My bad, the correct folder was : /home/jeedom/.local/share/dresden-elektronik/deCONZ/devices but there was no folder inside this one.
I have updated deconz, I am now using version 2.18.2 but I still cannot include the device. I have access to GUI, but I do not know how to check if the device has a problem, using help > log ?
1 - Have you the device node visible in the application ? If no, the inclusion have failed, not a problem with DDF, can be for exemple a problem in the reset procedure, or a connexion issue.
2 - If the node is visible, how is his name ? if it’s something like 0xXXXX the reconisation by the API have failed (here can be a DDF issue)
3 - If the name is something readable, the device is somewhere in the API
Remember the inclusion is make using jeedom or phoscon (add new sensor), not deconz.
You can see logs in deconz / help / debug view with flags “error” “error_l2” “info_l2” and “info” (the last one can be too much talkative)
Au départ, ZLinky_TIC est en attente d’appairage mais si vous souhaitez réinitialiser l’appareil, il suffit de rester appuyer sur le bouton “link” pendant 10 secondes. Ensuite, le bouton relâché, la Led s’éteint puis se met à clignoter.
Une fois appairé à votre box domotique par l’intermédiaire d’une ZiGate ou d’un autre coordinateur ZigBee, vous pourrez gérer votre consommation d’électricité.
hello
I face some issue to setup lixee with conbeII (firmware 26780700) & deconz (V2.18.2) .I have a conbeeII on my computer, I plug lixee on linky ( triphasé / historique/ PHC), lixee was paired, I see a node called Power2 00158D0005CE7653
but inside no cluster info, everything is at zero
I try with several DDF ( all three from lixee folder), and I had one proposed by smanar soem weeks ago for triphasé.
can someone should help me please? Up tu now I didn’t really understand how the DDF files is working and what we have to change in order to record specific address fro the zigbee node.
BR
You mean in deconz ? in the application ? you have 2 circle on right, clic on the second one to expand cluster, if you have only 1 circle mean the inclusion is not perfect
But if the device name have changed from 0xXXXX to “Power2” it’s a good sign, mean the inclusion have worked and the device is reconised in the API
You can check the API using for exemple phoscon / help / API Information / sensors (or event to see device report)
C:…\Local\dresden-elektronik\deCONZ\devices\lixee\zlinky_tic_historique_mono_base.json
In deconz, , yes I have 2 circle
I try to put a snapshot below, I don’t know if it will work
Ok so you have a problem with the OS (or deconz installation), deconz miss an xml config file. But it seem it don’t block the API working mode.
Perhaps a new installtion with the last official version can solve the problem. Right issue perhaps ?
On the ZHAPower all seem fine except the voltage.
On the ZHAconsumption, 0 for consumption, I think there is problem here ^^
But have you the link to the DDF you are using for I correct it, not the path on your computer ^^. (there are so much DDF in all issues …)
It start working so your procedure seem good, probably just need to adapt the DDF.
thank’s , I reinstall deCONZ and now I see the cluster info
for the DDF it’s this one for triphase (see below)
you are right there is an issue with voltage and also on AC measurement, on Phase A I have the parameter Activepower, reactive power , apparent power ( 0x050B, 0x050E,0x050F)
hello, as I really would like to know what is my consuption phase by phase, I ask EDF to change my TIC setting from historique to standard.
It will permit to have all information (tension, current, energy phase by phase). What do I need to change on my json files to make a standart triphase HPHC?
So first remember you already have the current by phase, it s the power image, you just need to * 230.
It’s not possible having consumption by phase
You can have the power by phase on standard (that is the current image) with attributes 0x050F, 0x090F, 0x0A0F.
But the problem is deconz don’t have power_1 power_2 and power3 for exemple, so need to create fake endpoint, it mean you will have 3 ZHAPower
Something like
hi
yes my report was every 5min, I rty to go to 10s but it fail, now I’m back to 1 mn, I found additionnal issue, tension of phase 2 &3 are not well reported, and CCASN (0X050B) too, so I try to modify DDF, please can you check if it’s look good or not?
there is something which not work, because on deconz app I saw all param (including all voltage and CCASN) but on phoscon app value from phase 2&3 (power/voltage) are stuck at 0. So probably a mistake on the DDF
Yes, it’s the minimum recommended by the dev from my memory.
This device is not made for “real time”, beter to use low reporting.
Phoscon is not reliable, you are looking direclty in the API ? Phoscon/help/API Information/sensors or using third app ? Remember you have 1 sensor by phase
For CCASN, what is it ? “Point n de la courbe de charge active soutirée” ?
I have found some problem for voltage, but nothing for power, I m using attribute 0x050F, 0x050B and 0x090F
Can you try to make a “hot reload” in the DDf editor, to reconfigure bind ?
When you read the value in the GUI, it need to update the value in the API, if yes, binding issue, else DDF issue.
I hope it’s not because of fake endpoint I m using.
hello
thank’s it work well now, for the power it was my mistake, with previous json it was already ok
even if it’s setup with 60s, I still have report every 5 mn, anyway, the only thing which is not working is the ZHAconsumption, I see the node on Jeedom/deconz, but I don’t have the command on the equipment, I will try to make myself the command but not sure how to do it (if only using the name is enough or we need something else)
ok, I answer myself, now it works for the consumption, I probably made a mistake yesterday
so now all good for lixee on a triphase network
thank’s a lot for your help
