[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] firmware.sh: executing...
[13:18:33] INFO: GCFFlasher V3_17 (c) dresden elektronik ingenieurtechnik gmbh
/dev/ttyACM0 | 0x1CF1 | 0x0030 | DE2454167 | ConBee II
[cont-init.d] firmware.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] novnc.sh: executing...
[cont-init.d] novnc.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[13:18:34] INFO: Running the OSRAM LEdvance OTA updater...
[13:18:34] INFO: Websockify waiting for VNC to start
[13:18:34] INFO: Running the deCONZ OTA updater...
[13:18:34] INFO: Running the IKEA OTA updater...
[13:18:34] WARNING: Your direct VNC access is not protected!
[13:18:34] INFO: Starting VNC server (local/no)...
[13:18:37] INFO: Starting websockify...
[13:18:40] INFO: deCONZ waiting for VNC to start
WebSocket server settings:
- Listen on 127.0.0.1:5901
- Flash security policy server
- Web server. Web root: /usr/share/novnc
- No SSL/TLS support (no cert file)
- proxying from 127.0.0.1:5901 to 127.0.0.1:5900
[13:18:40] INFO: Starting the deCONZ gateway...
[13:18:42] INFO: Starting Nginx...
2022/01/01 13:18:42 [notice] 313#313: using the "epoll" event method
2022/01/01 13:18:42 [notice] 313#313: nginx/1.14.2
2022/01/01 13:18:42 [notice] 313#313: OS: Linux 5.10.63-v8
2022/01/01 13:18:42 [notice] 313#313: getrlimit(RLIMIT_NOFILE): 1048576:1048576
2022/01/01 13:18:42 [notice] 313#313: start worker processes
2022/01/01 13:18:42 [notice] 313#313: start worker process 1467
13:18:42:588 DDF: loaded resource item descriptor: attr/manufacturername
13:18:42:588 DDF: loaded resource item descriptor: attr/modelid
13:18:42:588 DDF: loaded resource item descriptor: attr/name
13:18:42:588 DDF: loaded resource item descriptor: attr/swversion
13:18:42:588 DDF: loaded resource item descriptor: attr/type
13:18:42:588 DDF: loaded resource item descriptor: attr/uniqueid
13:18:42:588 DDF: loaded resource item descriptor: config/on
13:18:42:588 DDF: loaded resource item descriptor: config/reachable
13:18:42:588 DDF: loaded resource item descriptor: state/lastupdated
13:18:42:588 DDF: loaded resource item descriptor: state/power
13:18:42:588 DDF: loaded resource item descriptor: attr/id
13:18:42:588 DDF: loaded resource item descriptor: attr/lastannounced
13:18:42:588 DDF: loaded resource item descriptor: attr/lastseen
13:18:42:588 DDF: loaded resource item descriptor: state/consumption
13:18:42:598 parent process s6-supervise
13:18:42:598 gw run mode: docker/hassio
13:18:42:598 GW sd-card image version file does not exist: /data/.local/share/dresden-elektronik/deCONZ/gw-version
13:18:42:600 DB sqlite version 3.27.2
13:18:42:601 DB PRAGMA page_count: 48
13:18:42:601 DB PRAGMA page_size: 4096
13:18:42:601 DB PRAGMA freelist_count: 0
13:18:42:601 DB file size 196608 bytes, free pages 0
13:18:42:601 DB PRAGMA user_version: 9
13:18:42:601 DB cleanup
13:18:42:601 DB create temporary views
13:18:42:610 DB legacy loading sensor Dimmschalter 8, later handled by DDF Dimmer Switch 1. Gen EU/US
13:18:42:616 Started websocket server on 0.0.0.0, port: 8081
13:18:42:619 [INFO] - Found file containing button maps. Parsing data...
13:18:42:630 [INFO] - Button maps loaded.
13:18:42:631 found node plugin: libde_rest_plugin.so - REST API Plugin
13:18:42:632 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
13:18:48:142 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
13:18:48:208 LightNode 1: Configuration tool 1 added
13:18:48:216 SensorNode 8 set node 0x00178801080ab75f
13:18:48:221 SensorNode 9 set node 0x00158d000672716e
13:18:48:223 SensorNode 2 set node 0x00158d0006e4f072
13:18:48:224 SensorNode 7 set node 0x00158d0007103379
13:18:48:229 SensorNode 6 set node 0x00158d0007086996
13:18:48:232 LightNode 7: Wohnzimmerwand added
13:18:48:233 SensorNode 3 set node 0x00158d00070b7dc2
13:18:48:235 LightNode 4: Nachttisch Anni added
13:18:48:237 LightNode 5: Dimmable light 5 added
13:18:48:239 SensorNode 10 set node 0x00158d0006726ecb
13:18:48:240 SensorNode 5 set node 0x00158d00070862c7
13:18:48:242 LightNode 6: Arbeitsplatte added
13:18:48:244 LightNode 2: Range extender 2 added
13:18:48:246 SensorNode 4 set node 0x00158d0006ffcafb
13:18:48:247 SensorNode 11 set node 0x0c4314fffefdc641
172.30.32.2 - - [01/Jan/2022:13:18:48 +0100] "GET /api/DC0FA1E4C8/groups?_=1641039487443 HTTP/1.1" 404 152 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
13:18:48:516 DEV found DDF for 0x00178801080AB75F, path: /usr/share/deCONZ/devices/philips/rwl02_dimmer_switch.json
13:18:48:517 DEV no DDF for 0x00158D0007086996, modelId: lumi.sensor_magnet.aq2
13:18:48:518 DEV create on-the-fly DDF for 0x00158D0007086996
13:18:48:519 DEV found DDF for 0x00158D00070862C7, path:
13:18:48:519 DEV no DDF for 0x00158D0006726ECB, modelId: lumi.remote.b1acn01
13:18:48:520 DEV create on-the-fly DDF for 0x00158D0006726ECB
13:18:48:520 DEV found DDF for 0x00158D0006FFCAFB, path:
13:18:48:520 DEV no DDF for 0x0C4314FFFEFDC641, modelId: TRADFRI on/off switch
13:18:48:521 DEV create on-the-fly DDF for 0x0C4314FFFEFDC641
13:18:48:521 DEV found DDF for 0x00158D000672716E, path:
13:18:48:521 DEV found DDF for 0x00158D0007103379, path:
13:18:48:575 dlg action: Read binding table
13:18:48:625 DEV found DDF for 0x00158D0006E4F072, path:
13:18:48:625 DEV no DDF for 0x7CB03EAA0A02B12A, modelId: Plug 01
13:18:48:625 DEV create on-the-fly DDF for 0x7CB03EAA0A02B12A
13:18:48:626 DEV no DDF for 0x086BD7FFFE20182F, modelId: TRADFRI bulb E14 W op/ch 400lm
13:18:48:626 DEV create on-the-fly DDF for 0x086BD7FFFE20182F
13:18:48:626 DEV no DDF for 0x0017880106B3C248, modelId: LWA001
13:18:48:627 DEV create on-the-fly DDF for 0x0017880106B3C248
13:18:48:627 DEV no DDF for 0xB4E3F9FFFE6B888F, modelId: TRADFRI Driver 30W
13:18:48:628 DEV create on-the-fly DDF for 0xB4E3F9FFFE6B888F
13:18:48:628 DEV no DDF for 0x84FD27FFFED2EC43, modelId: TRADFRI Signal Repeater
13:18:48:629 DEV create on-the-fly DDF for 0x84FD27FFFED2EC43
172.30.32.2 - - [01/Jan/2022:13:18:48 +0100] "GET /api/DC0FA1E4C8/groups?_=1641039487444 HTTP/1.1" 200 2442 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
13:18:48:704 New websocket 172.30.32.1:56660 (state: 3)
172.30.32.2 - - [01/Jan/2022:13:18:48 +0100] "GET /api/DC0FA1E4C8/lights?_=1641039487445 HTTP/1.1" 200 2186 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:18:48 +0100] "GET /api/DC0FA1E4C8/sensors?_=1641039487446 HTTP/1.1" 200 4645 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:18:48 +0100] "GET /api/DC0FA1E4C8/config?_=1641039487447 HTTP/1.1" 200 3349 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
13:18:48:888 Announced to internet https://phoscon.de/discover
13:18:48:889 discovery server date: Sat, 01 Jan 2022 12:18:48 GMT
13:18:48:890 local time seems to be ok
13:18:49:317 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2454167-if00 / serialno: DE2454167, ConBee II
13:18:49:463 Skip idle timer callback, too early: elapsed 939 msec
13:18:50:854 DEV Tick.Init: booted after 8000 seconds
13:18:50:932 Device firmware version 0x26660700 ConBee II
13:18:50:934 unlocked max nodes: 512
13:18:50:952 Device protocol version: 0x010C
13:18:51:019 Current channel 15
13:18:51:024 CTRL ANT_CTRL 0x03
13:18:51:038 Device protocol version: 0x010C
13:18:51:067 CTRL ANT_CTRL 0x03
13:18:51:643 New websocket 127.0.0.1:55520 (state: 3)
[13:18:52] INFO: Successfully send discovery information to Home Assistant.
13:18:58:856 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26660700.bin.GCF
13:18:58:856 GW firmware version is up to date: 0x26660700
172.30.32.2 - - [01/Jan/2022:13:19:03 +0100] "GET /api/DC0FA1E4C8/groups?_=1641039487448 HTTP/1.1" 200 2442 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:19:03 +0100] "GET /api/DC0FA1E4C8/lights?_=1641039487449 HTTP/1.1" 200 2186 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:19:03 +0100] "GET /api/DC0FA1E4C8/sensors?_=1641039487450 HTTP/1.1" 200 4645 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:19:03 +0100] "GET /api/DC0FA1E4C8/config?_=1641039487451 HTTP/1.1" 200 3353 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
13:19:10:437 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
13:19:12:216 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
13:19:14:026 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
13:19:14:859 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xD0 on task
13:19:16:590 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
13:19:18:394 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
13:19:20:122 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
13:19:22:023 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xE1 on task
13:19:22:939 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
172.30.32.2 - - [01/Jan/2022:13:19:23 +0100] "GET /api/DC0FA1E4C8/groups?_=1641039487452 HTTP/1.1" 200 2442 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:19:23 +0100] "GET /api/DC0FA1E4C8/lights?_=1641039487453 HTTP/1.1" 200 2186 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:19:23 +0100] "GET /api/DC0FA1E4C8/sensors?_=1641039487454 HTTP/1.1" 200 4645 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:19:23 +0100] "GET /api/DC0FA1E4C8/config?_=1641039487455 HTTP/1.1" 200 3353 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
13:19:24:748 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
13:19:26:518 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
13:19:28:427 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xE1 on task
13:19:29:290 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
13:19:31:000 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
13:19:32:720 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
13:19:34:636 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xE1 on task
13:19:36:419 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
13:19:38:111 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
172.30.32.2 - - [01/Jan/2022:13:19:38 +0100] "GET /api/DC0FA1E4C8/groups?_=1641039487456 HTTP/1.1" 200 2442 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:19:38 +0100] "GET /api/DC0FA1E4C8/lights?_=1641039487457 HTTP/1.1" 200 2186 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:19:38 +0100] "GET /api/DC0FA1E4C8/sensors?_=1641039487458 HTTP/1.1" 200 4645 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:19:38 +0100] "GET /api/DC0FA1E4C8/config?_=1641039487459 HTTP/1.1" 200 3353 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
13:19:39:900 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
13:19:41:711 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xE1 on task
13:19:41:863 Device TTL 1181 s flags: 0x7
13:19:43:529 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
13:19:45:317 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
13:19:47:012 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
13:19:48:938 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xE1 on task
13:19:50:727 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
13:19:52:519 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
13:19:54:315 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
13:19:55:624 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xE1 on task
13:19:57:411 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
172.30.32.2 - - [01/Jan/2022:13:19:58 +0100] "GET /api/DC0FA1E4C8/groups?_=1641039487460 HTTP/1.1" 200 2442 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:19:58 +0100] "GET /api/DC0FA1E4C8/lights?_=1641039487461 HTTP/1.1" 200 2186 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:19:58 +0100] "GET /api/DC0FA1E4C8/sensors?_=1641039487462 HTTP/1.1" 200 4645 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:19:58 +0100] "GET /api/DC0FA1E4C8/config?_=1641039487463 HTTP/1.1" 200 3353 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
13:19:59:108 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
13:20:00:935 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
13:20:02:827 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xE1 on task
13:20:04:623 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
13:20:06:413 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
13:20:08:108 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
13:20:09:999 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xE1 on task
13:20:11:704 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
13:20:13:529 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
13:20:15:309 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
13:20:17:113 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xE1 on task
172.30.32.2 - - [01/Jan/2022:13:20:18 +0100] "GET /api/DC0FA1E4C8/groups?_=1641039487464 HTTP/1.1" 200 2442 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:20:18 +0100] "GET /api/DC0FA1E4C8/lights?_=1641039487465 HTTP/1.1" 200 2186 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:20:18 +0100] "GET /api/DC0FA1E4C8/sensors?_=1641039487466 HTTP/1.1" 200 4645 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:20:18 +0100] "GET /api/DC0FA1E4C8/config?_=1641039487467 HTTP/1.1" 200 3353 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
13:20:18:928 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
13:20:20:726 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
13:20:22:526 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
13:20:24:404 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xE1 on task
13:20:26:125 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
13:20:27:914 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
13:20:29:610 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
13:20:31:523 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xE1 on task
13:20:33:312 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
13:20:35:027 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
13:20:36:812 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
172.30.32.2 - - [01/Jan/2022:13:20:38 +0100] "GET /api/DC0FA1E4C8/groups?_=1641039487468 HTTP/1.1" 200 2442 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
13:20:38:641 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xE1 on task
172.30.32.2 - - [01/Jan/2022:13:20:38 +0100] "GET /api/DC0FA1E4C8/lights?_=1641039487469 HTTP/1.1" 200 2186 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:20:38 +0100] "GET /api/DC0FA1E4C8/sensors?_=1641039487470 HTTP/1.1" 200 4645 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
172.30.32.2 - - [01/Jan/2022:13:20:38 +0100] "GET /api/DC0FA1E4C8/config?_=1641039487471 HTTP/1.1" 200 3353 "http://homeassistant:8123/api/hassio_ingress/uQ3FIS6vf1lxbc1xk6b7LFjDd5sS7G-rvuENwi5Alb4/pwa/index.html?1639838561000&gwid=00212EFFFF078EC6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36"
13:20:40:421 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
13:20:41:862 Device TTL 1121 s flags: 0x7
13:20:42:220 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
13:20:44:027 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
13:20:45:931 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xE1 on task
13:20:47:729 0x7CB03EAA0A02B12A error APSDE-DATA.confirm: 0xE1 on task
13:20:49:510 0x086BD7FFFE20182F error APSDE-DATA.confirm: 0xE1 on task
13:20:51:311 0xB4E3F9FFFE6B888F error APSDE-DATA.confirm: 0xE1 on task
13:20:53:111 0x84FD27FFFED2EC43 error APSDE-DATA.confirm: 0xE1 on task
172.30.32.2 - - [01/Jan/2022:13:20:53 +0100] "GET /api/DC0FA1E4C8/groups?_=1641039487472
