Is there any python module to update conbee II firmware?
Hi
Is there any python module to update the conbee II firmware would like to integrate the firmware update in other software
I think not, the updater can be run in command line (using python) but you can’t find it in “stand alone mode” for all OS.
Yes, I would se a more open source flasher. I been trying to commit commandline flasher to a few project but was rejected because of closed source and external commad that’s not universal
@Gautama Are you able to answer this one?
I`m investigating here.
Edit: according to our programmers, there is only GCFFlasher at the moment. We are on it to make this open source, so that other connections can also be programmed.
