Hi all,
I´m observing a strange behaviour with my two LIDL remotes.
When I´m pushing the On Button, all lights and all groups will be switched on in the Phoscon App and the on states will be also reported to my IObroker. But the lights switched only in the Phoscon App virtually to on. The hardware, means the lamps themselves, remain in off state in the real live. When I´m pushing the Off button all the lights switched virtually back to Off state.
The Problem is reproduceable.
I have no pairing in Phoscon for both remotes. I´m switching the lights on and off via my IObroker system. So, normally no lights should be switched directly with the two Lidl remotes.
My system:
- Host system: Raspberry Pi
- Running method: (Raspbian + IObroker)
- Firmware version: 26660700
- deCONZ version: 2.13.04 / 18.12.2021
- Device: ConBee II
The Log looks the following:
09:18:16:831 [INFO] - Button 1002 - HG06323, broadcast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: On, payload: None, zclSeq: 76
09:18:16:861 rule event /groups/6/state/any_on: 0 -> 6
09:18:17:586 APS-DATA.request id: 113, addrmode: 0x03, addr: 0x588e81fffefcb286, profile: 0x0104, cluster: 0x0300, ep: 0x01 -> 0x01 queue: 0 len: 15 tx.options 0x00
09:18:17:606 APS-DATA.confirm id: 113, status: 0x00 SUCCESS
09:18:17:607 APS-DATA.confirm request id: 113 -> erase from queue
09:18:17:623 APS-DATA.indication srcAddr: 0xbf4d, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0300, lqi: 255, rssi: -55
09:18:17:624 APS-DATA.request id: 113 erase from queue
09:18:17:625 ZCL got data for node=0xBF4D, cl=0x0300, at=0x0000, status=0x00, type=0x20
09:18:17:625 ZCL got data for node=0xBF4D, cl=0x0300, at=0x0001, status=0x00, type=0x20
09:18:17:626 ZCL got data for node=0xBF4D, cl=0x0300, at=0x0003, status=0x00, type=0x21
09:18:17:627 ZCL got data for node=0xBF4D, cl=0x0300, at=0x0004, status=0x00, type=0x21
09:18:17:628 ZCL got data for node=0xBF4D, cl=0x0300, at=0x0007, status=0x00, type=0x21
09:18:17:629 ZCL got data for node=0xBF4D, cl=0x0300, at=0x0008, status=0x00, type=0x30
09:18:17:717 APS-DATA.request id: 117, addrmode: 0x01, addr: 0x0008, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0xFF queue: 0 len: 3 tx.options 0x00
09:18:17:922 APS-DATA.indication srcAddr: 0xbd4d, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0008, lqi: 255, rssi: -54
09:18:17:923 ZCL attribute report 0x842E14FFFE0017EB for cluster: 0x0008, ep: 0x01, frame control: 0x18, mfcode: 0x0000
09:18:17:944 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x01 dstAddrMode: 1, profile: 0x0104, cluster: 0x0006, lqi: 255, rssi: -54
09:18:17:983 APS-DATA.confirm id: 117, status: 0x00 SUCCESS
09:18:17:984 APS-DATA.confirm request id: 117 -> erase from queue
09:18:18:048 aps request id: 117 finished, erase from queue
09:18:18:057 APS-DATA.indication srcAddr: 0x6447, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0006, lqi: 167, rssi: -73
09:18:18:058 ZCL attribute report 0x84FD27FFFE8F88DF for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
09:18:18:070 APS-DATA.indication srcAddr: 0xc778, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0006, lqi: 167, rssi: -73
09:18:18:071 ZCL attribute report 0x60A423FFFEFE75B1 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
09:18:18:085 APS-DATA.indication srcAddr: 0xc8fc, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0006, lqi: 167, rssi: -73
09:18:18:086 ZCL attribute report 0x84FD27FFFE68EF96 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
09:18:18:342 APS-DATA.request id: 126, addrmode: 0x01, addr: 0x0009, profile: 0x0104, cluster: 0x0300, ep: 0x01 -> 0xFF queue: 0 len: 7 tx.options 0x00
09:18:18:387 apsUseExtPanid is 0xDDDDDDDDDDDDDDDD but should be 0, start reconfiguration
09:18:18:388 Skip automatic channel change, TODO warn user
09:18:18:461 APS-DATA.request id: 129, addrmode: 0x01, addr: 0x0008, profile: 0x0104, cluster: 0x0300, ep: 0x01 -> 0xFF queue: 1 len: 7 tx.options 0x00
09:18:18:464 APS-DATA.request id: 131, addrmode: 0x01, addr: 0x0001, profile: 0x0104, cluster: 0x0300, ep: 0x01 -> 0xFF queue: 2 len: 7 tx.options 0x00
09:18:18:475 APS-DATA.indication srcAddr: 0x1f07, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0008, lqi: 255, rssi: -55
09:18:18:478 ZCL attribute report 0x588E81FFFEFCA7BD for cluster: 0x0008, ep: 0x01, frame control: 0x18, mfcode: 0x0000
09:18:18:653 APS-DATA.request id: 135, addrmode: 0x01, addr: 0x0008, profile: 0x0104, cluster: 0x0300, ep: 0x01 -> 0xFF queue: 3 len: 7 tx.options 0x00
09:18:18:668 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x01 dstAddrMode: 1, profile: 0x0104, cluster: 0x0300, lqi: 229, rssi: 5
09:18:18:708 APS-DATA.request id: 137, addrmode: 0x03, addr: 0x84fd27fffe68ef96, profile: 0x0104, cluster: 0x0300, ep: 0x01 -> 0x01 queue: 4 len: 15 tx.options 0x00
09:18:18:709 APS-DATA.confirm id: 126, status: 0x00 SUCCESS
09:18:18:710 APS-DATA.confirm request id: 126 -> erase from queue
09:18:18:770 aps request id: 126 finished, erase from queue
09:18:18:778 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x01 dstAddrMode: 1, profile: 0x0104, cluster: 0x0300, lqi: 78, rssi: 81
09:18:18:789 APS-DATA.confirm id: 129, status: 0x00 SUCCESS
09:18:18:791 APS-DATA.confirm request id: 129 -> erase from queue
09:18:18:792 aps request id: 129 finished, erase from queue
09:18:18:819 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x01 dstAddrMode: 1, profile: 0x0104, cluster: 0x0300, lqi: 78, rssi: 81
09:18:18:884 APS-DATA.confirm id: 137, status: 0x00 SUCCESS
09:18:18:884 APS-DATA.confirm request id: 137 -> erase from queue
09:18:18:895 APS-DATA.confirm id: 131, status: 0x00 SUCCESS
09:18:18:895 APS-DATA.confirm request id: 131 -> erase from queue
09:18:18:905 APS-DATA.indication srcAddr: 0xc8fc, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0300, lqi: 159, rssi: -74
09:18:18:906 APS-DATA.request id: 131 erase from queue
09:18:18:909 APS-DATA.request id: 137 erase from queue
09:18:18:910 ZCL got data for node=0xC8FC, cl=0x0300, at=0x0000, status=0x00, type=0x20
09:18:18:910 ZCL got data for node=0xC8FC, cl=0x0300, at=0x0001, status=0x00, type=0x20
09:18:18:911 ZCL got data for node=0xC8FC, cl=0x0300, at=0x0003, status=0x00, type=0x21
09:18:18:911 ZCL got data for node=0xC8FC, cl=0x0300, at=0x0004, status=0x00, type=0x21
09:18:18:912 ZCL got data for node=0xC8FC, cl=0x0300, at=0x0007, status=0x00, type=0x21
09:18:18:913 ZCL got data for node=0xC8FC, cl=0x0300, at=0x0008, status=0x00, type=0x30
09:18:18:993 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x01 dstAddrMode: 1, profile: 0x0104, cluster: 0x0300, lqi: 159, rssi: -74
09:18:19:050 APS-DATA.indication srcAddr: 0x6447, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0300, lqi: 159, rssi: -74
09:18:19:052 ZCL attribute report 0x84FD27FFFE8F88DF for cluster: 0x0300, ep: 0x01, frame control: 0x18, mfcode: 0x0000
09:18:19:062 APS-DATA.confirm id: 135, status: 0x00 SUCCESS
09:18:19:064 APS-DATA.confirm request id: 135 -> erase from queue
09:18:19:073 APS-DATA.indication srcAddr: 0xc778, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0300, lqi: 159, rssi: -74
09:18:19:075 APS-DATA.request id: 135 erase from queue
09:18:19:076 ZCL attribute report 0x60A423FFFEFE75B1 for cluster: 0x0300, ep: 0x01, frame control: 0x18, mfcode: 0x0000
09:18:19:090 APS-DATA.indication srcAddr: 0xc8fc, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0008, lqi: 159, rssi: -74
09:18:19:092 ZCL attribute report 0x84FD27FFFE68EF96 for cluster: 0x0008, ep: 0x01, frame control: 0x18, mfcode: 0x0000
09:18:19:987 APS-DATA.request id: 151, addrmode: 0x03, addr: 0x842e14fffe0e233c, profile: 0x0104, cluster: 0x0300, ep: 0x01 -> 0x01 queue: 0 len: 15 tx.options 0x00
09:18:20:005 APS-DATA.request id: 153, addrmode: 0x01, addr: 0x0009, profile: 0x0104, cluster: 0x0300, ep: 0x01 -> 0xFF queue: 1 len: 7 tx.options 0x00
09:18:20:020 APS-DATA.request id: 155, addrmode: 0x01, addr: 0x0008, profile: 0x0104, cluster: 0x0300, ep: 0x01 -> 0xFF queue: 2 len: 7 tx.options 0x00
09:18:20:029 APS-DATA.confirm id: 151, status: 0x00 SUCCESS
09:18:20:030 APS-DATA.confirm request id: 151 -> erase from queue
09:18:20:039 APS-DATA.request id: 157, addrmode: 0x01, addr: 0x0001, profile: 0x0104, cluster: 0x0300, ep: 0x01 -> 0xFF queue: 3 len: 7 tx.options 0x00
09:18:20:133 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x01 dstAddrMode: 1, profile: 0x0104, cluster: 0x0300, lqi: 169, rssi: 7
09:18:20:135 APS-DATA.request id: 151 erase from queue
09:18:20:198 APS-DATA.indication srcAddr: 0x0bc7, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0300, lqi: 255, rssi: -54
09:18:20:199 ZCL got data for node=0x0BC7, cl=0x0300, at=0x0000, status=0x00, type=0x20
09:18:20:200 ZCL got data for node=0x0BC7, cl=0x0300, at=0x0001, status=0x00, type=0x20
09:18:20:200 ZCL got data for node=0x0BC7, cl=0x0300, at=0x0003, status=0x00, type=0x21
09:18:20:201 ZCL got data for node=0x0BC7, cl=0x0300, at=0x0004, status=0x00, type=0x21
09:18:20:201 ZCL got data for node=0x0BC7, cl=0x0300, at=0x0007, status=0x00, type=0x21
09:18:20:201 ZCL got data for node=0x0BC7, cl=0x0300, at=0x0008, status=0x00, type=0x30
09:18:20:222 APS-DATA.confirm id: 153, status: 0x00 SUCCESS
09:18:20:223 APS-DATA.confirm request id: 153 -> erase from queue
09:18:20:230 APS-DATA.indication srcAddr: 0x0bc7, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0300, lqi: 255, rssi: -54
09:18:20:232 APS-DATA.request id: 153 erase from queue
09:18:20:233 ZCL attribute report 0x842E14FFFE0E233C for cluster: 0x0300, ep: 0x01, frame control: 0x18, mfcode: 0x0000
09:18:20:304 APS-DATA.indication srcAddr: 0x4679, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0300, lqi: 255, rssi: -54
09:18:20:306 ZCL attribute report 0x588E81FFFED3E6D2 for cluster: 0x0300, ep: 0x01, frame control: 0x18, mfcode: 0x0000
09:18:20:377 APS-DATA.confirm id: 155, status: 0x00 SUCCESS
09:18:20:378 APS-DATA.confirm request id: 155 -> erase from queue
09:18:20:391 aps request id: 155 finished, erase from queue
09:18:20:400 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x01 dstAddrMode: 1, profile: 0x0104, cluster: 0x0300, lqi: 255, rssi: -54
09:18:20:415 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x01 dstAddrMode: 1, profile: 0x0104, cluster: 0x0300, lqi: 229, rssi: 5
09:18:20:477 APS-DATA.confirm id: 157, status: 0x00 SUCCESS
09:18:20:478 APS-DATA.confirm request id: 157 -> erase from queue
09:18:20:487 APS-DATA.indication srcAddr: 0x1f07, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0300, lqi: 255, rssi: -55
09:18:20:489 APS-DATA.request id: 157 erase from queue
09:18:20:489 ZCL attribute report 0x588E81FFFEFCA7BD for cluster: 0x0300, ep: 0x01, frame control: 0x18, mfcode: 0x0000
09:18:20:501 APS-DATA.indication srcAddr: 0xbf4d, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0300, lqi: 255, rssi: -55
09:18:20:503 ZCL attribute report 0x588E81FFFEFCB286 for cluster: 0x0300, ep: 0x01, frame control: 0x18, mfcode: 0x0000
09:18:20:512 APS-DATA.indication srcAddr: 0xbd4d, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0300, lqi: 255, rssi: -54
09:18:20:514 ZCL attribute report 0x842E14FFFE0017EB for cluster: 0x0300, ep: 0x01, frame control: 0x18, mfcode: 0x0000
09:18:21:187 APS-DATA.request id: 172, addrmode: 0x03, addr: 0x842e14fffe3b7859, profile: 0x0104, cluster: 0x0300, ep: 0x01 -> 0x01 queue: 0 len: 15 tx.options 0x00
09:18:21:205 APS-DATA.confirm id: 172, status: 0x00 SUCCESS
09:18:21:206 APS-DATA.confirm request id: 172 -> erase from queue
09:18:21:229 APS-DATA.indication srcAddr: 0x364f, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0300, lqi: 255, rssi: -54
09:18:21:230 APS-DATA.request id: 172 erase from queue
09:18:21:230 ZCL got data for node=0x364F, cl=0x0300, at=0x0000, status=0x00, type=0x20
09:18:21:230 ZCL got data for node=0x364F, cl=0x0300, at=0x0001, status=0x00, type=0x20
09:18:21:231 ZCL got data for node=0x364F, cl=0x0300, at=0x0003, status=0x00, type=0x21
09:18:21:231 ZCL got data for node=0x364F, cl=0x0300, at=0x0004, status=0x00, type=0x21
09:18:21:231 ZCL got data for node=0x364F, cl=0x0300, at=0x0007, status=0x00, type=0x21
09:18:21:232 ZCL got data for node=0x364F, cl=0x0300, at=0x0008, status=0x00, type=0x30
09:18:21:439 APS-DATA.indication srcAddr: 0x1341, srcEp: 0x01 dstAddrMode: 1, profile: 0x0104, cluster: 0x0006, lqi: 175, rssi: -72
09:18:21:440 [INFO] - Button 4002 - HG06323, broadcast to: 0x0000, endpoint: 0x01, cluster: ONOFF (0x0006), action: Off, payload: None, zclSeq: 77
09:18:21:456 rule event /groups/6/state/any_on: 0 -> 6
09:18:22:901 APS-DATA.request id: 184, addrmode: 0x01, addr: 0x0008, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0xFF queue: 0 len: 3 tx.options 0x00
09:18:22:918 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x01 dstAddrMode: 1, profile: 0x0104, cluster: 0x0006, lqi: 74, rssi: 5
09:18:22:947 APS-DATA.confirm id: 184, status: 0x00 SUCCESS
09:18:22:948 APS-DATA.confirm request id: 184 -> erase from queue
09:18:22:960 aps request id: 184 finished, erase from queue
