Hi, I am trying to install the Conbee II with deconz but the program does not start.
It seems that the service stop and start in loops.
The library libsqlite3.so.0 is well installed but is not found by deconz.
Here are my logs:
Nov 22 14:48:10 nanopim4 kernel: [ 3442.650006] usb 3-1.2: SerialNumber: DE------
Nov 22 14:48:10 nanopim4 kernel: [ 3442.708973] cdc_acm 3-1.2:1.0: ttyACM0: USB ACM device
Nov 22 14:48:13 nanopim4 kernel: [ 3446.324418] usb 3-1.2: USB disconnect, device number 5
Nov 22 14:48:14 nanopim4 kernel: [ 3446.627818] usb 3-1.2: new full-speed USB device number 6 using xhci-hcd
Nov 22 14:48:14 nanopim4 kernel: [ 3446.777478] usb 3-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Nov 22 14:48:14 nanopim4 kernel: [ 3446.777487] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Nov 22 14:48:14 nanopim4 kernel: [ 3446.777492] usb 3-1.2: Product: ConBee II
Nov 22 14:48:14 nanopim4 kernel: [ 3446.777497] usb 3-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Nov 22 14:48:14 nanopim4 kernel: [ 3446.777502] usb 3-1.2: SerialNumber: DE--------
Nov 22 14:48:14 nanopim4 kernel: [ 3446.836403] cdc_acm 3-1.2:1.0: ttyACM0: USB ACM device
Nov 22 14:48:37 nanopim4 systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Nov 22 14:48:37 nanopim4 systemd[1]: deconz.service: Scheduled restart job, restart counter is at 114.
Nov 22 14:48:37 nanopim4 systemd[1]: Starting deCONZ: ZigBee gateway – Initialisation…
Nov 22 14:48:37 nanopim4 systemd[1]: Stopped deCONZ: ZigBee gateway – REST API.
Nov 22 14:48:37 nanopim4 systemd[1]: Started deCONZ: ZigBee gateway – REST API.
Nov 22 14:48:37 nanopim4 deCONZ[6410]: /usr/bin/deCONZ: error while loading shared libraries: libsqlite3.so.0: cannot open shared object file: No such file or directory
Nov 22 14:48:37 nanopim4 systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Nov 22 14:48:37 nanopim4 systemd[1]: deconz.service: Failed with result ‘exit-code’.
Nov 22 14:48:37 nanopim4 deCONZ-init.sh[6409]: cat: /sys/block/mmcblk0/device/cid: No such file or directory
Nov 22 14:48:37 nanopim4 deCONZ-init.sh[6409]: stopping deconz-wifi.service
Nov 22 14:48:37 nanopim4 systemd[1]: Reloading.
Nov 22 14:48:38 nanopim4 systemd[1]: deconz-init.service: Succeeded.
Nov 22 14:48:38 nanopim4 systemd[1]: Started deCONZ: ZigBee gateway – Initialisation.
Nov 22 14:49:07 nanopim4 systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Nov 22 14:49:07 nanopim4 systemd[1]: deconz.service: Scheduled restart job, restart counter is at 115.
Nov 22 14:49:07 nanopim4 systemd[1]: Starting deCONZ: ZigBee gateway – Initialisation…
Nov 22 14:49:07 nanopim4 systemd[1]: Stopped deCONZ: ZigBee gateway – REST API.
Nov 22 14:49:07 nanopim4 systemd[1]: Started deCONZ: ZigBee gateway – REST API.
Nov 22 14:49:07 nanopim4 deCONZ[6448]: /usr/bin/deCONZ: error while loading shared libraries: libsqlite3.so.0: cannot open shared object file: No such file or directory
Nov 22 14:49:07 nanopim4 systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Nov 22 14:49:07 nanopim4 systemd[1]: deconz.service: Failed with result ‘exit-code’.
Nov 22 14:49:07 nanopim4 deCONZ-init.sh[6447]: cat: /sys/block/mmcblk0/device/cid: No such file or directory
Nov 22 14:49:07 nanopim4 deCONZ-init.sh[6447]: stopping deconz-wifi.service
Moved to Setup support
