-01'} 2021-12-06 19:40:30.787 Zigbee: ### Update device (Zigbee - Keukenspot 1) : {'nValue': 1, 'sValue': '53', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":249,"ww":249,"cw":6}'} 2021-12-06 19:40:30.802 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '9', 'r': 'lights', 'state': {'alert': 'none', 'bri': 254, 'colormode': 'ct', 'ct': 427, 'effect': 'none', 'hue': 0, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.1688, 0.1332]}, 't': 'event', 'uniqueid': 'f0:d1:b8:00:00:12:d4:56-01'} 2021-12-06 19:40:30.802 Zigbee: ### Update device (Zigbee - Hoek veranda links) : {'nValue': 1, 'sValue': '99', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":220,"ww":220,"cw":35}'} 2021-12-06 19:40:30.803 Activating Scene/Group Device: Zigbee - Keukenspot Koffiehoek (On) 2021-12-06 19:40:30.828 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '10', 'r': 'lights', 'state': {'alert': 'none', 'bri': 254, 'colormode': 'ct', 'ct': 427, 'effect': 'none', 'hue': 0, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.1688, 0.1332]}, 't': 'event', 'uniqueid': 'f0:d1:b8:00:00:12:b0:84-01'} 2021-12-06 19:40:30.829 Zigbee: ### Update device (Zigbee - Hoek veranda rechts) : {'nValue': 1, 'sValue': '99', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":220,"ww":220,"cw":35}'} 2021-12-06 19:40:30.854 Activating Scene/Group Device: Zigbee - Keukenspot Wasbak (On) 2021-12-06 19:40:30.856 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '9', 'r': 'lights', 'state': {'alert': 'none', 'bri': 254, 'colormode': 'ct', 'ct': 384, 'effect': 'none', 'hue': 0, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.1688, 0.1332]}, 't': 'event', 'uniqueid': 'f0:d1:b8:00:00:12:d4:56-01'} 2021-12-06 19:40:30.857 Zigbee: ### Update device (Zigbee - Hoek veranda links) : {'nValue': 1, 'sValue': '99', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":206,"ww":206,"cw":49}'} 2021-12-06 19:40:30.876 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '10', 'r': 'lights', 'state': {'alert': 'none', 'bri': 254, 'colormode': 'ct', 'ct': 384, 'effect': 'none', 'hue': 0, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.1688, 0.1332]}, 't': 'event', 'uniqueid': 'f0:d1:b8:00:00:12:b0:84-01'} 2021-12-06 19:40:30.876 Zigbee: ### Update device (Zigbee - Hoek veranda rechts) : {'nValue': 1, 'sValue': '99', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":206,"ww":206,"cw":49}'} 2021-12-06 19:40:30.897 Zigbee: onCommand called for Unit 31: Parameter 'Set Color', Level: 11, Hue: {"b":0,"cw":0,"g":0,"m":2,"r":0,"t":255,"ww":255} 2021-12-06 19:40:30.897 Zigbee: Send Command /api/96DAA2F2CB/groups/13/action with {'on': True, 'ct': 588, 'bri': 28, 'transitiontime': 0} (0 in buffer) 2021-12-06 19:40:30.897 Zigbee: Making Request: http://zigbee.bnet:80/api/96DAA2F2CB/groups/13/action with params {'on': True, 'ct': 588, 'bri': 28, 'transitiontime': 0} 2021-12-06 19:40:30.905 Activating Scene/Group Device: Zigbee - Keukenspot Airfryer (On) 2021-12-06 19:40:30.911 Zigbee: Request Return: [{"success":{"/groups/13/action/on":true}},{"success":{"/groups/13/action/bri":28}},{"success":{"/groups/13/action/ct":588}}] 2021-12-06 19:40:30.912 Zigbee: Classic Data : [{'success': {'/groups/13/action/on': True}}, {'success': {'/groups/13/action/bri': 28}}, {'success': {'/groups/13/action/ct': 588}}] 2021-12-06 19:40:30.912 Zigbee: onCommand called for Unit 23: Parameter 'Set Color', Level: 50, Hue: {"b":0,"cw":0,"g":164,"m":3,"r":255,"t":0,"ww":0} 2021-12-06 19:40:30.912 Zigbee: Send Command /api/96DAA2F2CB/lights/17/state with {'on': True, 'xy': [0.570374, 0.409637], 'bri': 127, 'transitiontime': 0} (0 in buffer) 2021-12-06 19:40:30.912 Zigbee: Making Request: http://zigbee.bnet:80/api/96DAA2F2CB/lights/17/state with params {'on': True, 'xy': [0.570374, 0.409637], 'bri': 127, 'transitiontime': 0} 2021-12-06 19:40:30.923 Zigbee: Request Return: [{"success":{"/lights/17/state/on":true}},{"success":{"/lights/17/state/bri":127}},{"error":{"address":"/lights/17/state/xy","description":"Internal error, 951","type":901}}] 2021-12-06 19:40:30.924 Zigbee: Classic Data : [{'success': {'/lights/17/state/on': True}}, {'success': {'/lights/17/state/bri': 127}}, {'error': {'address': '/lights/17/state/xy', 'description': 'Internal error, 951', 'type': 901}}] 2021-12-06 19:40:30.924 Zigbee: onCommand called for Unit 22: Parameter 'Set Color', Level: 73, Hue: {"b":0,"cw":0,"g":167,"m":3,"r":255,"t":0,"ww":0} 2021-12-06 19:40:30.924 Zigbee: Send Command /api/96DAA2F2CB/lights/16/state with {'on': True, 'xy': [0.56606, 0.413292], 'bri': 185, 'transitiontime': 0} (0 in buffer) 2021-12-06 19:40:30.924 Zigbee: Making Request: http://zigbee.bnet:80/api/96DAA2F2CB/lights/16/state with params {'on': True, 'xy': [0.56606, 0.413292], 'bri': 185, 'transitiontime': 0} 2021-12-06 19:40:30.938 Zigbee: Request Return: [{"success":{"/lights/16/state/on":true}},{"error":{"address":"/lights/16/state/bri","description":"Internal error, 951","type":901}},{"error":{"address":"/lights/16/state/xy","description":"Internal error, 951","type":901}}] 2021-12-06 19:40:30.938 Zigbee: Classic Data : [{'success': {'/lights/16/state/on': True}}, {'error': {'address': '/lights/16/state/bri', 'description': 'Internal error, 951', 'type': 901}}, {'error': {'address': '/lights/16/state/xy', 'description': 'Internal error, 951', 'type': 901}}] 2021-12-06 19:40:30.938 Zigbee: onCommand called for Unit 20: Parameter 'Set Color', Level: 64, Hue: {"b":10,"cw":0,"g":173,"m":3,"r":255,"t":0,"ww":0} 2021-12-06 19:40:30.938 Zigbee: Send Command /api/96DAA2F2CB/lights/14/state with {'on': True, 'xy': [0.557228, 0.420486], 'bri': 163, 'transitiontime': 0} (0 in buffer) 2021-12-06 19:40:30.938 Zigbee: Making Request: http://zigbee.bnet:80/api/96DAA2F2CB/lights/14/state with params {'on': True, 'xy': [0.557228, 0.420486], 'bri': 163, 'transitiontime': 0} 2021-12-06 19:40:30.950 Zigbee: Request Return: [{"error":{"address":"/lights/14/state/on","description":"Internal error, 951","type":901}},{"error":{"address":"/lights/14/state/bri","description":"Internal error, 951","type":901}},{"error":{"address":"/lights/14/state/xy","description":"Internal error, 951","type":901}}] 2021-12-06 19:40:30.950 Zigbee: Classic Data : [{'error': {'address': '/lights/14/state/on', 'description': 'Internal error, 951', 'type': 901}}, {'error': {'address': '/lights/14/state/bri', 'description': 'Internal error, 951', 'type': 901}}, {'error': {'address': '/lights/14/state/xy', 'description': 'Internal error, 951', 'type': 901}}] 2021-12-06 19:40:30.951 Zigbee: onCommand called for Unit 25: Parameter 'Set Color', Level: 66, Hue: {"b":0,"cw":0,"g":168,"m":3,"r":255,"t":0,"ww":0} 2021-12-06 19:40:30.951 Zigbee: Send Command /api/96DAA2F2CB/lights/19/state with {'on': True, 'xy': [0.564618, 0.414513], 'bri': 168, 'transitiontime': 0} (0 in buffer) 2021-12-06 19:40:30.951 Zigbee: Making Request: http://zigbee.bnet:80/api/96DAA2F2CB/lights/19/state with params {'on': True, 'xy': [0.564618, 0.414513], 'bri': 168, 'transitiontime': 0} 2021-12-06 19:40:30.955 Activating Scene/Group Device: Zigbee - Keukenspot Midden (On) 2021-12-06 19:40:30.963 Zigbee: Request Return: [{"error":{"address":"/lights/19/state/on","description":"Internal error, 951","type":901}},{"error":{"address":"/lights/19/state/bri","description":"Internal error, 951","type":901}},{"error":{"address":"/lights/19/state/xy","description":"Internal error, 951","type":901}}] 2021-12-06 19:40:30.963 Zigbee: Classic Data : [{'error': {'address': '/lights/19/state/on', 'description': 'Internal error, 951', 'type': 901}}, {'error': {'address': '/lights/19/state/bri', 'description': 'Internal error, 951', 'type': 901}}, {'error': {'address': '/lights/19/state/xy', 'description': 'Internal error, 951', 'type': 901}}] 2021-12-06 19:40:30.963 Zigbee: onCommand called for Unit 24: Parameter 'Set Color', Level: 63, Hue: {"b":0,"cw":0,"g":164,"m":3,"r":255,"t":0,"ww":0} 2021-12-06 19:40:30.964 Zigbee: Send Command /api/96DAA2F2CB/lights/18/state with {'on': True, 'xy': [0.570374, 0.409637], 'bri': 160, 'transitiontime': 0} (0 in buffer) 2021-12-06 19:40:30.964 Zigbee: Making Request: http://zigbee.bnet:80/api/96DAA2F2CB/lights/18/state with params {'on': True, 'xy': [0.570374, 0.409637], 'bri': 160, 'transitiontime': 0} 2021-12-06 19:40:30.975 Zigbee: Request Return: [{"error":{"address":"/lights/18/state/on","description":"Internal error, 951","type":901}},{"error":{"address":"/lights/18/state/bri","description":"Internal error, 951","type":901}},{"error":{"address":"/lights/18/state/xy","description":"Internal error, 951","type":901}}] 2021-12-06 19:40:30.975 Zigbee: Classic Data : [{'error': {'address': '/lights/18/state/on', 'description': 'Internal error, 951', 'type': 901}}, {'error': {'address': '/lights/18/state/bri', 'description': 'Internal error, 951', 'type': 901}}, {'error': {'address': '/lights/18/state/xy', 'description': 'Internal error, 951', 'type': 901}}] 2021-12-06 19:40:30.975 Zigbee: onCommand called for Unit 21: Parameter 'Set Color', Level: 34, Hue: {"b":0,"cw":0,"g":167,"m":3,"r":255,"t":0,"ww":0} 2021-12-06 19:40:30.975 Zigbee: Send Command /api/96DAA2F2CB/lights/15/state with {'on': True, 'xy': [0.56606, 0.413292], 'bri': 86, 'transitiontime': 0} (0 in buffer) 2021-12-06 19:40:30.975 Zigbee: Making Request: http://zigbee.bnet:80/api/96DAA2F2CB/lights/15/state with params {'on': True, 'xy': [0.56606, 0.413292], 'bri': 86, 'transitiontime': 0} 2021-12-06 19:40:30.985 Zigbee: Request Return: [{"error":{"address":"/lights/15/state/on","description":"Internal error, 951","type":901}},{"error":{"address":"/lights/15/state/bri","description":"Internal error, 951","type":901}},{"error":{"address":"/lights/15/state/xy","description":"Internal error, 951","type":901}}] 2021-12-06 19:40:30.985 Zigbee: Classic Data : [{'error': {'address': '/lights/15/state/on', 'description': 'Internal error, 951', 'type': 901}}, {'error': {'address': '/lights/15/state/bri', 'description': 'Internal error, 951', 'type': 901}}, {'error': {'address': '/lights/15/state/xy', 'description': 'Internal error, 951', 'type': 901}}] 2021-12-06 19:40:30.985 Zigbee: onMessage called 2021-12-06 19:40:30.986 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '12', 'r': 'lights', 'state': {'alert': 'none', 'bri': 71, 'colormode': 'hs', 'ct': 153, 'effect': 'none', 'hue': 47502, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.2751, 0.1112]}, 't': 'event', 'uniqueid': '84:71:27:ff:fe:97:e3:3f-01'} 2021-12-06 19:40:30.986 Zigbee: ### Update device (Zigbee - Spotje bij kast Links) : {'nValue': 1, 'sValue': '27', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":0,"ww":0,"cw":255}'} 2021-12-06 19:40:31.007 Activating Scene/Group Device: Zigbee - Tuinspots (On) 2021-12-06 19:40:31.044 Zigbee: onMessage called 2021-12-06 19:40:31.045 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '11', 'r': 'lights', 'state': {'alert': 'none', 'bri': 89, 'colormode': 'hs', 'ct': 153, 'effect': 'none', 'hue': 43090, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.1296, 0.0552]}, 't': 'event', 'uniqueid': '84:71:27:ff:fe:97:ef:24-01'} 2021-12-06 19:40:31.046 Zigbee: ### Update device (Zigbee - Spotje bij kast Rechts) : {'nValue': 1, 'sValue': '34', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":0,"ww":0,"cw":255}'} 2021-12-06 19:40:31.079 Zigbee: ### WebSocket Data : {'attr': {'colorcapabilities': 0, 'ctmax': 65279, 'ctmin': 0, 'id': '16', 'lastannounced': '2021-11-14T18:09:41Z', 'lastseen': '2021-12-06T18:40Z', 'manufacturername': 'LDS', 'modelid': 'ZBT-RGBWLight-M0000', 'name': 'Keukenspot 3', 'swversion': '2.08.03', 'type': 'Extended color light', 'uniqueid': '84:71:27:ff:fe:1a:2c:8f-01'}, 'e': 'changed', 'id': '16', 'r': 'lights', 't': 'event', 'uniqueid': '84:71:27:ff:fe:1a:2c:8f-01'} 2021-12-06 19:40:31.079 Zigbee: onMessage called 2021-12-06 19:40:31.079 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '22', 'r': 'lights', 'state': {'alert': 'none', 'bri': 28, 'colormode': 'ct', 'ct': 588, 'on': True, 'reachable': True}, 't': 'event', 'uniqueid': '00:15:8d:00:01:27:50:f6-01'} 2021-12-06 19:40:31.080 Zigbee: ### Update device (Zigbee - Eettafel 3) : {'nValue': 1, 'sValue': '10', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":255,"ww":255,"cw":0}'} 2021-12-06 19:40:31.108 Zigbee: onMessage called 2021-12-06 19:40:31.109 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '23', 'r': 'lights', 'state': {'alert': 'none', 'bri': 28, 'colormode': 'ct', 'ct': 588, 'on': True, 'reachable': True}, 't': 'event', 'uniqueid': '00:15:8d:00:01:27:53:97-01'} 2021-12-06 19:40:31.110 Zigbee: ### Update device (Zigbee - Eettafel 2) : {'nValue': 1, 'sValue': '10', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":255,"ww":255,"cw":0}'} 2021-12-06 19:40:31.129 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '20', 'r': 'lights', 'state': {'alert': 'none', 'bri': 28, 'colormode': 'ct', 'ct': 588, 'on': True, 'reachable': True}, 't': 'event', 'uniqueid': '00:15:8d:00:01:26:d5:76-01'} 2021-12-06 19:40:31.129 Zigbee: ### Update device (Zigbee - Eettafel 1) : {'nValue': 1, 'sValue': '10', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":255,"ww":255,"cw":0}'} 2021-12-06 19:40:31.149 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '21', 'r': 'lights', 'state': {'alert': 'none', 'bri': 28, 'colormode': 'ct', 'ct': 588, 'on': True, 'reachable': True}, 't': 'event', 'uniqueid': '00:15:8d:00:01:27:39:5f-01'} 2021-12-06 19:40:31.149 Zigbee: ### Update device (Zigbee - Eettafel 4) : {'nValue': 1, 'sValue': '10', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":255,"ww":255,"cw":0}'} 2021-12-06 19:40:31.167 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '17', 'r': 'lights', 'state': {'alert': 'none', 'bri': 127, 'colormode': 'xy', 'ct': 555, 'effect': 'none', 'hue': 3870, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.5603, 0.4182]}, 't': 'event', 'uniqueid': '84:71:27:ff:fe:99:e8:dc-01'} 2021-12-06 19:40:31.168 Zigbee: ### Update device (Zigbee - Keukenspot 1) : {'nValue': 1, 'sValue': '49', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":249,"ww":249,"cw":6}'} 2021-12-06 19:40:31.185 Zigbee: ### WebSocket Data : {'attr': {'colorcapabilities': 0, 'ctmax': 65279, 'ctmin': 0, 'id': '17', 'lastannounced': '2021-11-15T07:47:05Z', 'lastseen': '2021-12-06T18:40Z', 'manufacturername': 'LDS', 'modelid': 'ZBT-RGBWLight-M0000', 'name': 'Keukenspot Koffiehoek', 'swversion': '2.08.03', 'type': 'Extended color light', 'uniqueid': '84:71:27:ff:fe:99:e8:dc-01'}, 'e': 'changed', 'id': '17', 'r': 'lights', 't': 'event', 'uniqueid': '84:71:27:ff:fe:99:e8:dc-01'} 2021-12-06 19:40:31.185 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '17', 'r': 'lights', 'state': {'alert': 'none', 'bri': 137, 'colormode': 'xy', 'ct': 555, 'effect': 'none', 'hue': 3870, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.5603, 0.4182]}, 't': 'event', 'uniqueid': '84:71:27:ff:fe:99:e8:dc-01'} 2021-12-06 19:40:31.186 Zigbee: ### Update device (Zigbee - Keukenspot 1) : {'nValue': 1, 'sValue': '53', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":249,"ww":249,"cw":6}'} 2021-12-06 19:40:31.200 Zigbee: ### WebSocket Data : {'attr': {'colorcapabilities': 0, 'ctmax': 65279, 'ctmin': 0, 'id': '14', 'lastannounced': '2021-11-15T07:47:29Z', 'lastseen': '2021-12-06T18:40Z', 'manufacturername': 'LDS', 'modelid': 'ZBT-RGBWLight-M0000', 'name': 'Keukenspot Links', 'swversion': '2.08.03', 'type': 'Extended color light', 'uniqueid': '84:71:27:ff:fe:1a:2c:94-01'}, 'e': 'changed', 'id': '14', 'r': 'lights', 't': 'event', 'uniqueid': '84:71:27:ff:fe:1a:2c:94-01'} 2021-12-06 19:40:31.201 Zigbee: onCommand called for Unit 1: Parameter 'Set Color', Level: 100, Hue: {"b":0,"cw":38,"g":0,"m":2,"r":0,"t":217,"ww":217} 2021-12-06 19:40:31.201 Zigbee: Send Command /api/96DAA2F2CB/lights/1/state with {'on': True, 'ct': 414, 'bri': 254, 'transitiontime': 0} (0 in buffer) 2021-12-06 19:40:31.201 Zigbee: Making Request: http://zigbee.bnet:80/api/96DAA2F2CB/lights/1/state with params {'on': True, 'ct': 414, 'bri': 254, 'transitiontime': 0} 2021-12-06 19:40:31.222 Zigbee: Request Return: [{"error":{"address":"/lights/1/state","description":"resource, /lights/1/state, is not modifiable. Device is not reachable.","type":202}}] 2021-12-06 19:40:31.223 Zigbee: Classic Data : [{'error': {'address': '/lights/1/state', 'description': 'resource, /lights/1/state, is not modifiable. Device is not reachable.', 'type': 202}}] 2021-12-06 19:40:31.223 Zigbee: onMessage called 2021-12-06 19:40:31.223 Zigbee: ### WebSocket Data : {'attr': {'colorcapabilities': 0, 'ctmax': 65279, 'ctmin': 0, 'id': '19', 'lastannounced': None, 'lastseen': '2021-12-06T18:40Z', 'manufacturername': 'LDS', 'modelid': 'ZBT-RGBWLight-M0000', 'name': 'Keukenspot Wasbak', 'swversion': '2.08.03', 'type': 'Extended color light', 'uniqueid': '84:71:27:ff:fe:8c:cf:ec-01'}, 'e': 'changed', 'id': '19', 'r': 'lights', 't': 'event', 'uniqueid': '84:71:27:ff:fe:8c:cf:ec-01'} 2021-12-06 19:40:31.674 Zigbee: onMessage called 2021-12-06 19:40:31.675 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '17', 'r': 'lights', 'state': {'alert': 'none', 'bri': 127, 'colormode': 'xy', 'ct': 555, 'effect': 'none', 'hue': 3870, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.5603, 0.4182]}, 't': 'event', 'uniqueid': '84:71:27:ff:fe:99:e8:dc-01'} 2021-12-06 19:40:31.676 Zigbee: ### Update device (Zigbee - Keukenspot 1) : {'nValue': 1, 'sValue': '49', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":249,"ww":249,"cw":6}'} 2021-12-06 19:40:32.056 Zigbee: onMessage called 2021-12-06 19:40:32.056 Zigbee: ### WebSocket Data : {'attr': {'colorcapabilities': 0, 'ctmax': 65279, 'ctmin': 0, 'id': '23', 'lastannounced': None, 'lastseen': '2021-12-06T18:40Z', 'manufacturername': 'ZigBee/CCT', 'modelid': 'CCT Light', 'name': 'Eettafel 2', 'swversion': '00.00.01', 'type': 'Color temperature light', 'uniqueid': '00:15:8d:00:01:27:53:97-01'}, 'e': 'changed', 'id': '23', 'r': 'lights', 't': 'event', 'uniqueid': '00:15:8d:00:01:27:53:97-01'} 2021-12-06 19:40:33.083 Zigbee: onHeartbeat called 2021-12-06 19:40:33.584 Zigbee: onMessage called 2021-12-06 19:40:33.585 Zigbee: ### WebSocket Data : {'attr': {'colorcapabilities': 0, 'ctmax': 65279, 'ctmin': 0, 'id': '12', 'lastannounced': '2021-11-14T09:29:26Z', 'lastseen': '2021-12-06T18:40Z', 'manufacturername': 'LDS', 'modelid': 'ZBT-RGBWLight-M0000', 'name': 'Spotje bij kast links', 'swversion': '2.08.03', 'type': 'Extended color light', 'uniqueid': '84:71:27:ff:fe:97:e3:3f-01'}, 'e': 'changed', 'id': '12', 'r': 'lights', 't': 'event', 'uniqueid': '84:71:27:ff:fe:97:e3:3f-01'} 2021-12-06 19:40:33.585 Zigbee: onMessage called 2021-12-06 19:40:33.585 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '12', 'r': 'lights', 'state': {'alert': 'none', 'bri': 71, 'colormode': 'hs', 'ct': 153, 'effect': 'none', 'hue': 47732, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.2751, 0.1112]}, 't': 'event', 'uniqueid': '84:71:27:ff:fe:97:e3:3f-01'} 2021-12-06 19:40:33.586 Zigbee: ### Update device (Zigbee - Spotje bij kast Links) : {'nValue': 1, 'sValue': '27', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":0,"ww":0,"cw":255}'} 2021-12-06 19:40:33.653 Zigbee: onMessage called 2021-12-06 19:40:33.656 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '10', 'r': 'lights', 'state': {'alert': 'none', 'bri': 254, 'colormode': 'ct', 'ct': 384, 'effect': 'none', 'hue': 0, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.1688, 0.1332]}, 't': 'event', 'uniqueid': 'f0:d1:b8:00:00:12:b0:84-01'} 2021-12-06 19:40:33.658 Zigbee: ### Update device (Zigbee - Hoek veranda rechts) : {'nValue': 1, 'sValue': '99', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":206,"ww":206,"cw":49}'} 2021-12-06 19:40:35.835 Zigbee: onMessage called 2021-12-06 19:40:35.838 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '9', 'r': 'lights', 'state': {'alert': 'none', 'bri': 254, 'colormode': 'ct', 'ct': 384, 'effect': 'none', 'hue': 0, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.1688, 0.1332]}, 't': 'event', 'uniqueid': 'f0:d1:b8:00:00:12:d4:56-01'} 2021-12-06 19:40:35.840 Zigbee: ### Update device (Zigbee - Hoek veranda links) : {'nValue': 1, 'sValue': '99', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":206,"ww":206,"cw":49}'} 2021-12-06 19:40:36.824 Zigbee: onMessage called 2021-12-06 19:40:36.827 Zigbee: ### WebSocket Data : {'e': 'changed', 'id': '19', 'r': 'lights', 'state': {'alert': 'none', 'bri': 137, 'colormode': 'xy', 'ct': 555, 'effect': 'none', 'hue': 4386, 'on': True, 'reachable': True, 'sat': 254, 'xy': [0.5603, 0.4182]}, 't': 'event', 'uniqueid': '84:71:27:ff:fe:8c:cf:ec-01'} 2021-12-06 19:40:36.829 Zigbee: ### Update device (Zigbee - Keukenspot Wasbak) : {'nValue': 1, 'sValue': '53', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":249,"ww":249,"cw":6}'}
951 > bridge busy
Gateway is spammed, too much request in a short time.
Ah, really… damn, thats not funny.
Then i have todo all scene stuff in deconz itself.
Okay, i’m going to do that…
Thanks, will let you know!
I made some scenes in deconz itself and use them a couple days, but the problems remains.
It’s even worser then before, some lights wont turn on at all :face_with_monocle:
I switched back to the scene / devices in domoticz…
Using raspberry 4b / 4gb (deconz image) with only as deconz gateway, cpu usage 2/3%, memory 184 of 4gb used.
dunno what the problem is in here…
Ha nope, I don’t speak about scene, but group, zigbee group, it s a zigbee feature used to send less request, 1 group request (broadcast) instead of 10 requests for the 10 devices (unicast).
But I remember now, you can’t use group because all devices need to have a different color ? You can have a group for 10 device that will work same ?
If not the only way I m seing is using a queue list, send all requests spaced by 0.5s for exemple.
Sorry, i mean a scene ofcourse!! :stuck_out_tongue:
So you can “group” your devices to use EXACTLY the same request for more than 3/4 devices ?
Interesting subject. I will follow this with interest. Not to hi-jack this topic but I am having similar issues operating my ZigBee roller shutters. They too are not always reacting to commands from Domoticz although the shutters are activated around 5 seconds apart.
Pardon, what do you mean exactly?
omg… I see… There is a “group” and a “scene”, so far i’m using a group to turn on or off devices.
now i see i didnt make any scene at all as i can’t make any scene!
this is because i’m using a phone and tablet and getting an screen errors on this devices! how stupid…
That’s the reason i couldnt set a scene because it need an laptop or bigger screen to set it up, but my laptop is in our office far away from where i need the scenes! haha…
how is it possible to make any scene on phone and/or tablet then?
i did a try with desktop mode in chrome, but that also didnt work.
not handy at all :frowning:
i guess most people wants to use their mobile phone to make a scene, since this is the easiest way that is IN the place where you NEED the scene without the use of a laptop?!
now i remember again, that was the main reason why i’m using the scenes from inside domoticz itself, i just couldnt create a scene in the browser on a mobile phone.
Nope scene is another thing.
I m speaking about group Phoscon App to use the zigbee group feature.
If you put 20 device in a group, you can send only 1 request for the 20 devices.
But for that you need the 20 devices need the same command, you can’t set a different color for each.
@Sjonnie it s battery Shutter ? You have the same error message in logs ? how many shutters ?
Hi Smanar,
No specific errors in Domoticz log:
2021-12-06 02:22:32.444 Error: YouLess hardware (17) thread seems to have ended unexpectedly
2021-12-06 22:10:04.145 Error: ConBee2: (ConBee2) Device not ready : 2
2021-12-07 04:43:06.218 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2021-12-07 22:10:04.108 Error: ConBee2: (ConBee2) Device not ready : 2
2021-12-08 22:10:04.174 Error: ConBee2: (ConBee2) Device not ready : 2
2021-12-09 22:10:04.109 Error: ConBee2: (ConBee2) Device not ready : 2
2021-12-10 22:10:04.138 Error: ConBee2: (ConBee2) Device not ready : 2
2021-12-11 22:10:04.150 Error: ConBee2: (ConBee2) Device not ready : 2
The devices are 230V devices of the type TS130F (Vendor: _TZ3000_vd43bbfq). I have ten of these in use. Two or three of them are always working. The other ones intermittently fail :expressionless:
Note: the Error: Conbee2: (Conbee2) Device not ready:2 is probably caused by starting a back-up to external SSD on my Pi at that time.
