Installation of deConz 2.32.5 fails on Trixie / Pi1B?
Solving dependencies… Error!
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
The following information may help to resolve the situation:
Unsatisfied dependencies:
deconz : Depends: libqt5core5a but it is not installable
Depends: libqt5network5 but it is not installable
Depends: libqt5widgets5 but it is not installable
Depends: libqt5gui5 but it is not installable
Depends: libqt5sql5 but it is not installable
Error: Unable to correct problems, you have held broken packages.
Error: The following information from --solver 3.0 may provide additional context:
Unable to satisfy dependencies. Reached two conflicting decisions:
  1. deconz:armhf=2.32.5 is selected for install
  2. deconz:armhf Depends libqt5core5a
    but none of the choices are installable:
    [no choices]
Hi Trixie on 64-bit versions don’t have Qt5. To install deCONZ there you need to switch to the Qt6 package of deCONZ.
apt get install deconz-qt6
