Sensor Value display is not consistant. The order changes depending on the device. Makes it much more difficult to read. See screenshot
There is no possibility to sort the items in the list for now, Is this what you mean? If you want do things with the values temperature or lux maybe you think about anyway of a Home Automation System. With this you can do a lot more things - and sorting. A list of compatbile systems are here:
https://www.phoscon.de/en/conbee2#hasystems
The ask is for athe GUI to be fixed so that all the sensors deisplay in the same way, same data order. Should be simple fix (maybe 2 lines of code to order the data consistantly) and it will make it a lot easier to read.
Ah ok, our developers are aware of this. Probably in the course of the introduction of the DDF’s there will be a change here as well.
