Herewith is the DDF file I use
"manufacturername": "LiXee",
"modelid": "ZLinky_TIC",
"vendor": "LiXee",
"product": "ZLinky_TIC",
"sleeper": false,
"status": "Bronze",
"path": "/devices/zlinky_tic_with_alarm_HCHP.json",
"type": "$TYPE_POWER_SENSOR",
"restapi": "/sensors",
"0x01",
"0x0b04"
"name": "attr/swversion"
"name": "config/on"
"name": "config/reachable"
"name": "state/consumption",
"refresh.interval": 300,
"read": {
"at": "0x0100",
"cl": "0x0702",
"fn": "zcl"
"at": "0x0100",
"cl": "0x0702",
"ep": 0,
"eval": "Item.val = Attr.val"
"name": "state/current",
"read": {
"at": "0x0508",
"cl": "0x0b04",
"fn": "zcl"
"at": "0x0508",
"cl": "0x0b04",
"name": "state/lastupdated"
"name": "state/power",
"read": {
"at": "0x050f",
"cl": "0x0b04",
"fn": "zcl"
"at": "0x050f",
"cl": "0x0b04",
"name": "state/voltage",
"0x01",
"0x0702"
"name": "config/on"
"read": {
"at": "0x0102",
"cl": "0x0702",
"fn": "zcl"
"at": "0x0102",
"cl": "0x0702",
"ep": 0,
"type": "ZHAAlarm",
"0x01",
"0xff66"
"name": "config/on"
"name": "state/alarm",
"refresh.interval": 30,
"read": {
"at": "0x0005",
"cl": "0xff66",
"fn": "zcl"
"at": "0x0005",
"cl": "0xff66",
"fn": "zcl"
"default": false
"0x02",
"0x0702"
"name": "config/on"
"read": {
"at": "0x0100",
"cl": "0x0702",
"fn": "zcl"
"at": "0x0100",
"cl": "0x0702",
"bindings": [
"cl": "0x0702",
"at": "0x0000",
"dt": "0x23",
"min": 1,
"max": 300,
"change": "0x00000001"
"cl": "0x0B04",
"at": "0x0505",
"dt": "0x21",
"min": 1,
"max": 300,
"at": "0x0508",
"dt": "0x21",
"min": 1,
"max": 300,
"at": "0x050F",
"dt": "0x21",
"min": 1,
"max": 300,
"cl": "0xFF66",
"at": "0x0005",
"dt": "0x21",
"min": 1,
"max": 300,
