i feel dump after all that years I discovered the websocket. This should be much much more promoted!
it is no solution but with this there are easy workaround on all triggers. Websocket gives me an instant cutom action on all devices that have a trigger and even more…
so the problem is not solved for me but the workaround works.
I simply start a selfmade script on the triggers that do the job using the normal api
Here is a sample output from the switch
Empfangene Daten: {‘e’: ‘changed’, ‘id’: ‘2’, ‘r’: ‘sensors’, ‘state’: {‘buttonevent’: 3001, ‘lastupdated’: ‘2023-11-12T20:10:28.209’}, ‘t’: ‘event’…
Empfangene Daten: {‘config’: {‘battery’: 100, ‘group’: ‘4’, ‘on’: True, ‘reachable’: True}, ‘e’: ‘changed’, ‘id’: ‘2’, ‘r’: ‘sensors’, ‘t’: ‘event’,…
Empfangene Daten: {‘config’: {‘battery’: 100, ‘group’: ‘2’, ‘on’: True, ‘reachable’: True}, ‘e’: ‘changed’, ‘id’: ‘2’, ‘r’: ‘sensors’, ‘t’: ‘event’, …
Empfangene Daten: {‘e’: ‘changed’, ‘id’: ‘2’, ‘r’: ‘sensors’, ‘state’: {‘buttonevent’: 3001, ‘lastupdated’: ‘2023-11-12T20:10:32.739’}, ‘t’: ‘event’, …
Empfangene Daten: {‘config’: {‘battery’: 100, ‘group’: ‘4’, ‘on’: True, ‘reachable’: True}, ‘e’: ‘changed’, ‘id’: ‘2’, ‘r’: ‘sensors’, ‘t’: ‘event’, '…
Empfangene Daten: {‘config’: {‘battery’: 100, ‘group’: ‘1’, ‘on’: True, ‘reachable’: True}, ‘e’: ‘changed’, ‘id’: ‘2’, ‘r’: ‘sensors’, ‘t’: ‘event’, …
Empfangene Daten: {‘config’: {‘battery’: 100, ‘group’: ‘2’, ‘on’: True, ‘reachable’: True}, ‘e’: ‘changed’, ‘id’: ‘2’, ‘r’: ‘sensors’, ‘t’: ‘event’, '…
Empfangene Daten: {‘e’: ‘changed’, ‘id’: ‘2’, ‘r’: ‘sensors’, ‘state’: {‘buttonevent’: 1001, ‘lastupdated’: ‘2023-11-12T20:10:38.213’}, ‘t’: ‘event’, '…
Empfangene Daten: {‘config’: {‘battery’: 100, ‘group’: ‘3’, ‘on’: True, ‘reachable’: True}, ‘e’: ‘changed’, ‘id’: ‘2’, ‘r’: ‘sensors’, ‘t’: ‘event’, …
Empfangene Daten: {‘config’: {‘battery’: 100, ‘group’: ‘4’, ‘on’: True, ‘reachable’: True}, ‘e’: ‘changed’, ‘id’: ‘2’, ‘r’: ‘sensors’, ‘t’: ‘event’, …
