Hi
By default, Kobold goes to full brightness if power-cycled. How can I change the behavior that the last state (on/off & brightness) are remembered?
Thanks
Jochen
Hi
Thanks
Jochen
Hi @manup, thanks for your reply.
I have already tried this but it does not work. Due to the wrong description of the attribute I wasn’t sure it is what the name suggests.
I set it to “Previous” and hit “write”. Then I turned off the Kobold (the attached light), cut power and turned power on again. I would have expected the light attached to the Kobold to remain turned off since this was the previous state but it goes to full brightness instead…
What am I doing wrong?
I’m running deconz 2.13.04, Conbee I with Firmware 26400500.
The Kobold is fresh from Amazon and shows the following version info in the basic cluster:
Thank you!
I have forwarded the issue internally, looks like there is some missing part. The default on/off values seem to work but the previous state not. We’ll see to check what the issue is and address it in the next OTA update.
