hello, sincerely me either I spent 4 days this the problem is it is in changing the name of the manufacturer and the name of the folder that it works perfectly, I just miss the measurement of the current.
inside the json
“manufacturername”: “LIXee”,
“modelid”: “ZLinky_TIC”,
“product”: “ZLinky_TIC historique+base”,
“sleeper”: false,
“status”: “Gold”,
“subdevices”: [
“type”: “$TYPE_POWER_SENSOR”,
“restapi”: “/sensors”,
“uuid”: [
“$address.ext”,
“0x01”,
“0x0b04”
“items”: [
“name”: “attr/id”
“name”: “attr/lastannounced”
“name”: “attr/lastseen”
“name”: “attr/manufacturername”
“name”: “attr/modelid”
“name”: “attr/name”
“name”: “attr/swversion”
“name”: “attr/type”
“name”: “attr/uniqueid”
“name”: “config/on”
“name”: “config/reachable”
“name”: “state/current”,
“refresh.interval”: 10,
“read”: {
“at”: “0x0508”,
“cl”: “0x0b04”,
“ep”: 1,
“fn”: “zcl”
“parse”: {
“at”: “0x0508”,
“cl”: “0x0b04”,
“ep”: 1,
“eval”: “if (Attr.val != 65535) { Item.val = Attr.val; }”
“name”: “state/lastupdated”
“name”: “state/power”,
“read”: {
“at”: “0x050f”,
“cl”: “0x0b04”,
“ep”: 1,
“fn”: “zcl”
“parse”: {
“at”: “0x050f”,
“cl”: “0x0b04”,
“ep”: 1,
“eval”: “if (Attr.val != -32768) { Item.val = Attr.val; }”
“name”: “state/voltage”,
“refresh.interval”: 300
“type”: “$TYPE_CONSUMPTION_SENSOR”,
“uuid”: [
“$address.ext”,
“0x01”,
“0x0702”
“items”: [
“name”: “attr/id”
“name”: “attr/name”
“name”: “attr/type”
“name”: “config/on”
“name”: “state/consumption”,
“read”: {
“at”: “0x0100”,
“cl”: “0x0702”,
“ep”: 1,
“fn”: “zcl”
“parse”: {
“at”: “0x0100”,
“cl”: “0x0702”,
“ep”: 1,
“eval”: “Item.val = Attr.val”
“type”: “ZHAAlarm”,
“uuid”: [
“$address.ext”,
“0x01”,
“0xff66”
“items”: [
“name”: “attr/id”
“name”: “attr/name”
“name”: “attr/type”
“name”: “config/on”
“name”: “state/alarm”,
“refresh.interval”: 300,
“read”: {
“at”: “0x0005”,
“cl”: “0xff66”,
“ep”: 1,
“fn”: “zcl”
“parse”: {
“at”: “0x0005”,
“cl”: “0xff66”,
“ep”: 1,
“eval”: “Item.val = Attr.val > 0 ? true : false”,
“fn”: “zcl”
“default”: false
“bindings”: [
“bind”: “unicast”,
“src.ep”: 1,
“cl”: “0x0702”,
“report”: [
“at”: “0x0000”,
“dt”: “0x23”,
“min”: 60,
“max”: 300,
“change”: “0x00000001”
“bind”: “unicast”,
“src.ep”: 1,
“cl”: “0x0B04”,
“report”: [
“at”: “0x0505”,
“dt”: “0x21”,
“min”: 60,
“max”: 300,
“at”: “0x0508”,
“dt”: “0x21”,
“min”: 60,
“max”: 300,
“at”: “0x050F”,
“dt”: “0x21”,
“min”: 60,
“max”: 300,
“bind”: “unicast”,
“src.ep”: 1,
“cl”: “0xFF66”,
“report”: [
“at”: “0x0005”,
“dt”: “0x21”,
“min”: 60,
“max”: 300,
